[EVL] Problem running a evl file [message #991369] |
Tue, 18 December 2012 19:33 |
Sebastian Rivera Messages: 7 Registered: December 2012 |
Hi , I'm having the following problem:
i have my evl file ,it does the validation all ok but when i modify any value in the model that the constraint checks, like changing a attribute name of a class to another. When i run the validation again it keeps like a copy of the model in the cache and still sees the old value of the attribute. So i have to close eclipse and open it again and then if i run the evl file again it works as intended.
In resume it looks like for the purpose of the evl it keeps looking a old model saved in the cache without the modifications that i could have done after the first time i run the evl file.I don't know how to fix the problem ,I have tried checking and testing the different options on the "Configure EMF models" window but without any good result.
I'm using Eclipse Indigo and the version 1.0.0.201211082326 of Epsilon
If you need more info or anything please tell me and also sorry for my English since its not my native language
Thx a lot for the help in advance.
[Updated on: Tue, 18 December 2012 19:34] Report message to a moderator
Re: [EVL] Problem running a evl file [message #991461 is a reply to message #991412] |
Wed, 19 December 2012 10:34 |
After you run your EVL launch configuration, you should inspect any unsatisfied constraints and then click the green play-like button in the Validation view to finalise its execution before you can run it again.
Dimitris
FUDForum. Page generated in 0.04129 seconds
