Home » Archived » Buckminster » The import org.eclipse.swt cannot be resolved
The import org.eclipse.swt cannot be resolved [message #988987] Tue, 04 December 2012 02:43 Go to next message
Since November 28 our Hudson (linux) build keeps failing because SWT can not be resolved:
https://hudson.eclipse.org/hudson/job/emf-cdo-integration
The target platform only contains a org.eclipse.swt.win32.win32.x86_64_3.8.1.v3834e.jar
<https://hudson.eclipse.org/hudson/job/emf-cdo-integration/ws/result/tp/plugins/org.eclipse.swt.win32.win32.x86_64_3.8.1.v3834e.jar>
fragment: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/ws/result/tp/plugins
That might explain why the build works at home on Windows. But where have the other platform fragments gone? Any ideas?
Cheers
/Eike
http://www.esc-net.de
Re: The import org.eclipse.swt cannot be resolved [message #989019 is a reply to message #988987] Tue, 04 December 2012 05:38 Go to previous messageGo to next message
On 12/04/2012 08:43 AM, Eike Stepper wrote:
> not be resolved: https://hudson.eclipse.org/hudson/job/emf-cdo-integration
> fragment:
for curiosity (I'm recently taking a look at projects which use
buckminster to get inspiration ;) I took a look here
http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.releng/build.cquery
I don't know if that is the cause, but you skip some gtk components from
swt and equinox ...
sorry if I said something stupid :)
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: The import org.eclipse.swt cannot be resolved [message #989114 is a reply to message #989019] Tue, 04 December 2012 11:40 Go to previous messageGo to next message
Am 04.12.2012 11:38, schrieb Lorenzo Bettini:
>> fragment:
> Hi
> swt and equinox ...
Hmm, it doesn't look like the cause to me. I'm only excluding source components and fragments for unneeded platforms.
And I've not touched that file for ages. Nevertheless I'm trying a build with those lines commented out...
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989248 is a reply to message #989114] Wed, 05 December 2012 05:53 Go to previous messageGo to next message
>>> Hi,
>>> not be resolved:
>>> fragment:
>> Hi
>> swt and equinox ...
> components and fragments for unneeded platforms. And I've not touched
> commented out...
The error seems different now... it looks like it can't find
javax.annotations...
https://hudson.eclipse.org/hudson/job/emf-cdo-integration/2554/console
Re: The import org.eclipse.swt cannot be resolved [message #989312 is a reply to message #989248] Wed, 05 December 2012 10:51 Go to previous messageGo to next message
Am 05.12.2012 11:53, schrieb Lorenzo Bettini:
> The error seems different now... it looks like it can't find javax.annotations...
Yeah, that was an attempt to use fixed os/ws/arch parameters. It obviously failed. And it couldn't be an end solution
because our build used to produce example products for multiple platforms ;-(
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989359 is a reply to message #989312] Wed, 05 December 2012 15:12 Go to previous messageGo to next message
> obviously failed. And it couldn't be an end solution because our build
But you don't use
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
in your cquery, do you?
probably it's in a properties file, I guess...
I don't know whether your problem is related to this, but on 28
November, Thomas released a fix for this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395070
and it looks like your job stopped working on that date...
but I don't know the internal details, Thomas will have to say something :)
cheers
Lorenzo
Re: The import org.eclipse.swt cannot be resolved [message #989404 is a reply to message #989359] Thu, 06 December 2012 01:07 Go to previous messageGo to next message
Am 05.12.2012 21:12, schrieb Lorenzo Bettini:
> But you don't use
Hmm, strange. I have those in my build.mspec:
<mspec:property key="target.os" value="*"/>
<mspec:property key="target.ws" value="*"/>
<mspec:property key="target.arch" value="*"/>
Plus I have them in my build.properties:
target.os=*
target.ws=*
target.arch=*
Thomas, can you please explain where these settings are all needed or where I can read about that?
I already tried to use the previous build from http://archive.eclipse.org/tools/buckminster/archivedsites-4.2 - To no
effect. Maybe I've done soemthing wrong and instead still used the newest build. I thought I compared the versions
during the tool installation.
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989414 is a reply to message #989359] Thu, 06 December 2012 02:14 Go to previous messageGo to next message
> But you don't use
Lorenzo, you saved my entire week ;-)
I added the <cq:property> lines and in fact the build succeeds again!!!
You're the greatest. I'd never have expected that I must specify this in a third place. Thank you again.
It strikes me that the redundant (3 times) definition is not ideal. I'd still like to learn about what impact these
properties have depending on where they're specified...
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989424 is a reply to message #989414] Thu, 06 December 2012 03:00 Go to previous messageGo to next message
>> But you don't use
You shouldn't need to provided that they are passed in as properties on
the command line.
> still like to learn about what impact these properties have depending on
One time should be enough. The properties passed on the command line are
merged with the ones from the cquery and the rmap. The mspec ones should
be passed to unless you first resolve using the cquery and then, as a
separate step perform the materialization using your mspec and a bom file.
So questions:
1. How is Buckminster made aware of your build.properties settings?
2. What command or commands are used for resolving and materializing?
3. Did any of this change recently? What happened on November 28?
- thomas
Re: The import org.eclipse.swt cannot be resolved [message #989435 is a reply to message #989424] Thu, 06 December 2012 03:42 Go to previous messageGo to next message
Am 06.12.2012 09:00, schrieb Thomas Hallgren:
>>> But you don't use
> You shouldn't need to provided that they are passed in as properties on the command line.
