Home » Modeling » EMF » [CDO] Decomposing model into several repo & use same DB
[CDO] Decomposing model into several repo & use same DB [message #987308] Sun, 25 November 2012 16:45 Go to next message
I would like to decompose my model into several repositories, that contain references between them. The reason for doing this: I would like to have some of the repositories stored locally. And because CDO doesn't allow a partial checkout of the repository, a solution would be the use of multiple repositories, instead of a single, bigger one.
Question 1) is it possible that all my repositories use the same database? All the examples that I found about CDO: 1 repo = 1 DB.
Question 2) Should I expect severe performance penalties because of this approach? E.g. 1 resource/repo with 10000 objects vs 10 resources/repositories with 1000 objects each vs 100 resources/repositories with 100 objects each?
Thank you in advance,
Cristian
Re: [CDO] Decomposing model into several repo & use same DB [message #987338 is a reply to message #987308] Mon, 26 November 2012 03:37 Go to previous messageGo to next message
What do you mean with "Doesn't allow a partial checkout"? What do you want to achieve exactly?
rgds Christophe
Re: [CDO] Decomposing model into several repo & use same DB [message #987359 is a reply to message #987338] Mon, 26 November 2012 04:46 Go to previous messageGo to next message
Let's say that I have 10 resources in my server repository (resource1, resource2, ... resource10). Each resource has 1000 objects.
I want to be able to have a local clone of the repository, that contains only a subset of the resources, not the entire repository e.g. resource3 and resource4. That's what I called "partial checkout"; perhaps not the best term Smile
I understand that this is not possible; i.e. the local repository has to be a complete mirror of the server repository. That's why I am thinking of having a separete repository for each resource.
Cristian.
Re: [CDO] Decomposing model into several repo & use same DB [message #987377 is a reply to message #987359] Mon, 26 November 2012 05:57 Go to previous messageGo to next message
ah ok, so you want a partial off-line repo. Sorry, I am not into this offline stuff...
Re: [CDO] Decomposing model into several repo & use same DB [message #987546 is a reply to message #987308] Tue, 27 November 2012 00:57 Go to previous message
Am 25.11.2012 22:45, schrieb Cristian Mising name:
> Hello,
> repo = 1 DB.
I think it should be possible (easy to try out), but it may depend on the physical system used. You may need to declare
separate schemas or so.
Each repository has its own set of infrastructure services (revision manager/cache, package registry, security realm,
and, and, and...). You'd need additional server resources for all of them. Similarly for the sessions on the clients.
Inter-repo cross references (and containment proxies) are stored as URLs that need more storage space/bandwidth and that
can only be resolved by clients with properly configured resource sets).
Multi-repo commits require a CDOXATransaction which is somewhat complexer and more time consuming.
Unfortunately I can hardly comment on the exact performance differences. They depend on various things like the store
being used, the DB system being used, etc. If you make a prototype and measure yourself, I'd appreciate if you would
write them to the wiki and let us know ;-)
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[CDO Hibernate Store] Unable to instantiate default tuplizer
Next Topic:Schema location for cascaded ecore models "initialize by loading"
Current Time: Sat Jul 12 20:49:30 EDT 2025
Powered by FUDForum. Page generated in 0.03498 seconds
