Home » Eclipse Projects » Remote Application Platform (RAP) » ClassNotFoundException in OSGi but jars included(Problem resolving classes that apparently are included)
| ClassNotFoundException in OSGi but jars included [message #989723] |
Fri, 07 December 2012 07:50  |
Trying to execute a RAP application from Eclipse 4.2.1 with RAP 2.0 M3 under OSGi but having problems persuading it to find all of my referenced classes.
The application runs ok as SWT Standalone.
Firstly, here is the error reported in the console:
2012-12-07 12:25:37.033:WARN:oejs.ServletHandler:ERROR: Error for /rapide;jsessionid=k3ooqc2qng501m3x93hh6xkcv
java.lang.NoClassDefFoundError: com/ca/gen80/abrt/ABBase
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at iet.co.uk.rapide.RapideInstance.initialisePStep(RapideInstance.java:2299)
at iet.co.uk.rapide.RapideMain.GenGUILoadPStep(RapideMain.java:194)
at iet.co.uk.rapide.RapideMain.begin(RapideMain.java:76)
at iet.co.uk.rapide.RapideMain.start(RapideMain.java:35)
at iet.co.uk.rapide.RapideEntryPoint.createUI(RapideEntryPoint.java:52)
at iet.co.uk.rapide.RapideApplication.start(RapideApplication.java:8)
at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
at java.lang.Thread.run(Thread.java:662)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
Caused by:
java.lang.ClassNotFoundException: com.ca.gen80.abrt.ABBase
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
My RAP application is the 'iet.co.uk.rapide' one, which references a set of classes starting 'ca.com.gen80.*'. These are in a single JAR called 'gen80rt.jar'.
Where should I be specifying the gen80rt.jar so that my RAP app can find it at runtime? gen80rt.jar is not a Plug-in or a Bundle, just a totally stand-alone JAR file. There doesn't appear to be a concept of a CLASSPATH for RAP applications (apart from the Bundle's Classpath that I've included further down in this post), which sort of makes sense since they have to define precisely what they export and what they import in the manifest, but how to actually reference this JAR?
Perhaps this is very basic, and I'm missing something fundamental, so please be patient while I get my head around it all!
I've placed gen80rt.jar into WEB-INF/lib by the way.
Basic project structure as below:
ss from OSGi in the console gives:
ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20121026-132713
Fragments=7
1 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20120918-182152
2 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20120521-2329
3 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
4 ACTIVE org.eclipse.equinox.app_1.3.100.v20120522-1841
5 ACTIVE org.eclipse.rap.ui.workbench_2.0.0.20121106-1948
6 ACTIVE org.eclipse.equinox.console_1.0.100.v20121001-124408
7 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.2.100.v20120522-2049
Master=0
8 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
9 ACTIVE org.eclipse.core.commands_3.6.1.v20120814-150512
10 ACTIVE org.eclipse.rap.jface.databinding_2.0.0.20121031-1050
11 ACTIVE org.eclipse.rap.rwt.osgi_2.0.0.20121031-1050
12 ACTIVE org.eclipse.jetty.security_8.1.3.v20120522
13 ACTIVE org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841
14 ACTIVE org.eclipse.equinox.http.registry_1.1.200.v20120912-125810
15 ACTIVE org.eclipse.core.databinding_1.4.1.v20120912-132807
16 ACTIVE org.eclipse.equinox.common_3.6.100.v20120522-1841
17 ACTIVE org.eclipse.core.runtime_3.9.0.v20121004-163638
18 ACTIVE javax.servlet_3.0.0.v201112011016
19 ACTIVE org.eclipse.rap.ui_2.0.0.20121105-1706
20 ACTIVE org.eclipse.core.databinding.beans_1.2.200.v20120523-1955
21 ACTIVE org.eclipse.equinox.registry_3.5.300.v20120731-134527
22 ACTIVE org.eclipse.core.expressions_3.4.401.v20120912-155018
23 ACTIVE org.eclipse.jetty.util_8.1.3.v20120522
24 ACTIVE iet.co.uk.rapide.runtime_1.0.0.qualifier
25 ACTIVE org.eclipse.osgi.services_3.3.100.v20120522-1822
26 ACTIVE org.eclipse.jetty.server_8.1.3.v20120522
27 ACTIVE org.eclipse.core.contenttype_3.4.200.v20120523-2004
28 ACTIVE com.ibm.icu.base_4.4.2.v20110831
29 ACTIVE org.eclipse.jetty.http_8.1.3.v20120522
30 ACTIVE org.eclipse.help_3.6.0.v20120521-2344
31 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20120824-092539
32 ACTIVE org.eclipse.rap.design.example_1.5.100.20121109-0718
33 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
34 ACTIVE org.eclipse.jetty.continuation_8.1.3.v20120522
35 ACTIVE org.eclipse.rap.jface_2.0.0.20121031-1050
36 ACTIVE org.eclipse.equinox.http.servlet_1.1.300.v20120912-125810
37 ACTIVE org.eclipse.jetty.io_8.1.3.v20120522
38 ACTIVE org.eclipse.rap.ui.forms_1.5.100.20121105-1308
39 ACTIVE org.eclipse.rap.rwt_2.0.0.20121112-1148
40 ACTIVE org.eclipse.core.jobs_3.5.300.v20120912-155018
41 ACTIVE org.eclipse.jetty.servlet_8.1.3.v20120522
42 ACTIVE javax.xml_1.3.4.v201005080400
43 ACTIVE org.eclipse.rap.ui.views_1.5.100.20121031-1050
osgi>
So I can see my Bundle as ACTIVE at number 24 in this case.
