Home » Eclipse Projects » EGit / JGit » EGit says files are dirty but Git says working directory is clean
EGit says files are dirty but Git says working directory is clean [message #990505] Wed, 12 December 2012 14:07 Go to next message
I'm at the end of my rope here.
For the last two hours I've been trying to figure out why EGit is telling me that a file is dirty when it is not. Example: I open a text file in the repository. I add something, save, undo, then save again. The file is now back to its original content, but EGit still shows the file as being dirty.
Similarly, I can't successfully discard changes to a dirty file. My understanding is that Replace With -> HEAD Revision is supposed to accomplish this. But whenever I try it, the file is still showing as dirty afterwards. And if I do it on a file that's not dirty, it suddenly becomes dirty.
Meanwhile, if I do git status on the command line (or, more accurately, in Git Bash, since I'm on Windows), it reports that there's nothing to commit and the working directory is clean.
Anyone know WTF is going on here?
Re: EGit says files are dirty but Git says working directory is clean [message #990523 is a reply to message #990505] Wed, 12 December 2012 16:27 Go to previous messageGo to next message
Presumably what you're seeing are unix v dos linebreak differences. What version of EGit do you have installed, and how are you handling linebreaks in your repository?
Some older versions of JGit don't support core.autocrlf properly, and as far as I know, no versions support .gitattributes yet. But you should be ok with core.auto.crlf in the latest EGit/JGit (currently 2.2.0.201212041527)
[Updated on: Wed, 12 December 2012 16:30] by Moderator
Re: EGit says files are dirty but Git says working directory is clean [message #990542 is a reply to message #990523] Wed, 12 December 2012 19:26 Go to previous messageGo to next message
Thanks for the reply. That was the first thing I thought of. Looked at the files in a text editor, they're always CR+LF before and after I edit them. Was using the latest stable release, tried updating to nightly. Problem is still there. Any other thoughts?
Re: EGit says files are dirty but Git says working directory is clean [message #990639 is a reply to message #990542] Thu, 13 December 2012 09:48 Go to previous messageGo to next message
How is your repository configured to handle linebreaks? Are you using core.autocrlf or .gitattributes, or some other scheme?
If you're using core.autocrlf you might need to force a full re-checkout of the branch so that the autocrlf stuff has a chance to do its thing properly. You should also try making a entirely new clone with the updated EGit/JGit, if only to see if that behaves better. What value of core.autocrlf are you using and what are your unix/linux co-workers using?
As mentioned previously, If you're using .gitattributes I don't think JGit knows what to do with it. I hope this is added soon, as .gitattributes is a cleaner way to deal with this.
Or you could buy a Mac Smile
Re: EGit says files are dirty but Git says working directory is clean [message #990646 is a reply to message #990639] Thu, 13 December 2012 10:08 Go to previous messageGo to next message
Making an entirely new clone seems to do the trick. Thanks!
The entire team I'm on (only 3 people) just switched a couple projects to Git from Mercurial. Wasn't our choice; company politics forced the change. So we're all Git noobs right now. No idea what core.autocrlf is set to, but we're all developing on Windows boxes.
Re: EGit says files are dirty but Git says working directory is clean [message #990655 is a reply to message #990646] Thu, 13 December 2012 10:56 Go to previous messageGo to next message
core.autocrlf and .gitattributes are different ways in Git of handling platform-specific linebreaks. it's mostly intended for projects in which some developers are in linux or os x and others are in windows. The usual pattern is that the internal representation for a linebreak is lf. In windows, lf is converted to cr+lf on checkout and converted back to lf on commit. In linux and os x, lf is left as is. This allows the local representation of text files to have the right form for the local platform, regardless of the internal representation.
core.autorcrlf is a configuration setting that was the original fix for this issue. Each developer has to set this independently. Typically windows users would set it to 'true' (ie, always convert on both checkout and commit) and linux/os x users would set it to 'input' (leave as is, except convert any stray cr+lf to lf on checkout so that it can be fixed).
.gitattributes is a newer and more general approach to this problem. This a file that can be checked in as part of the repository. It specifies the handling of linebreaks, among other things.
If everyone on your team is using Windows and if none of you are making any use of core.autocrlf (or .gitattributes) I'm not sure why you had a problem in the first place. Depending how you set up your local installation of Git, it might well have set core.autocrlf to 'true' at the system level. If the installation prompted you with a question about linebreak conversion and you answered 'yes', that's what happened. If any team member has this setting enabled, all of you have to have it enabled. You can check by running 'git config -l' in the shell or by looking at the 'Properties' view in the 'Git Repository Exploring' perspective in Eclipse.
Mercurial is a clean and elegant distributed version-control system. I used it happily for awhile and was annoyed by the seemingly excessive complexity of Git. But once I grasped a few key Git concepts, it revolutionized my thinking about version control. I'll never voluntarily go back to HG at this point, much less SVN <shudder>.
Re: EGit says files are dirty but Git says working directory is clean [message #991384 is a reply to message #990505] Tue, 18 December 2012 15:32 Go to previous messageGo to next message
Rich DiCroce skrev 2012-12-12 20.07:
> directory is clean.
No, but I fixed a bug recently that resulted in reports of false conflicts when switching
branches. The bug was in one of the core classes so might have strange behavior in many
places. The fix is in the nightly builds so you may want to try it.
-- robin
Re: EGit says files are dirty but Git says working directory is clean [message #1713651 is a reply to message #991384] Thu, 05 November 2015 13:06 Go to previous messageGo to next message
It's three years later and I'm having the same problem.
I've got a project attached to a Git repository. EGit is displaying the > sign indicating that the project is dirty, but command-line git says everything is clean and up-to-date. I also have no way to tell what EGit thinks is dirty, because none of the subsidiary files are marked as dirty.
Googling around, I found some StackOverflow articles suggesting that this problem could arise from the way Windows handles line feeds. I don't think this is the issue here because no Windows machine has ever committed to this repository. In any case, those articles suggested that the problem has been fixed, but it still happens on a freshly-downloaded version of Eclipse, even when I re-clone the repository from GitHub.
Help!
Re: EGit says files are dirty but Git says working directory is clean [message #1713653 is a reply to message #1713651] Thu, 05 November 2015 13:20 Go to previous messageGo to next message
Aha! Found a workaround:
My directory had one of those .DS_Store files that OS X uses to keep track of how the directory should be displayed in the Finder. Adding that to .gitignore did the trick.
Still, it's disturbing that git and EGit disagreed as to the cleanliness of the directory.
Re: EGit says files are dirty but Git says working directory is clean [message #1713682 is a reply to message #1713653] Thu, 05 November 2015 17:10 Go to previous message
I guess your Eclipse is configured to hide "." files hence you can't see what's causing the dirty status.
In Project Explorer (or package explorer) click the little triangle in the upper right corner of the view and
check if you are filtering out .* resources, if that's the case uncheck this option and you should see
which files is causing the dirty status on the project/repository.
Previous Topic:jgit: mvn clean install (windows 7) / core tests failed
Next Topic:jgit-cli: "log <file>" -- failed: <file> is not a commit
Current Time: Mon Sep 22 07:26:47 EDT 2025
Powered by FUDForum. Page generated in 0.04693 seconds
