extending/overriding source code generation i [message #143918] |
Tue, 04 March 2008 15:10 |
Originally posted by: frank.rausch.gmx.net
Dear list members,
for a current project I wrote a new layout manager - based on
GridBagConstraints but it does not inherit from GridBagLayout - which
works as designed, but it should integrate in IBM RSA V7 to switch the
layout from the properties view.This works already by using
java.awt.LayoutManager.override.
Further it is possible to see the GridFeedback by using a new
LayoutPolicyFactory which inherits from GridBagLayoutPolicyFactory
defined in the appropiate override file.
But when one switches the layout the constraint variables are named
>gridbagconstraintsXX< with XX substituted by a number. But I want to use
a different name for the constraint variable built on the name of the
component variable which is described by the constraint. How can this be
done?
Further I want every added component being described in a separate
init-method instead of being set up in the method of the containing
container!
Please help!
kind regards
Frank Rausch
FUDForum. Page generated in 0.05684 seconds
