Home » Archived » Buckminster » Buckminster calling product.ant (from example)(Error while creating the plugin)
Buckminster calling product.ant (from example) [message #988919] Mon, 03 December 2012 12:26 Go to next message
Hello Buckyers,
I am trying, as you can see from other posts, to headlessly materialize one plugin in a p2 website, given a custom Target Platform.
I had to go trough a lot of different problems, partly because I am a Buckminster newbie, but I am probably close to the solution.
Now, the command that fails now is:
buckminster -L DEBUG perform com.myproduct.customization#create.product
The command is basically a replica of the Buckminster Releng example, where the build/ folder contains the product.ant file (unchanged).
The error I get is the following:
[ant] C:\buckminster\plugins\org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
[ant] file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.myproduct.customization_1.3.0-eclipse.feature/site.p2/
[ant] C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.myproduct.customization_1.3.0-eclipse.feature\custom
ERROR: org.eclipse.core.runtime.CoreException: C:\Users\arichiardi\workspace\features\com.myproduct.customization\build\product.ant:22: Java returned: 13
        at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
        at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
        at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
        at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
        at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
        at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
        at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
        at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
        at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
        at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
        at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
        at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:350)
        at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:145)
        at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:165)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: C:\Users\arichiardi\workspace\features\com.myproduct.customization\build\product.ant:22: Java returned: 13
        at org.apache.tools.ant.taskdefs.Java.execute(Java.java:111)
        at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
        at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
        at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
        at org.apache.tools.ant.Task.perform(Task.java:348)
        at org.apache.tools.ant.Target.execute(Target.java:392)
        at org.apache.tools.ant.Target.performTasks(Target.java:413)
        at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
        at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
        at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
        at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
        at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
        at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
        at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
        at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
        ... 25 more
Doing full workspace refresh
Waiting for jobs to end
Caused by:
The last "Caused by:" is empty, but you can see that it fails at line 22 of the ant script, which is:
<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
Again, I am headless here...why is it failing on that line?
Thank you very much! Smile
Andrea.
[Updated on: Mon, 03 December 2012 12:28] by Moderator
Re: Buckminster calling product.ant (from example) [message #988980 is a reply to message #988919] Tue, 04 December 2012 02:12 Go to previous messageGo to next message
Hi Andrea,
Not sure what's going on here. Can you please turn ant-debugging on an
try again?
buckminster -L ant=DEBUG,console=DEBUG perform
- thomas
On 2012-12-03 18:26, Andrea Richiardi wrote:
> Hello Buckyers,
> [ant]
> [ant]
> file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.biomet.rac.customization_8000.3.0-eclipse.feature/site.p2/
> [ant]
> C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.biomet.rac.customization_8000.3.0-eclipse.feature\custom
> C:\Users\arichiardi\workspace\features\com.biomet.rac.customization\build\product.ant:22:
> Java returned: 13
> Java returned: 13
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Caused by:
> Java returned: 13
> at
> at
> at
> at
> at
> at
> at
> ... 25 more
> Java returned: 13
> Caused by:
> Thank you very much! :) Andrea.
Re: Buckminster calling product.ant (from example) [message #989016 is a reply to message #988919] Tue, 04 December 2012 05:31 Go to previous messageGo to next message
Usually, when you get Java error 13 during creating a product it's
because, during p2 installation of your product, some bundles are
missing in the created p2 site (the one created by p2.site action and
that is used by p2 director to build your product)... if you enable
further debugging info as Thomas suggested you should get more
information, and then searching for 'requires' should show you what
requires what...
hope this helps
Lorenzo
On 12/03/2012 06:26 PM, Andrea Richiardi wrote:
> Hello Buckyers,
> [ant]
> [ant]
> [ant]
> Java returned: 13
> Java returned: 13
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> Java returned: 13
> at
> at
> at
> at
> at
> at
> at
> ... 25 more
> Java returned: 13
> Caused by:
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Buckminster calling product.ant (from example) [message #989330 is a reply to message #988980] Wed, 05 December 2012 11:30 Go to previous messageGo to next message
Thomas Hallgren wrote on Tue, 04 December 2012 02:12
Hi Andrea,
try again?
- thomas
> Hello Buckyers,
> Thank you very much! Smile Andrea.
I receive:
org.eclipse.buckminster.cmdline.parser.InvalidOptionValueException: The value for option 'L' is invalid:ant
A problem in my buckminster version? I am using 4.2 headless.
