Several XML Files into one UML [message #990994] |
Sun, 16 December 2012 14:08 |
Tex Iano Messages: 99 Registered: February 2012 |
Member |
I have the following situation:
I have a lot of XML files (XSD files, XML files based on custom XSD etc.) with cross-references (e.g. in one XSD another XSD is imported and types defined in this file are refined etc.). Now I want to create one UML model from these files.
Is this possible with ATL? Currently I am using ATL only that way:
One file as input => one file as output.
But how do I work with ATL in this situation? The number of input files can differ and everything is expected to be part of one big model.
Is this possible at all?
Tex
[Updated on: Sun, 16 December 2012 14:12] Report message to a moderator
Re: Several XML Files into one UML [message #991044 is a reply to message #990994] |
Mon, 17 December 2012 07:45 |
I have a transformation with two input files, and one output file
module transf;
create OUT : UML from IN : UML, UTP : UML;
Then, in the run configuration you need to specify every model involved with a correspondig file.
Also, you can use libraries (common operations) and superimposition, where you can configure different files. Take a look to the documentation with these ideas and for sure you are going to make it work
bye!
FUDForum. Page generated in 0.02723 seconds
