Re: Eclipse CFScript Syntax Highlighting Bug [message #990885 is a reply to message #990870] |
Fri, 14 December 2012 16:18 |
Ed Merks Messages: 33145 Registered: July 2009 |
CFEclipse isn't a project hosted at Eclipse so better you look for help
at their link: http://cfeclipse.org/index.cfm/help/
On 14/12/2012 4:50 PM, Jonas Müller wrote:
> I have the eclipse juno service release 1 with CFeclipse.
> The syntax coloring preferences are set, so that text is black and expressions in quotes are blue. When i use single quotes within CFScript, then after the closing quote all of the following code becomes blue. The code is correct, i tried it in dreamweaver, and all of the code was highlighted fine.
> Someone has an answer?
> Images attached:
> - eclipse installation details
> - syntax highlighting bug
Ed Merks
FUDForum. Page generated in 0.08092 seconds