My Manifest looks like this:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %Bundle-Name
Bundle-SymbolicName: iet.co.uk.rapide.runtime;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: %Bundle-Vendor
Import-Package: iet.co.uk.rapide,
org.eclipse.rap.rwt.application;version="2.0.0",
org.eclipse.rap.rwt.lifecycle;version="2.0.0",
org.eclipse.rap.rwt.widgets;version="2.0.0",
org.eclipse.swt,
org.eclipse.swt.events,
org.eclipse.swt.graphics,
org.eclipse.swt.layout,
org.eclipse.swt.widgets
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: iet.co.uk.rapide;
uses:="com.ca.gen80.vwrt.vdf,
eu.jgen.gen.invoke.ab.base,
org.eclipse.rap.rwt.application,
org.w3c.dom,
org.eclipse.swt.ole.win32,
com.ca.gen80.abrt,
com.ca.gen80.csu.exception,
com.ca.gen80.vwrt,
org.eclipse.rap.rwt.lifecycle,
org.eclipse.equinox.app,
org.eclipse.swt.widgets"
Require-Bundle: org.eclipse.rap.ui
Bundle-ClassPath: .,
WEB-INF/lib/gen80rt.jar
I'm not sure that I understand where the 'uses' come from, or if they are relevant?
Any suggestions as to how to get the class loader to see the Classes in gen80rt.jar?
Thanks, John
[Updated on: Fri, 07 December 2012 07:51] by Moderator
| Re: ClassNotFoundException in OSGi but jars included [message #989764 is a reply to message #989723] |
Fri, 07 December 2012 11:08   |
Ok, so I figured out that I have to have the gen80rt.jar in a Bundle, which I've done, giving MANIFEST of that project looking like this:
Bundle-Name: Gen r8.0 Runtimes
Bundle-SymbolicName: com.ca.gen80.runtimes
Bundle-Version: 8.0.0
Bundle-ClassPath: gen80rt.jar
Export-Package: com.ca.gen80.abrt,
com.ca.gen80.abrt.cascade,
com.ca.gen80.abrt.functions,
com.ca.gen80.abrt.manager,
com.ca.gen80.abrt.trace,
com.ca.gen80.csu.MIME,
com.ca.gen80.csu.load,
com.ca.gen80.csu.nls,
com.ca.gen80.csu.resource,
com.ca.gen80.csu.semaphore,
... (and lots more than I'd expect - various classes I need access to) ...
