Home » Modeling » EMF » eInvoke fails
eInvoke fails [message #991607] Wed, 19 December 2012 16:01 Go to next message
it's me again . For my project I have to use the eInvoke-method to call an Operation for a certain EObject.
But no matter which method I want to invoke it always fails with the Exception:
java.lang.UnsupportedOperationException: eInvoke not implemented for getAllSuperClassifiers
I honestly don't have any clue what goes wrong, the internet doesn't show that much detail
for what "eInvoke not implemented for XZY" means.
Any help would be appreciated.
Greetings
Markus
Re: eInvoke fails [message #991915 is a reply to message #991607] Thu, 20 December 2012 08:30 Go to previous messageGo to next message
Markus,
Did you generate the model to support "Operation Reflection"?
On 19/12/2012 1:01 PM, Markus Riedl wrote:
> Hello,
> Exception:
> Greetings
> Markus
Re: eInvoke fails [message #991937 is a reply to message #991915] Thu, 20 December 2012 09:05 Go to previous messageGo to next message
Ahhh that seems to be the problem.. quite hidden in fact..
Greetings
Re: eInvoke fails [message #991944 is a reply to message #991937] Thu, 20 December 2012 09:19 Go to previous messageGo to next message
Markus,
With Xcore-based models, it defaults to true...
> Greetings
Re: eInvoke fails [message #991952 is a reply to message #991944] Thu, 20 December 2012 09:39 Go to previous messageGo to next message
Hi Ed
Is it easy for OCLinEcore to change this default too, or is this only
possible once genmodel is integrated into the model model?
Ed Willink
On 20/12/2012 14:19, Ed Merks wrote:
> Markus,
>> Greetings
Re: eInvoke fails [message #991967 is a reply to message #991952] Thu, 20 December 2012 10:08 Go to previous messageGo to next message
Ed,
I added the method
org.eclipse.emf.codegen.ecore.genmodel.GenModel.initialize(boolean) in
2.8 and it's called by when creating new models, i.e.,
org.eclipse.emf.importer.ModelImporter.adjustGenModel(Monitor), and when
a GenModel is inferred from an Xcore model.
On 20/12/2012 6:39 AM, Ed Willink wrote:
> Hi Ed
> Regards
> Ed Willink
>> Markus,
>>> Greetings
Re: eInvoke fails [message #991999 is a reply to message #991967] Thu, 20 December 2012 11:25 Go to previous messageGo to next message
Hi Ed
Great. So it's fixed for everything; I had a vague feeling that things
had got better here.
Ed
On 20/12/2012 15:08, Ed Merks wrote:
> Ed,
> I added the method
> when a GenModel is inferred from an Xcore model.
>> Hi Ed
>> Regards
>> Ed Willink
>>> Markus,
>>>> Greetings
Re: eInvoke fails [message #992007 is a reply to message #991999] Thu, 20 December 2012 11:42 Go to previous messageGo to next message
Ed,
Yes, I have to balance keeping things stable for the established user
base, while making useful improvements for the new user base. This
approach of keeping defaults such that the base is stable while setting
improved defaults for new models seemed like a good way to balance those
conflicting needs.
On 20/12/2012 8:25 AM, Ed Willink wrote:
> Hi Ed
> Regards
> Ed
>> Ed,
>> I added the method
>> in 2.8 and it's called by when creating new models, i.e.,
>>> Hi Ed
>>> only possible once genmodel is integrated into the model model?
>>> Regards
>>> Ed Willink
>>>> Markus,
>>>>> Greetings
Re: eInvoke fails [message #992750 is a reply to message #992007] Sat, 22 December 2012 08:54 Go to previous messageGo to next message
It maybe default, but the genmodel which I referred to was not under my control (not until now), there they intentionally or not set Operation Reflection to false and even in IBM RSA 8.5 the default is false
Greetings
Re: eInvoke fails [message #992836 is a reply to message #992750] Sat, 22 December 2012 14:41 Go to previous message
Markus,
Yes, unfortunately a model needs to generate support for that and if a
model doesn't do that, your extension of it isn't going to be able to
support operation reflection either.
> false
> Greetings
Previous Topic:EMF and Java Templates
Next Topic:How to avoid an EMF Object in XMI serialisation
Current Time: Wed Nov 05 14:53:42 EST 2025
Powered by FUDForum. Page generated in 0.05803 seconds
