Re: How to analyse the runtime of my java programm [message #991154 is a reply to message #991010] |
Mon, 17 December 2012 14:51 |
Thomas Messages: 12 Registered: October 2012 |
If you don't want to install anything, I would recommend using JVisualVM to profile your program. As long as you have the JDK installed, you should be able to find it in the "bin" folder of your JDK. Once you have it up, run your program, click on your program in the tree on the left, go to the "Profiler" tab, and click on the CPU button.
For more information, look at http://visualvm.java.net/profiler.html
Note that if your installation of the JDK is old enough that the included JVisualVM doesn't have the "Profiler" tab, you should probably update your JDK, or at least update to the latest version of JVisualVM.
FUDForum. Page generated in 0.03460 seconds
