| How to @Inject a service into a called object [message #987727] |
Tue, 27 November 2012 13:50  |
This seems like a basic question, but I can't find an answer and I guess it's because I'm missing some basic understanding... But I can't be the only one.
I'm constructing and calling an object from a part. The part has a service successfully injected, but I can't inject into the called object. To explain with code:
public class MyPart {
@PostConstruct
public void postConstruct(Composite parent, IMyService myService) {
MyClass myObject = new MyClass();
myObject.test();
System.out.println("*myService = " + myService);
public class MyClass {
@Inject IMyService myService;
@Inject IEclipseContext eclipseContext;
MyClass() {
void test() {
System.out.println("myService = " + myService);
System.out.println("eclipseContext = " + eclipseContext);
The console output:
myService = null
eclipseContext = null
*myService = com.example.services.MyService@190d8e1
How do I inject or get access to an IMyService from MyClass?
Of course the service could be passed to myObject, but this does not work in my case (for reasons outside of scope of this question). I though the answer might be to use getBundleContext(), but although I can get the Bundle, getBundleContext() returns null.
| Re: How to @Inject a service into a called object [message #987860 is a reply to message #987837] |
Wed, 28 November 2012 07:23   |
No, no, no. Your error is that you are creating the instance of the bean
your own instead of useing ContextInjectionFactory.make()
If you want to use DI don't do this:
but do this:
MyClass myObject = ContextInjectionFactory.make(MyClass.class,context);
You don't need RunAndTrack!
Tom
Am 28.11.12 11:55, schrieb Jeff Rickard:
> Thanks, Lars.
> I had (of course :p ) read through this material (and other stuff) a
> couple of times before posting, but could not see what I was missing. I
> see now that the section on RunAndTrack is what I was after.
> (I was thrown off the scent by the phrases "A RunAndTrack is basically a
> Runnable..." and "The runAndTrack() method allows a client to keep some
> external state synchronized...", neither of which I thought were
> applicable to my problem.)
> My problem was that MyClass needed access to the IEclipseContext, and
> IEclipseContext.runAndTrack() provides a way of getting this. For
> completeness, here is my sample code, modified to work:
> @PostConstruct
> public void postConstruct(Composite parent, IEclipseContext context,
> context.runAndTrack(myObject);
> myObject.test();
> public class MyClass extends RunAndTrack {
> @Override
> public boolean changed(IEclipseContext context) {
> myService = context.getActive(IMyService.class);
> return false; // don't call on updates
> void test() {
> The console output:
| Re: How to @Inject a service into a called object [message #987867 is a reply to message #987862] |
Wed, 28 November 2012 07:46   |
No. @Creatable has the effect that an instance is created if needed by
another bean.
Say you have BeanA and BeanB.
BeanA {
@Inject
BeanB b;
BeanB {
@Inject
public BeanB(MyService service) {
If you now call:
CIF#make(BeanA,context) will normally croak and tell your that there's
no BeanB registered in context, so you'd be forced to do this.
context.set(BeanB.class, CIF#make(BeanB,context) );
BeanA a = CIF#make(BeanA,context)
If you add the @Creatable the DI container will itself create an
instance of BeanB if none is found.
Tom
Am 28.11.12 13:37, schrieb Dirk Fauth:
> Hi Tom,
> just to be sure I understand CIF now more clearly, MyClass has to be
> annotated with @Creatable so CIF.make() works. Is that correct?
> Greez,
> Dirk
| Re: How to @Inject a service into a called object [message #988291 is a reply to message #988275] |
Thu, 29 November 2012 04:54  |
Hi Dirk, Tom,
Dirk is right, using ContextInjectionFactory.inject() is a syntactically cleaner solution than RunAndTrack. (From caller it makes no difference, but it makes it more obvious in the MyClass which fields are injected.) This seems to be the right solution, at least in my case. @Lars might want to mention .inject() in the tutorial.
I think that in my case Tom's solution is more complicated than I need. In other cases it may be the best solution.
(Now I understand the solution, I see that much of this topic was already covered by http://www.eclipse.org/forums/index.php/m/982712/ - my previous searching did not find that - and that topic may contain some extra information for the next person to read this post.)
For completeness for the next person to google this question, here is the solution I have. This uses ContextInjectionFactory.inject() as an alternative to ContextInjectionFactory.make() for the case where the constructor has a parameter.
@PostConstruct
public void postConstruct(Composite parent, IEclipseContext context) {
MyClass myObject = new MyClass(123);
ContextInjectionFactory.inject(myObject, context);
MyClass(int param) {
[Updated on: Thu, 29 November 2012 04:54] by Moderator
FUDForum. Page generated in 0.06360 seconds
