Home » Modeling » ATL » Errors when removing from and adding to the same sequence in refining mode
Errors when removing from and adding to the same sequence in refining mode [message #989274] Wed, 05 December 2012 08:14
I'm refining an ecore model, so that classes will have an additional reference in their structural features and have some of their attributes dropped. The transformation is this:
-- @atlcompiler atl2010
-- @nsURI ECore=http://www.eclipse.org/emf/2002/Ecore
module refactorAuditInfo;
create output: ECore refining input: ECore, additional: ECore;
rule removeAuditInfoFeatures {
	from
		input_name: ECore!EAttribute (
			input_name.isAuditInfoAttribute()
	to
		drop
rule addReferenceToAudit {
	from
		input: ECore!EClass (
			input.eStructuralFeatures -> exists(e | e.isAuditInfoAttribute())
	to
		outputClass: ECore!EClass (
			eStructuralFeatures <- auditInfoReference
		auditInfoReference: ECore!EReference (
			eType <- thisModule.auditClassifier,
			name <- 'audit'
helper def: additionalDbadm: ECore!EPackage =
	ECore!EPackage.allInstances() -> select(e | e.nsURI = 'http://additional.dbadm/1.0').
			first();
helper def: auditClassifier: ECore!EClass =
	thisModule.additionalDbadm.eClassifiers -> select(e | e.name = 'Audit').first();
helper context ECore!EStructuralFeature def: isAuditInfoAttribute(): Boolean =
	false;
helper context ECore!EAttribute def: isAuditInfoAttribute(): Boolean =
	Sequence{'beDat',
				'beUser',
				'beRolle'} -> includes(self.name);
When I run the transformation, I get
org.eclipse.m2m.atl.engine.vm.VMException: Feature sourceElement does not exist on MOF!EAttribute
	at A.__applyRefiningTrace__() : ??#58(refactorAuditInfo.atl)
		local variables = {self=refactorAuditInfo : ASMModule}
		local stack = [refiningTrace!<unnamed>]
The problem has something to do with the drop of some of the features. However, I have no idea what I must do about it.
I already read this topic, which describes a similar problem. But as far as I understand I should already have followed the advice made their.
Does anybody has some advice for me to solve that problem? Thanks.
EDIT:
The above error message was with the regular VM. When I change to the EMF-specific VM, then I get:
org.eclipse.m2m.atl.engine.emfvm.VMException
	at __applyRefiningTrace__#47(refactorAuditInfo.atl)
		local variables: self=refactorAuditInfo : ASMModule
	at main#79(refactorAuditInfo.atl)
Java Stack:
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:643)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
	at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
	at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
	at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:234)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
	at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.ArrayIndexOutOfBoundsException
Sadly, I don't see the trace where the ArrayIndexOutOfBoundsException comes from.
EDIT2:
The ArrayIndexOutOfBoundsException comes from the fact that the stack size is limited to 100 in the EMF-specific VM. I detected this by enabling the option Print execution information to console for every executed bytecode. The last output of that before the error had a stack depth of 100.
EDIT3:
I also get that error with a reduced transformation on the regular VM. Then it looks like this:
create output: ECore refining input: ECore;
	from
	to
		drop
	Sequence{'beDat',
				'beUser',
However when I use the EMF-specific VM, the transformation runs through. That means I'm stuck between two errors. Either the regular VM is failing because of the said error or the EMF-specific VM is failing because of its limited stack size.
As a workaround I'm going to split this up into two transformations that will run subsequently.
[Updated on: Wed, 05 December 2012 10:11] by Moderator
Previous Topic:NoSuchElementException when appending refining trace to sequence
Next Topic:ATL to ATL Refining Mode
Current Time: Thu Jul 03 05:23:06 EDT 2025
Powered by FUDForum. Page generated in 0.04807 seconds