Import-Package: javax.xml.ws,
javax.xml.bind,
javax.sql,
javax.rmi,
javax.xml.bind.annotation.adapters,
javax.transaction,
javax.servlet.http; version="2.6.0",
javax.naming,
javax.servlet; version="2.6.0",
javax.xml.soap
In my original RAP project where I want to use this JAR, I've added a dependency to it as follows:
I then modify my RAP Run Configuration to include this new Bundle:
Unfortunately nothing has changed. The browser gives the same as previous:
HTTP ERROR: 500
Problem accessing /rapide;jsessionid=1f3nt5siflgtg12n9k9k761xxz. Reason:
Powered by Jetty://
...and the console still gives:
Caused by:
...and ss in OSGi console gives:
ss
id State Bundle
Fragments=5
1 ACTIVE org.eclipse.core.runtime_3.9.0.v20121004-163638
2 ACTIVE org.eclipse.rap.rwt_2.0.0.20121112-1148
3 ACTIVE org.eclipse.rap.ui.workbench_2.0.0.20121106-1948
4 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
5 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.2.100.v20120522-2049
Master=0
6 ACTIVE com.ca.gen80.runtimes_8.0.0
7 ACTIVE org.eclipse.rap.ui.views_1.5.100.20121031-1050
8 ACTIVE org.eclipse.jetty.io_8.1.3.v20120522
9 ACTIVE org.eclipse.equinox.registry_3.5.300.v20120731-134527
10 ACTIVE org.eclipse.equinox.app_1.3.100.v20120522-1841
11 ACTIVE org.eclipse.help_3.6.0.v20120521-2344
12 ACTIVE org.eclipse.jetty.continuation_8.1.3.v20120522
13 ACTIVE org.eclipse.equinox.http.servlet_1.1.300.v20120912-125810
14 ACTIVE org.eclipse.equinox.console_1.0.100.v20121001-124408
15 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
16 ACTIVE javax.xml_1.3.4.v201005080400
17 ACTIVE iet.co.uk.rapide.runtime_1.0.0.qualifier
18 ACTIVE org.eclipse.rap.jface.databinding_2.0.0.20121031-1050
19 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
20 ACTIVE org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841
21 ACTIVE org.eclipse.jetty.servlet_8.1.3.v20120522
22 ACTIVE com.ibm.icu.base_4.4.2.v20110831
23 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20120521-2329
24 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20120918-182152
25 ACTIVE org.eclipse.jetty.http_8.1.3.v20120522
26 ACTIVE javax.servlet_3.0.0.v201112011016
27 ACTIVE org.eclipse.jetty.server_8.1.3.v20120522
28 ACTIVE org.eclipse.osgi.services_3.3.100.v20120522-1822
29 ACTIVE org.eclipse.core.jobs_3.5.300.v20120912-155018
30 ACTIVE org.eclipse.core.databinding_1.4.1.v20120912-132807
31 ACTIVE org.eclipse.core.databinding.beans_1.2.200.v20120523-1955
32 ACTIVE org.eclipse.jetty.security_8.1.3.v20120522
33 ACTIVE org.eclipse.jetty.util_8.1.3.v20120522
34 ACTIVE org.eclipse.core.contenttype_3.4.200.v20120523-2004
35 ACTIVE org.eclipse.rap.rwt.osgi_2.0.0.20121031-1050
36 ACTIVE org.eclipse.rap.ui.forms_1.5.100.20121105-1308
37 ACTIVE org.eclipse.equinox.http.registry_1.1.200.v20120912-125810
38 ACTIVE org.eclipse.core.commands_3.6.1.v20120814-150512
39 ACTIVE org.eclipse.core.expressions_3.4.401.v20120912-155018
40 ACTIVE org.eclipse.rap.ui_2.0.0.20121105-1706
41 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20120824-092539
42 ACTIVE org.eclipse.equinox.common_3.6.100.v20120522-1841
43 ACTIVE org.eclipse.rap.jface_2.0.0.20121031-1050
44 ACTIVE org.eclipse.rap.design.example_1.5.100.20121109-0718
osgi>
You can see both my Bundles as ACTIVE (at number 6 and 17 in the above example).
So, why can't my 'rapide' RAP application see the runtimes within gen80rt.jar (in the com.ca.gen80.runtimes Bundle)?
Please help, I'm going headless chicken with this not understanding what I'm missing!
Many thanks, John
| Re: ClassNotFoundException in OSGi but jars included [message #989776 is a reply to message #989723] |
Fri, 07 December 2012 12:07   |
John,
ideally you would create an OSGi bundle from the gen80 library. Google
for "use library jar in osgi" or so and you'll find plenty of advise.
Alternatively you can extend the class-path of the bundle that contains
the gen08 library like so
Bundle-ClassPath: .,ren08rt.jar
and make sure that the library is listed in the build.properties file
like so:
bin.includes = .,META-INF/,gen08rt.jar
As you said that your application runs ok as SWT Standalone, are you
aware that you don't *have* to use OSGi. RWT, the SWT for the web part
of RAP, runs just fine without OSGi. See the FAQ [1] and the developer's
guide [2] for more.
