Home » Modeling » ATL » NoSuchElementException when appending refining trace to sequence
NoSuchElementException when appending refining trace to sequence [message #989204] |
Wed, 05 December 2012 08:47 |
Andreas Brieg Messages: 48 Registered: November 2012 |
Member |
I have an ecore model where a lot of classes have 3 attributes for audit information. I want to replace these 3 attributes with a reference to a class that contains all those attributes. That class is contained in another ecore model.
Therefore I wrote the following transformation:
-- @atlcompiler atl2010
-- @nsURI ECore=http://www.eclipse.org/emf/2002/Ecore
module refactorAuditInfo;
create output: ECore refining input: ECore, additional: ECore;
rule addReferenceToAudit {
from
input : ECore!EClass (
input.eStructuralFeatures -> exists(e | e.isAuditInfoFeature())
to
auditInfoReference : ECore!EReference (
eContainingClass <- input,
eType <- input.refImmediateComposite().auditClassifier(),
name <- 'audit',
eReferenceType <- input.refImmediateComposite().auditClassifier().debug()
outputClass : ECore!EClass (
eStructuralFeatures <- input.eStructuralFeatures.append(auditInfoReference.debug())
helper context ECore!EPackage def : auditClassifier() : OclAny =
thisModule.additionalDbadm.eClassifiers -> select(e | e.name = 'Audit').first();
helper def : additionalDbadm : ECore!EPackage =
ECore!EPackage.allInstances()->select(e | e.nsURI = 'http://additional.dbadm/1.0').first();
helper context ECore!EStructuralFeature def : isAuditInfoFeature() : Boolean =
Sequence{'beDat', 'beUser', 'beRolle'}.contains(self.name);
However I get a NoSuchElementException when I execute that transformation. The output is:
additional!Audit
refiningTrace!<unnamed>
org.eclipse.m2m.atl.engine.emfvm.VMException
at __resolve__#13(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, value=input!beDat
at __resolve__#26(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, value=Sequence {input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, input!***, refiningTrace!<unnamed>}, e=input!beDat
at __applyaddReferenceToAudit#56(refactorAuditInfo.atl[30:7-30:90])
local variables: self=refactorAuditInfo : ASMModule, link=TransientLink {rule = addReferenceToAudit, sourceElements = {input = org.eclipse.emf.ecore.impl.EClassImpl@209933c3 (name: ***) (instanceClassName: null) (abstract: false, interface: false)}, targetElements = {auditInfoReference = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@483d42d (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false)), outputClass = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6aded8ab (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, input=input!***, auditInfoReference=refiningTrace!<unnamed>, outputClass=refiningTrace!<unnamed>
at __exec__#18(refactorAuditInfo.atl)
local variables: self=refactorAuditInfo : ASMModule, e=TransientLink {rule = addReferenceToAudit, sourceElements = {input = org.eclipse.emf.ecore.impl.EClassImpl@209933c3 (name: ***) (instanceClassName: null) (abstract: false, interface: false)}, targetElements = {auditInfoReference = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@483d42d (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false)), outputClass = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@6aded8ab (eClass: org.eclipse.emf.ecore.impl.EClassImpl@56cb4b5d (name: Element) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#57(refactorAuditInfo.atl)
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:643)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:388)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:234)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.util.NoSuchElementException
at java.util.ArrayList$Itr.next(Unknown Source)
at org.eclipse.m2m.atl.engine.emfvm.lib.ExecEnv$173.exec(ExecEnv.java:1683)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:391)
... 15 more
The NoSuchElementException is raised during execution of the line
Note that the line information of the ATL stack is not matching the correct line in the above ATL transformation, because I left out some other stuff.
I'm using Juno with ATL 3.3.1. Does anyone know, why this exception is raised and what I'm doing wrong? Thanks
[Updated on: Wed, 05 December 2012 08:49] Report message to a moderator
Current Time: Fri Sep 20 08:23:16 GMT 2024
Powered by FUDForum. Page generated in 0.04137 seconds