[Updated on: Wed, 05 December 2012 12:46] by Moderator
Re: Buckminster calling product.ant (from example) [message #989425 is a reply to message #989330] Thu, 06 December 2012 03:03 Go to previous messageGo to next message
>> Hi Andrea,
>> try again?
>> - thomas
>> > Hello Buckyers,
> I receive:
If you are on Windows (where the command line interpreter splits
arguments on both white space and '=') you'll need to quote the argument
passed to the -L option:
buckminster -L "ant=DEBUG,console=DEBUG" perform
No, this functionality has been present for some time now.
- thomas
Re: Buckminster calling product.ant (from example) [message #989583 is a reply to message #989425] Thu, 06 December 2012 15:32 Go to previous message
Ah ah, ok sorry about that, I didn't know it Smile
Ok, basically here is the content of the log file in buckminster/configuration:
Command-line arguments:  -application org.eclipse.equinox.p2.director -repository file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.myproduct.customization_1.3.0-eclipse.feature/site.p2/ -destination C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.myproduct.customization_1.3.0-eclipse.feature\custom -profile MyProfile -profileProperties org.eclipse.update.install.features=true -installIU com.myproduct.customization -p2.os win32 -p2.ws win32 -p2.arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.p2.director.app 4 0 2012-12-06 15:12:03.341
!MESSAGE The installable unit com.myproduct.customization has not been found.
That matches the following excerpt of the buckminster output.
[ant]
[ant] The ' characters around the executable and arguments are
[ant] not part of the command.
[ant] Execute:Java13CommandLauncher: Executing 'C:\Program Files\Java\jre6\bin\java.exe' with arguments:
[ant] '-jar'
[ant] 'C:\buckminster\plugins\org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar'
[ant] '-application'
[ant] 'org.eclipse.equinox.p2.director'
[ant] '-repository'
[ant] 'file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.myproduct.customization_1.3.0-eclipse.feature/site.p2/'
[ant] '-destination'
[ant] 'C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.myproduct.customization_1.3.0-eclipse.feature\custom'
[ant] '-profile'
[ant] 'BiometProfile'
[ant] '-profileProperties'
[ant] 'org.eclipse.update.install.features=true'
[ant] '-installIU'
[ant] 'com.myproduct.customization'
[ant] '-p2.os'
[ant] 'win32'
[ant] '-p2.ws'
[ant] 'win32'
[ant] '-p2.arch'
[ant] 'x86_64'
[ant] '-consoleLog'
[ant]
[ant] The installable unit com.myproduct.customization has not been found.
[ant] Application failed, log file location: C:\buckminster\configuration\1354824722519.log
[ant] Installation failed.
[ant] !SESSION 2012-12-06 15:12:02.305 -----------------------------------------------
[ant] eclipse.buildId=unknown
[ant] java.version=1.6.0_30
[ant] java.vendor=Sun Microsystems Inc.
[ant] BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
[ant] Framework arguments:  -application org.eclipse.equinox.p2.director -repository file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.myproduct.customization_1.3.0-eclipse.feature/site.p2/ -destination C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.myproduct.customization_1.3.0-eclipse.feature\custom -profile BiometProfile -profileProperties org.eclipse.update.install.features=true -installIU com.myproduct.customization -p2.os win32 -p2.ws win32 -p2.arch x86_64
[ant] Command-line arguments:  -application org.eclipse.equinox.p2.director -repository file:/C:/Users/ARICHI~1/AppData/Local/Temp/buckminster/build/com.myproduct.customization_1.3.0-eclipse.feature/site.p2/ -destination C:\Users\ARICHI~1\AppData\Local\Temp\buckminster\build\com.myproduct.customization_1.3.0-eclipse.feature\custom -profile MyProfile -profileProperties org.eclipse.update.install.features=true -installIU com.myproduct.customization -p2.os win32 -p2.ws win32 -p2.arch x86_64 -consoleLog
[ant]
[ant] !ENTRY org.eclipse.equinox.p2.director.app 4 0 2012-12-06 15:12:03.341
[ant] !MESSAGE The installable unit com.myproduct.customization has not been found.
[ant]
The fact is that com.myproduct.customization is the container which includes the actual plugin I want to generate. Another thing that I notice here is that he asks for x86_64 architecture (I am running buckminster from a Windows 64 machine). But nowhere else I declare that I want a x86_64 product to be built...
Previous Topic:cannot skip components during materialization
Next Topic:The import org.eclipse.swt cannot be resolved
Current Time: Mon Jul 07 08:31:09 EDT 2025
Powered by FUDForum. Page generated in 0.03846 seconds
