Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EmfStore] Commit observe on server
[EmfStore] Commit observe on server [message #988785] Mon, 03 December 2012 03:10 Go to next message
Maybe it's a simple question..
How observe commit on server side? I find solution only on client side by extension org.eclipse.emf.emfstore.client.commitObserver
Thanks.
Dmitriy.
Re: [EmfStore] Commit observe on server [message #989038 is a reply to message #988785] Tue, 04 December 2012 06:39 Go to previous messageGo to next message
Hi Dmitriy,
Unfortunately we do not provide a server based callback interface
anymore. We did in the past and you may find these plugins in the
emfstore.other repository (they are called backchannel plugins),
but the API these plugins depend on has been marked as deprecated.
As an alternative solution to your problem you can register adapters on
the EMF server model, e.g. by adding
EAdapters to the ProjectHistory instances. Please find attached some
example code that gets called for all existing projects when a commit
has been registered via the versions property of the ProjectHistory
class (this goes into the EMFStoreController's run(boolean) method)
after initServerSpace() has completed:
for (final ProjectHistory history : serverSpace.getProjects()) {
history.eAdapters().add(new AdapterImpl() {
public void notifyChanged(Notification msg) {
if
(msg.getFeature().equals(ModelPackage.eINSTANCE.getProjectHistory_Versions()))
Version newVersion = (Version) msg.getNewValue();
System.out.println("New version " +
newVersion.getPrimarySpec().getIdentifier()
+ " for project " + history.getProjectName() + " committed.");
If the proposed solution above does not fit your needs, we are happy to
provide a dedicated API with one of the next nightly builds. In this
case it would be helpful if you could explain your requirements in more
detail.
Maximilian
Am 03.12.2012 09:10, schrieb Dmitriy Shishkin:
> Thanks.
> Dmitriy.
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EmfStore] Commit observe on server [message #989256 is a reply to message #989038] Wed, 05 December 2012 06:26 Go to previous messageGo to next message
Hi Maximilian,
Thanks for detailed answer.
I think it is suitable solution for my task. The point is that we need some codegeneration for our domain model. As model live in EmfStore then codegenration should occur on server side at the same time with commit
Dmitriy
Re: [EmfStore] Commit observe on server [message #989268 is a reply to message #989256] Wed, 05 December 2012 07:31 Go to previous messageGo to next message
Hi Dmitriy,
OK, let me know if it works out for you!
Maximilian
Am 05.12.2012 12:26, schrieb Dmitriy Shishkin:
> Hi Maximilian,
> Dmitriy
Maximilian Kögel
Re: [EmfStore] Commit observe on server [message #1371618 is a reply to message #989268] Wed, 21 May 2014 09:06 Go to previous messageGo to next message
I tried the solution for the commit notifications and I am getting
Nullpointer Exceptions when I try to delete projects on the server.
It seems to be connected to the Adapters which are created for the
notifications.
Is there a way to get this working properly? I already tried deleting
the Adapter before the project itself is being deleted in the
deleteProject method in class
org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl
but without any luck.
Kristof
Re: [EmfStore] Commit observe on server [message #1376406 is a reply to message #1371618] Fri, 23 May 2014 07:54 Go to previous messageGo to next message
could you post the stacktrace, please.
Maximilian
Am 21.05.2014 15:06, schrieb Zalecki, Kristof:
> notifications.
> Kristof
Maximilian Kögel
Re: [EmfStore] Commit observe on server [message #1385417 is a reply to message #1376406] Fri, 06 June 2014 05:59 Go to previous messageGo to next message
sorry for the late answer. I already found the solution. At deletion of
a project the notification needs to be disabled first. I added a few
lines to the method deleteProject() in class
which now looks like this:
public void deleteProject(SessionId sessionId, ProjectId projectId,
boolean deleteFiles) throws ESException {
eMFStoreControllerInstance.getServerSpace().getProjects())
if (history.getProjectId().getId().equals(projectId.getId()))
// the notifier needs to be disabled for the deletion of the
// project to avoid NullPointerExceptions
history.eAdapters().get(0).getTarget().eSetDeliver(false);
getEmfStore().deleteProject(sessionId, projectId, deleteFiles);
Kristof
Am 23.05.2014 13:54, schrieb Maximilian Koegel:
> Cheers,
> Maximilian
>> notifications.
>> Regards,
>> Kristof
Re: [EmfStore] Commit observe on server [message #1385866 is a reply to message #1385417] Wed, 11 June 2014 14:32 Go to previous messageGo to next message
Hi Kristof,
I tested this myself and I didn't have any issues so far.
Do you have any customizations of your own registered at the server?
If so, would you mind sharing a stacktrace or a minimal test case with
us, such that we can reproduce the issue?
Also, can you tell us which adapter is returned for
history.eAdapters().get(0) and which target it is pointing to?
Edgar
Am 06.06.2014 11:59, schrieb Zalecki, Kristof:
> the
> Kristof
>> Cheers,
>> Maximilian
>>> Hi,
>>> notifications.
>>> Regards,
>>> Kristof
Edgar Mueller
Re: [EmfStore] Commit observe on server [message #1386438 is a reply to message #1385866] Tue, 17 June 2014 10:28 Go to previous message
Hi Edgar,
In the attachement there are two text files containing the stack traces
from my client and from my server. The only changes I have made on
server side are the mentioned Adapters, which i added to the server
start as your example showed and also to the createProject() and
createEmptyProject() in class
in order to create them at creation of projects.
The problem occurs after committing a project containing changes, which
then of course invokes the notification mechanism. After that I try to
delete the project on the server and I get the NullPointerException.
