Home » Newcomers » Newcomers » No build path option in Eclipse(64-bit Mac)
No build path option in Eclipse [message #987294] Sun, 25 November 2012 14:33 Go to next message
I use the newest Eclipse on 64-bit Mac and when i right-click on any folder in project, I don't have "Build Path" option, I tried to make new projects like some simple Hello World, just to test, if it's my fault, but on all of them it's missing.
Re: No build path option in Eclipse [message #987324 is a reply to message #987294] Mon, 26 November 2012 01:50 Go to previous messageGo to next message
Sebastian,
You've installed which Eclipse Package? Are you looking in the
Properties wizard for that? Only the project has a whole has Java Built
Path properties, not its subfolders.
Re: No build path option in Eclipse [message #987421 is a reply to message #987324] Mon, 26 November 2012 09:42 Go to previous messageGo to next message
I've installed Eclipse Juno 4.2 SR1 for Java Developers 64bit Mac. When I click on the project there's no such option as build path. Also when i make a new source folder(New>Source Folder) and I delete it later I've got an error Project is missing required source folder and I have to edit .classpath file
Re: No build path option in Eclipse [message #987453 is a reply to message #987421] Mon, 26 November 2012 11:45 Go to previous messageGo to next message
Are you sure that you created a 'Java Project'?
Dani
Re: No build path option in Eclipse [message #987802 is a reply to message #987453] Wed, 28 November 2012 03:56 Go to previous messageGo to next message
Yes, it's a Java Project
Re: No build path option in Eclipse [message #987920 is a reply to message #987802] Wed, 28 November 2012 11:33 Go to previous message
Have you tried looking at Right Click project -> Properties -> Java Build Path
Can you post relevant screenshots here.
Previous Topic:Android Interaction Flow
Next Topic:ECLIPSE in MOBILE
Current Time: Thu Nov 06 07:04:55 EST 2025
Powered by FUDForum. Page generated in 0.09840 seconds
