Re: 5009: AUT start failed [message #994075 is a reply to message #990812] |
Wed, 26 December 2012 10:15 |
emre ergun Messages: 3 Registered: December 2012 |
Hello again,
Sorry for the late comment.
I use embedded agent and Java written AUT. I am sure that just one AUT starts at that time. These are the steps:
1 - I install GuiDancer.
2 - Open it.
3 - Open a new work space.
4 - Cofigure it's PostGreSQL option. (My test cases are stored in a PostGreSQL database)
5 - Start AUT.
6 - Make new test cases.
7 - Close the AUT.
8 - Stop the agent.
9 - Close GuiDancer.
If I restart Guidancer with the previous work space, the agent is connected but I get the 5009: AUT start failed exception. However if I close the AUT, disconnect the agent do not close Guidancer and then reconnect the agent again AUT starts successfully. To solve this problem I open a new work space or uninstall everyting about Guidancer and do the steps above.
Thanks for your help.
[Updated on: Wed, 26 December 2012 10:15] Report message to a moderator
Re: 5009: AUT start failed [message #1002138 is a reply to message #999136] |
Fri, 18 January 2013 02:21 |
posia han Messages: 43 Registered: December 2012 |
Member |
some suggestion for you ,I have meet the problem before, at the end I confirmed The AUT configuration and found that there is some problem at the configuration,such as the excutable File name configurated error or the file is not exit in the configurate path.I hope that my answer can help you a little.
posia
[Updated on: Fri, 18 January 2013 02:22] Report message to a moderator
FUDForum. Page generated in 0.03131 seconds