> One time should be enough. The properties passed on the command line are merged with the ones from the cquery and the
> rmap. The mspec ones should be passed to unless you first resolve using the cquery and then, as a separate step
> So questions:
All this has initially been set up by you and Mikael. I think it is like this:
1. the build.xml imports build.properties.
2. then it echoes all properties to a variable (properties.tmp)
3. in the bucky call they're passed like this:
<arg value="@{command}" />
<arg value="-P" />
<arg value="${properties.tmp}" />
<cmdargs />
<buckminster command="import">
<cmdargs>
<arg value="-B" />
<arg value="${hudson.WORKSPACE}/bom.xml" />
<arg value="-P" />
<arg value="${basedir}/build.properties" />
<!-- Last argument: -->
<arg value="${basedir}/build.mspec" />
</cmdargs>
</buckminster>
No, the last commit to our maintenance branch was almost exactly 1 month *before* the failures started (Nov. 28).
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989442 is a reply to message #989435] Thu, 06 December 2012 04:14 Go to previous messageGo to next message
This issue really displays all the traits of a regression in the build
system. You tested with:
org.eclipse.buckminster.site.eclipse.headless_1.5.0.v20121118-2330.zip
and that displayed the same problems. Are you sure that this is the one
that your build was using previously? I guess the answer is yes, you
always pick the latest from our headless site. But just to be sure,
could you try with the version before that, i.e.
http://www.eclipse.org/downloads/download.php?file=/tools/buckminster/archivedsites-4.2/org.eclipse.buckminster.site.eclipse.headless_1.5.0.v20121007-1625.zip
or if there's a chance to set up a sandbox where I could try and save
you the time of doing it, that would be fine too. It just seems so odd
that your build suddenly require parameters that it didn't use to have
even though nothing changed.
- thomas
Re: The import org.eclipse.swt cannot be resolved [message #989466 is a reply to message #989442] Thu, 06 December 2012 05:36 Go to previous messageGo to next message
Am 06.12.2012 10:14, schrieb Thomas Hallgren:
> This issue really displays all the traits of a regression in the build system. You tested with:
> and that displayed the same problems. Are you sure that this is the one that your build was using previously? I guess
> the answer is yes, you always pick the latest from our headless site. But just to be sure, could you try with the
Wow, with that version it works, too: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/2565/console
Cheers
/Eike
> or if there's a chance to set up a sandbox where I could try and save you the time of doing it, that would be fine
> too. It just seems so odd that your build suddenly require parameters that it didn't use to have even though nothing
> changed.
> - thomas
Re: The import org.eclipse.swt cannot be resolved [message #989472 is a reply to message #989466] Thu, 06 December 2012 06:07 Go to previous messageGo to next message
>> one that your build was using previously? I guess the answer is yes,
>> sure, could you try with the version before that, i.e.
OK. So that suggests a regression between our 20121007 and 20121118
versions that somehow affects how properties are passed from the mspec
during import. I'll investigate that.
Thanks a lot for investing time helping with this Eike. It would be hard
to track things down if you didn't.
- thomas
Re: The import org.eclipse.swt cannot be resolved [message #989482 is a reply to message #989472] Thu, 06 December 2012 07:28 Go to previous messageGo to next message
Am 06.12.2012 12:07, schrieb Thomas Hallgren:
> OK. So that suggests a regression between our 20121007 and 20121118 versions that somehow affects how properties are
> passed from the mspec during import. I'll investigate that.
> Thanks a lot for investing time helping with this Eike. It would be hard to track things down if you didn't.
> - thomas
Re: The import org.eclipse.swt cannot be resolved [message #989483 is a reply to message #989482] Thu, 06 December 2012 07:29 Go to previous messageGo to next message
Am 06.12.2012 13:28, schrieb Eike Stepper:
>> - thomas
Hmm, what did I want to say?! You're welcome :P
Cheers
/Eike
Re: The import org.eclipse.swt cannot be resolved [message #989735 is a reply to message #989424] Fri, 07 December 2012 08:12 Go to previous message
Hi Thomas
concerning the merging of properties I noted a behavior which I do not
know whether it's the one expected: I've set up for one of my projects a
cquery to materialize all the projects in the workspace
http://emf-components.eclipselabs.org.codespot.com/git/releng/it.rcpvision.emf.components.buckminster/remote/web-build.cquery
the URL is thought to be opened in the IDE and it clones the git repo,
materialize target platform and all projects in the workspace.
In the rmap I have some properties, like git.clone.dest, that I can
redefine, for instance, in a Jenkins job when calling buckminster
headlessly. The default value for such properties is in the rmap.
Everything works.
Now, if I try to put a default value for these properties in the cquery,
then the values passed on the command line are ignored...
is it the expected behavior (it's not a problem for my context)?
Otherwise it might be somehow related to Eike's problem?
cheers
Lorenzo
Previous Topic:Buckminster calling product.ant (from example)
Next Topic:equinox repository prefs are not installed
Current Time: Wed Sep 24 19:17:00 EDT 2025
Powered by FUDForum. Page generated in 0.05553 seconds
