Re: Build VE for Eclipse 3.3 [message #143913 is a reply to message #143785] |
Tue, 04 March 2008 14:31 |
Originally posted by: mik.c-l-a-s-s-x.it
Hi Yves,
Everything is working very well with Europa 3.3.2 (Eclipse Europa Winter
Maintenance Packages).
The installation is really easy:
- download your VE build
- download Eclipse 3.3.2 (eclipse-java-europa-winter-win32.zip)
- download emf-sdo-xsd-SDK-2.3.2.zip
- download GEF-ALL-3.3.2.zip
- unzip them all with respect of the eclipse directory structure.
- READY to use. Just start Eclipse.
Many thanks.
Mik
> ClassX Development Italy Via Francesca, 368/I I-56030 S.M. a Monte (PI) <
> Tel.(+39)-0587-705153 Fax.(+39)-0587-705153 WEB: http://www.classx.it <
"Yves YANG" <yves.yang@soyatec.com> ha scritto nel messaggio
news:fo5u8t$8tv$1@build.eclipse.org...
> Hi All,
> Here is the build I made for Eclipse 3.3 with the bugfix of
> GridBagConstraint:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=203542
> The build is available here for Windows:
> http://www.soyatec.org/update/org.eclipse.ve_1.3.0.200802040 250.zip
> It depends on emf-sdo-xsd-SDK-2.3.0.zip and GEF-ALL-3.3.1.zip. You need
> to install them first. Please keep in mind, it is not official build. You
> use
> it at your risk. Any report are welcome.
> Best regards
> Yves YANG
> http://www.soyatec.com
Re: Build VE for Eclipse 3.3 [message #143978 is a reply to message #143969] |
Mon, 10 March 2008 09:25 |
Hi David,
this is the simplest working Eclipse 3.3.2 + VE installation around.
Maybe this should be added to the Wiki.
It would be nice to hear from Yves YANG..
Mik
"David Perez" <craquerpro@yahoo.es> ha scritto nel messaggio
news:f4cac21a416ecfe1660f883c44a3381e$1@www.eclipse.org...
> Thanks for your tips.
> GEF runtime 3.3.2 is a smaller download and also works.
> Probably the EMF runtime will be also enough, instead of the full SDK.
> Why don't make it official?
FUDForum. Page generated in 0.04138 seconds
