a reference to a previous element (tree view of the model) [message #990502] |
Wed, 12 December 2012 18:49 |
Aran A Messages: 30 Registered: January 2011 |
Member |
Hi!,
Working with the "Sample Reflective Ecore Model Editor" I've found a behaviour that seems quite strange to me. I would like to know what the reason is.
In my metamodel I have two classes A and B, the former has a no-containment association (cardinality: 1) to B (called 'creates').
Using the "create dynamic instance" option, I have created a new model conformed to the metamodel. Everything is OK. When I open that model with the "Sample Reflective Ecore Model Editor" I see that when an A element refers to one B element that is behind itself in the tree, its 'creates' attribute is fulfilled with the right value (the identity of the corresponding B element). However, when the A element refers to one B element that is before itself in the tree, its 'creates' attribute is 'empty'. If I open the model with the "Text editor", in both cases the 'creates' attribute has the right value, so in the second case, the reference attribute seems to be 'empty', but it has a value really.
Could anybody explain me the reason for this behaviour? or maybe, do I have to change any configuration somewhere?
Thanks in advance, best regards
Aran
Re: a reference to a previous element (tree view of the model) [message #990700 is a reply to message #990502] |
Wed, 12 December 2012 20:22 |
Ed Merks Messages: 33146 Registered: July 2009 |
Aran,
Comments below.
On 12/12/2012 7:49 PM, Aran A wrote:
> Hi!,
> the reason is.
So you mean the reference.
What do you mean by 'empty'? You're seeing this in the Properties view?
I don't understand what you're trying to explain. Perhaps a screen
capture would help...
> Aran
Ed Merks
FUDForum. Page generated in 0.05228 seconds
