Re: Image DPI [message #989568 is a reply to message #989433] |
Thu, 06 December 2012 18:55 |
Take a look at this new and notable features page about the dpi and fit to container settings for images.
New and Notable - Images
As for the fixed layout vs auto layout, are you wanting to know the difference in general or just the effect on images?
Michael
Developer Evangelist, Silanis
Re: Image DPI [message #989813 is a reply to message #989674] |
Sat, 08 December 2012 00:15 |
What is your output and BIRT version? The fit to container, which means grid or table cell, like you're using, seems to only work as expected in PDF. The rest of the time, it just seems to cut the image off.
Michael
Re: Image DPI [message #990326 is a reply to message #990252] |
Tue, 11 December 2012 21:13 |
Set the height of the grid row to 150mm, instead of the entire grid. That should do what you're wanting.
Michael
Re: Image DPI [message #990478 is a reply to message #990407] |
Wed, 12 December 2012 16:15 |
For the first question, I'm not sure why this is ignored. You can log a bug in the bugzilla for this. For the second question, the difference between auto and fixed has to do with page size constraints. Fixed deals with the fixed page size you defined for your masterpage, auto does not.
Michael
FUDForum. Page generated in 0.03684 seconds
