Home » Eclipse Projects » Remote Application Platform (RAP) » Missing SWT Image Constants
Missing SWT Image Constants [message #988899] Mon, 03 December 2012 10:48 Go to next message
I am trying to create a grayed (or disabled) version of an SWT image as described in [1] under "Image Effects":
Image grayImage = new Image(display,image,SWT.IMAGE_GRAY);
However, neither the SWT.IMAGE_GRAY nor the SWT.IMAGE_DISABLE constants seem to be available in RAP 1.5.
Any suggestions on how to achieve this in RAP?
I know it is possible somehow because disabling a button that has an associated image does gray out/disable that image.
Franz-Stefan
[1] http://www.eclipse.org/articles/Article-SWT-images/graphics-resources.html
(I use the SWT class from org.eclipse.rap.rwt-1.5.1.20120917-1116.jar).
Re: Missing SWT Image Constants [message #989222 is a reply to message #988899] Wed, 05 December 2012 04:41 Go to previous message
Hi Franz-Stefan,
There is an open feature request for this: [1]. However, it's not a
straight forward implementation, because SWT uses native libraries to
transform images, which we can't do in RAP. I guess the simplest
solution is to create and register grayed images on your own.
Alternatively, you can use some third-party library to process images at
runtime.
Disabling a button does not change the actual image in RAP.
Regards, Ralf
[1] 317439: Support for IMAGE_GRAY and IMAGE_DISABLE
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317439
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:Theme lost after refresh
Next Topic:TableColumn and Table Fonts
Current Time: Tue Nov 04 01:03:14 EST 2025
Powered by FUDForum. Page generated in 0.03627 seconds