HTH
Rüdiger
[1]
http://wiki.eclipse.org/RAP/FAQ#How_do_I_develop_an_RWT_standalone_application_with_RAP_.3E.3D_1.5
[2] http://eclipse.org/rap/developers-guide
> at java.security.AccessController.doPrivileged(Native Method)
> Caused by:
> Where should I be specifying the gen80rt.jar so that my RAP app can find it at runtime? It is not a Plug-in or a Bundle, just a totally stand-alone JAR file. There doesn't appear to be a concept of a CLASSPATH for RAP applications (apart from the Bundle's Classpath that I've included further down in this post), which sort of makes sense since they have to define precisely what the export and what they import in the manifest, but how to actually reference this JAR?
> I've placed gen80rt.jar into WEB-INF/lib by then way.
> ss
> id State Bundle
> Fragments=7
> Master=0
> osgi>
> org.eclipse.swt,
> org.w3c.dom,
> com.ca.gen80.abrt,
> com.ca.gen80.vwrt,
> Thanks, John
Rüdiger Herrmann
http://codeaffine.com
| Re: ClassNotFoundException in OSGi but jars included [message #990014 is a reply to message #989988] |
Mon, 10 December 2012 08:42   |
Have moved on a little... I got suspicious when it transpired that other classes within that JAR (gen80rt.jar) were being found ok, and realised that ABBase was being loaded via programmatic class loader:
myABClass = myClassLoader.loadClass(className);
So, I modified my ClassLoader to include the gen80rt.jar at runtime, hard-coded for now from a specific path:
try {
myClassLoader.addURL(new URL("file:" + appRoot + "/gen80rt.jar"));
} catch (MalformedURLException e) {
e.printStackTrace();
Great, this gets around that issue, but now I have other unexpected issues with other classes in the jar, not being able to cast them as I did in SWT/RWT:
Caused by:
java.lang.ClassCastException: IET.GDWBLG1_IA cannot be cast to com.ca.gen80.vwrt.IImportView
at iet.co.uk.rapide.RapideInstance.initialisePStep(RapideInstance.java:2331)
at iet.co.uk.rapide.RapideMain.GenGUILoadPStep(RapideMain.java:202)
at iet.co.uk.rapide.RapideMain.start(RapideMain.java:55)
Why is it that I can do this cast successfully in SWT/RWT, but not under RAP?
The actual Classes noted here are not relevant, but I guess I need to understand why the ClassLoader is fussier under RAP compared to SWT/RWT...?
Thanks, John
[Updated on: Mon, 10 December 2012 09:50] by Moderator
| Re: ClassNotFoundException in OSGi but jars included [message #990440 is a reply to message #990179] |
Wed, 12 December 2012 08:56  |
Thanks Cole and Holger,
I'll bookmark that Tabris bootstrapper link for later once we move into Tabris.
The links on Class Loaders were incredibly helpful, and I've restructured my whole approach to doing this now, and happily can report that my app (single-sourced) will run on SWT Standalone, SWT Exported, RWT Standalone, RAP within Eclipse IDE, RAP exported as WAR to JBoss and to WebLogic! Fabulous - this is what this technology is all about!
Here's another link that I found useful too, in describing how Class Loaders work in application servers:
http://www.theserverside.com/news/1364680/Understanding-J2EE-Application-Server-ClassLoading-Architectures#ref
The solution I used for Class Loading is to simply take a note of the Class Loader for the top-level Class in my project, and pass this down the chain, so any Classes loaded on the fly have the same starting point, and therefore the same visibility. Works brilliantly:
Top level Class:
genGUIClassLoader = getClass().getClassLoader();
Then genGUIClassLoader is passed down to any other Classes that need it at runtime, for example:
myABCClass = genGUIClassLoaderForRef.loadClass("my.class.abc");
Very simple - always the best.
Now, I'm not sure if there are any negative implications in the way I've done this, so I'd be interested to hear any further comments, but for now it works exactly the way I need in practise, and across all of the various target platforms, so I'm happy!
Cheers, John
Current Time: Sun Oct 26 09:20:43 EDT 2025
Powered by FUDForum. Page generated in 0.05027 seconds