When trying to delete the project a second time it works.
I am also using Version 1.1 of EMFStore so maybe this problem fixed
itself on the way.
Kristof
Am 11.06.2014 20:32, schrieb Edgar Mueller:
> Hi Kristof,
> Cheers,
> Edgar
>> the
>> Regards,
>> Kristof
>>> Hi,
>>> Cheers,
>>> Maximilian
>>>> Hi,
>>>> notifications.
>>>> Regards,
>>>> Kristof
!ENTRY org.eclipse.emf.emfstore.client 4 4 2014-06-17 16:11:50.268
!MESSAGE org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
!STACK 0
java.util.concurrent.ExecutionException: org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:232)
at java.util.concurrent.FutureTask.get(FutureTask.java:91)
at org.eclipse.emf.emfstore.internal.client.common.UnknownEMFStoreWorkloadCommand.execute(UnknownEMFStoreWorkloadCommand.java:83)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$14.run(ESRemoteProjectImpl.java:518)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$14.run(ESRemoteProjectImpl.java:1)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.run(ServerCall.java:249)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.executeCall(SessionManager.java:120)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.SessionManager.execute(SessionManager.java:61)
at org.eclipse.emf.emfstore.internal.client.model.connectionmanager.ServerCall.execute(ServerCall.java:269)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:482)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl$13.call(ESRemoteProjectImpl.java:1)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException$2.doRun(RunESCommand.java:102)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack$1.doExecute(EMFStoreTransactionalCommandStack.java:61)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.basicExecute(EMFStoreTransactionalCommandStack.java:163)
at org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
at org.eclipse.emf.emfstore.internal.client.transaction.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
at org.eclipse.emf.emfstore.client.util.RunESCommand$WithException.run(RunESCommand.java:117)
at org.eclipse.emf.emfstore.internal.client.model.impl.api.ESRemoteProjectImpl.delete(ESRemoteProjectImpl.java:477)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.deleteRemoteProject(UIDeleteRemoteProjectController.java:149)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.doRun(UIDeleteRemoteProjectController.java:110)
at org.eclipse.emf.emfstore.internal.client.ui.controller.UIDeleteRemoteProjectController.doRun(UIDeleteRemoteProjectController.java:1)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction$1.run(MonitoredEMFStoreAction.java:70)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1162)
at org.eclipse.emf.emfstore.internal.client.ui.common.MonitoredEMFStoreAction.execute(MonitoredEMFStoreAction.java:67)
at org.eclipse.emf.ecp.emfstore.internal.ui.handler.DeleteOnServerHandler.execute(DeleteOnServerHandler.java:50)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:814)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:707)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:691)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:630)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.emf.ecp.application3x.Application.start(Application.java:30)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.emf.emfstore.server.exceptions.ESException: java.lang.NullPointerException
at org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:152)
at org.eclipse.emf.emfstore.internal.server.core.EMFStoreImpl.invoke(EMFStoreImpl.java:158)
at $Proxy4.deleteProject(Unknown Source)
at org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl.deleteProject(XmlRpcEmfStoreImpl.java:193)
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:115)
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.execute(ReflectiveXmlRpcHandler.java:106)
at org.apache.xmlrpc.server.XmlRpcServerWorker.execute(XmlRpcServerWorker.java:46)
at org.apache.xmlrpc.server.XmlRpcServer.execute(XmlRpcServer.java:86)
at org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:200)
at org.apache.xmlrpc.webserver.Connection.run(Connection.java:208)
at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
Caused by: java.lang.NullPointerException
at org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl$1.notifyChanged(XmlRpcEmfStoreImpl.java:122)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.didRemove(BasicNotifierImpl.java:146)
at org.eclipse.emf.common.util.AbstractEList.didClear(AbstractEList.java:166)
at org.eclipse.emf.common.util.BasicEList.clear(BasicEList.java:640)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl$EAdapterList.clear(BasicNotifierImpl.java:235)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unloaded(ResourceImpl.java:1576)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doUnload(ResourceImpl.java:1635)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doUnload(XMLResourceImpl.java:631)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unload(ResourceImpl.java:1650)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.delete(ResourceImpl.java:1667)
at org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.deleteProject(ProjectSubInterfaceImpl.java:302)
at org.eclipse.emf.emfstore.internal.server.core.subinterfaces.ProjectSubInterfaceImpl.deleteProject(ProjectSubInterfaceImpl.java:263)
at org.eclipse.emf.emfstore.internal.server.core.AbstractSubEmfstoreInterface.execute(AbstractSubEmfstoreInterface.java:140)
... 14 more!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-17 16:11:50.249
!MESSAGE Exception on execution: java.lang.reflect.InvocationTargetException
... 19 more
... 19 more
17.06.2014 16:11:50 org.apache.xmlrpc.server.XmlRpcErrorLogger log
SCHWERWIEGEND: Failed to invoke method deleteProject in class org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl: java.lang.NullPointerException
org.apache.xmlrpc.common.XmlRpcInvocationException: Failed to invoke method deleteProject in class org.eclipse.emf.emfstore.internal.server.connection.xmlrpc.XmlRpcEmfStoreImpl: java.lang.NullPointerException
at org.apache.xmlrpc.server.ReflectiveXmlRpcHandler.invoke(ReflectiveXmlRpcHandler.java:129)
... 6 more
... 14 more
Caused by:
... 14 more
Previous Topic:[EMF Forms] Displaying structured models
Next Topic:[TEXO][Xcore] Generating JPA Entities from Xcore
Current Time: Wed Nov 05 04:37:29 EST 2025
Powered by FUDForum. Page generated in 0.04418 seconds
