Home » Newcomers » Newcomers » trouble getting started(Eclipse is installed, but I cannot create a new project)
trouble getting started [message #987442] Mon, 26 November 2012 10:59 Go to next message
I've upgraded the OS on my PC: from Ubuntu 10.04 to 12.04. Now Eclipse is useless.
With the 10.04 version of Eclipse everything worked fine: Java and C++
Now, with the 12.04 version of ubuntu I installed Eclipse, the old projects were imported but:
- syntax-highlighting is no longer available
- I cannot create a new project because File -> New -> Project offers me only General and CVS, no Java or C++
The versions of the software installed:
Eclipse: Indigo (version 3.7.2). installed are:
Eclipse C/C++ development tools. Binary runtime and user documentation.
Plugins for C/C++ library hover help
Eclipse Java development tools (binary runtime and user documentation).
gcc tells me: gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3
java tells me: java version "1.6.0_24"
What's wrong here? What is missing?
AugustQ
Re: trouble getting started [message #987480 is a reply to message #987442] Mon, 26 November 2012 14:26 Go to previous messageGo to next message
How did you install it before and how did you install it this time?
Re: trouble getting started [message #987677 is a reply to message #987480] Tue, 27 November 2012 09:45 Go to previous messageGo to next message
I think the problem is solved.
Hee iswhat I did:
- opened a terminal
- switched to root
- started eclipse via the command-line
- in it I played a bit
- closed eclipse
- closed the terminal
When I now start Eclipse I can create a new project in Java, C and C++. I succesfully create a 'hello world'-project in these 3 languages, compiled it and run the code.
I do not know why I had to go this way but now it works......
AugustQ
Re: trouble getting started [message #987682 is a reply to message #987442] Tue, 27 November 2012 10:13 Go to previous messageGo to next message
is my last posting visible?
When I look at this thread I can see 2 postings, when I hit the reply-button I can see my answer (=3 postings).
AugustQ
Re: trouble getting started [message #987683 is a reply to message #987682] Tue, 27 November 2012 10:15 Go to previous message
ah, it showed the contents from the cache.
please excuse.
AugustQ
Previous Topic:<Modified> Editor tab (the tab with file name) question
Next Topic:How to Disable Auto-Capitalization of Hex Values in Properties Files
Current Time: Sun Oct 26 16:04:12 EDT 2025
Powered by FUDForum. Page generated in 0.06456 seconds
