Home » Eclipse Projects » EGit / JGit » How to untrack already tracked files(Untrack indexed files)
How to untrack already tracked files [message #991345] Tue, 18 December 2012 10:37 Go to next message
We are using the Eclipse EGit Plug-In to work with Git and integrate with BitBucket and we are having issues to untrack already tracked files from a repository and populating this change to other team members via PULL.
This is how we do it:
1. Working in a branch (not the master branch)
2. Untrack an already tracked file using Team context menu, Untrack
3. Adding the file to .gitignore
4. Commit changes on the branch
5. Switch to master
6. Merge
7. Push
It doesn't look like the untrack change from the branch was merged to the master branch and of course wasn't pushed as a change to the remote repository.
Can someone suggest a resolution?
Liron
Re: How to untrack already tracked files [message #991383 is a reply to message #991345] Tue, 18 December 2012 15:32 Go to previous messageGo to next message
Works fine for me in EGit 2.2.0.201212162313. After step 6 the deleted file is removed from the master branch and the filename is added to .gitignore -- exactly what I would expect.
What do you see in master after the merge, and what version of EGit are you using?
I would normally use 'delete' in this scenario, rather than 'untrack', since the untracked file won't survive steps 5 & 6 anyway. But I suppose it's handy to keep the untracked file around in the branch briefly so you can do step 3 via Team -> Ignore, which is a bit more reliable than editing .gitignore manually.
Re: How to untrack already tracked files [message #991997 is a reply to message #991383] Thu, 20 December 2012 11:22 Go to previous message
You can't do that using the commit dialog since it's using the jgit equivalent of commit -o which by definition ignores the index.
But the fact that you want to no longer track a file which was tracked so far is only reflected in the index Sad
Hence (at least at the moment) you need to use the staging view in order to be able to commit untracking a file which was tracked
earlier.
Previous Topic:Synchronize View remains empty despite lots of unstaged changes?
Next Topic:Egit well installed, but no GIT menu
Current Time: Sat Nov 08 19:55:30 EST 2025
Powered by FUDForum. Page generated in 0.02691 seconds
