Home » Modeling » UML2 » How to identify a Class correctly?
How to identify a Class correctly? [message #988608] Fri, 30 November 2012 12:03 Go to next message
My problem is that I have difficulties to determine wheter my Object is an actual Class. If i check if it is an instanceof (org.eclipse.uml2.uml.Class) all Types which inherit from (org.eclipse.uml2.uml.Class) :
org.eclipse.uml2.uml.AssociationClass (also extends org.eclipse.uml2.uml.Association)
org.eclipse.uml2.uml.Behavior
org.eclipse.uml2.uml.Activity
org.eclipse.uml2.uml.Interaction (also extends org.eclipse.uml2.uml.InteractionFragment)
org.eclipse.uml2.uml.OpaqueBehavior
org.eclipse.uml2.uml.FunctionBehavior
org.eclipse.uml2.uml.StateMachine
org.eclipse.uml2.uml.ProtocolStateMachine
org.eclipse.uml2.uml.Component
org.eclipse.uml2.uml.Node (also extends org.eclipse.uml2.uml.DeploymentTarget)
org.eclipse.uml2.uml.Device
org.eclipse.uml2.uml.ExecutionEnvironment
org.eclipse.uml2.uml.Stereotype
Also fullfill this test. So maybe someone has an idea how to find out if it is an actual class.
regards
Florian
Re: How to identify a Class correctly? [message #988617 is a reply to message #988608] Fri, 30 November 2012 12:23 Go to previous messageGo to next message
Florian,
You can check that the eClass() is exactly the one from
UML2Package.eINSTANCE.getClass_(); I'm not sure if the
generatedUML2Package has a Literals interface with a CLASS constant).
> regards
> Florian
Re: How to identify a Class correctly? [message #988641 is a reply to message #988617] Fri, 30 November 2012 14:52 Go to previous message
I'm not sure if the
Yeah, that would be UMLPackage.Literals.CLASS.
HTH,
Rafael
Previous Topic:Growing profile file size
Next Topic:Using UML2 Java Code in Eclipse
Current Time: Fri Sep 26 07:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.04032 seconds
