Home » Newcomers » Newcomers » how to run different classes ?
how to run different classes ? [message #988903] Mon, 03 December 2012 11:16 Go to next message
I want to work on my different class lets say for example house.java but the green play button seems to be locked a program called project.java and only that program. how do I tell Eclipse to run a different classes in the same folder besides the project.java?i have an applet and i tried running it...but eclipse loads project.java every time....
Re: how to run different classes ? [message #988915 is a reply to message #988903] Mon, 03 December 2012 11:35 Go to previous messageGo to next message
You would benefit from following one or two tutorials on using Eclipse.
I would suggest the first three from
http://www.vogella.com/eclipseide.html .
Hope this helps.
Re: how to run different classes ? [message #1711530 is a reply to message #988915] Fri, 16 October 2015 13:01 Go to previous messageGo to next message
have main method to tell eclipse to start excecution
Re: how to run different classes ? [message #1711795 is a reply to message #1711530] Mon, 19 October 2015 13:43 Go to previous message
See https://www.eclipse.org/forums/index.php?t=msg&th=1070583&goto=1709296&#msg_1709296
Previous Topic:How to configure ANDROID_HOME= on linux mint
Next Topic:How can I enlarge the font in the Problems Tab?
Current Time: Mon May 19 15:26:58 EDT 2025
Powered by FUDForum. Page generated in 0.08540 seconds
