Problem installing hibernate library bundles [message #991410] |
Tue, 18 December 2012 23:28 |
Daniel Łaś Messages: 1 Registered: December 2012 |
I have fresh instalation of Virgo 3.5.0. I try to deploy org.hibernate.ejb-library in version 3.4.0.GA-A. All bundles except com.springsource.org.hibernate.annotations-3.4.0.GA-A and com.springsource.org.hibernate.ejb-3.4.0.GA-A are successfuly started. When I copy com.springsource.org.hibernate.annotations-3.4.0.GA-A.jar to pickup folder, following exception is thrown:
HD0003E Hot re-deploy failed for file 'com.springsource.org.hibernate.annotations-3.4.0.GA-A.jar'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Dependency satisfaction failed
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:363)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:139)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:252)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:163)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:70)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'com.springsource.org.hibernate.annotations' at version '3.4.0.GA-A': Cannot resolve: com.springsource.org.hibernate.annotations
Resolver report:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.springsource.org.hibernate.annotations_3.4.0.GA-A. Resolver error data <Import-Package: org.hibernate.annotations.common.annotationfactory; version="[3.3.0.ga,3.4.0)">. Caused by missing constraint in bundle <com.springsource.org.hibernate.annotations_3.4.0.GA-A>
constraint: <Import-Package: org.hibernate.annotations.common.annotationfactory; version="[3.3.0.ga,3.4.0)">
Possible hosts:
com.springsource.org.hibernate_3.3.2.GA (resolved)
Constraint conflict:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.springsource.org.hibernate.annotations_3.4.0.GA-A. Resolver error data <Import-Package: org.hibernate.annotations.common.reflection; version="[3.3.0.ga,3.4.0)">. Caused by missing constraint in bundle <com.springsource.org.hibernate.annotations_3.4.0.GA-A>
constraint: <Import-Package: org.hibernate.annotations.common.reflection; version="[3.3.0.ga,3.4.0)">
Possible hosts:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.springsource.org.hibernate.annotations_3.4.0.GA-A. Resolver error data <Import-Package: org.hibernate.annotations.common.reflection.java; version="[3.3.0.ga,3.4.0)">. Caused by missing constraint in bundle <com.springsource.org.hibernate.annotations_3.4.0.GA-A>
constraint: <Import-Package: org.hibernate.annotations.common.reflection.java; version="[3.3.0.ga,3.4.0)">
Possible hosts:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.springsource.org.hibernate.annotations_3.4.0.GA-A. Resolver error data <Import-Package: org.hibernate.annotations.common.util; version="[3.3.0.ga,3.4.0)">. Caused by missing constraint in bundle <com.springsource.org.hibernate.annotations_3.4.0.GA-A>
constraint: <Import-Package: org.hibernate.annotations.common.util; version="[3.3.0.ga,3.4.0)">
Possible hosts:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.springsource.org.hibernate.annotations_3.4.0.GA-A. Resolver error data <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">. Caused by missing constraint in bundle <com.springsource.org.hibernate.annotations_3.4.0.GA-A>
constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">
Possible hosts:
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:360)
... 9 common frames omitted
Can somebody explain/help solve the issue?
FUDForum. Page generated in 0.05073 seconds
