Problems with Tab selection by value or index [message #987438] |
Mon, 26 November 2012 15:48 |
Massimo Rabbi Messages: 29 Registered: November 2010 Location: Padova |
Hi all,
I'm quite new to Jubula, but I really would like to spend some time using it in order to speed-up the testing process of our RCP product.
Right now I'm facing a very simple, but let's say blocking issue.
One of the test case I've recorded includes the tab switching between the "Project Explorer" tab and a custom "Repository Explorer" one.
Unfortunately I'm not able to pass the first selection step.
I got the following error:
=> Type: Action Error
=> Error Description: Timeout received before confirming the posted event
Just for the sake of completeness, I'm running my environment on Mac OS X.
By the way, I found out that there is the Bug 373937 "Tabbed Pane: Select/Check selection of tab by value/index fails during our nightly tests on Swing Fulltest" that recalls a similar problem.
Some of you guys experienced similar problems? Is there any known workaround?
I'll give it a try on Windows to see if it's a platform dependent issue.
Thanks in advance for the reply.
Best Regards,
Massimo.
[Updated on: Mon, 26 November 2012 15:50] Report message to a moderator
Re: Problems with Tab selection by value or index [message #987582 is a reply to message #987560] |
Tue, 27 November 2012 09:13 |
Hi Alexandra,
thanks for the reply. The current version of Mac OS X I'm working on is the 10.7.5.
To get started with Jubula I read this article hxxp://www.rcp-vision.com/?p=1506&lang=en (sorry can not post link yet).
Our product is packaged and based on Eclipse 3.8.1.
First round, I tried with Eclipse for Testers (Juno 4.2). After that I tried to do the same steps using my development environment (Eclipse 3.8.1 + GEF,Xtext,etc.), so I installed Jubula feature: latest available is 1.2.2.201209040912.
The standalone version of Jubula is 1.3.0, so the latest available from download page. Maybe this little additional information could help.
I tried to modify the "Step delay" setting for the Test Suite, initially it was set to 0. I tried to use 100,500 and 5000. Is this a correct approach in trying to resolve what you call "timing problem"?
I'll try to run the First Steps cheat sheet as you said in order to understand better the specification of the test by hand.
Thanks again,
Massimo.
FUDForum. Page generated in 0.05700 seconds
