Home » Archived » Buckminster » Running ExternalTools headless
Running ExternalTools headless [message #990545] Wed, 12 December 2012 19:41 Go to next message
Is this possible?
I've read that I need this 'org.eclipse.core.externaltools' plugin. I managed to intall it by installing the 'org.eclipse.platform' feature but it fails when I run it because it's trying to activate "org.eclipse.debug.ui"
Any help appriciated.
ERROR: An error occurred while automatically activating bundle org.eclipse.debug.ui (142).
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.debug.core.DebugPlugin.getStatusHandler(DebugPlugin.java:584)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.saveBeforeLaunch(LaunchConfigurationDelegate.java:252)
at org.eclipse.ant.internal.launching.launchConfigurations.AntLaunchDelegate.saveBeforeLaunch(AntLaunchDelegate.java:868)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.preLaunchCheck(LaunchConfigurationDelegate.java:208)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:809)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:696)
at org.eclipse.buckminster.core.commands.Launch.internalRun(Launch.java:209)
at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:350)
at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:145)
at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:165)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:546)
at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:315)
at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:516)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 47 more
Re: Running ExternalTools headless [message #990710 is a reply to message #990545] Thu, 13 December 2012 03:49 Go to previous messageGo to next message
Hi Philip
in this plugin, part of my project,
http://sourceforge.net/p/xsemantics/code/ci/master/tree/examples/it.xsemantics.xsemantics.ui.examples/
I have a build.xml which basically creates some zips, and I have the
corresponding
org.eclipse.buckminster.ant.AntBuilder
in the .project
with that, an headless build automatically calls the ant targets (and in
this case it creates the zips).
Is that what you would need?
as for features installed in headless buckminster I only use these ones
org.eclipse.buckminster.cmdline.product
org.eclipse.buckminster.core.headless.feature.feature.group
org.eclipse.buckminster.pde.headless.feature.feature.group
hope it helps
cheers
Lorenzo
On 12/13/2012 01:41 AM, Philip Bedingfield wrote:
> Is this possible?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> created yet.
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 47 more
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Running ExternalTools headless [message #990739 is a reply to message #990710] Thu, 13 December 2012 19:06 Go to previous messageGo to next message
Thanks Lorenzo
I solved it by creating a few buckminster actions, thus using buckminster ant.
Re: Running ExternalTools headless [message #990794 is a reply to message #990739] Fri, 14 December 2012 05:04 Go to previous message
On 12/14/2012 01:06 AM, Philip Bedingfield wrote:
> Thanks Lorenzo
> buckminster ant.
could you please share it? :)
cheers
Lorenzo
Previous Topic:create a site.p2 from the target platform (again)
Next Topic:p2 sites for 3.8 target platform
Current Time: Sun Oct 26 09:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.04026 seconds
