Home » Eclipse Projects » Eclipse 4 » XWT Databinding(Widget Property and IObservableValue)
XWT Databinding [message #986982] Thu, 22 November 2012 12:03 Go to next message
I have an object of IObservableValue (org.eclipse.core.databinding.observable.value.IObservableValue) and I want to bind it with widgets Properties. (For example with text).Is there a way to do this in XWT. ?
Re: XWT Databinding [message #987010 is a reply to message #986982] Thu, 22 November 2012 15:24 Go to previous messageGo to next message
One key idea behind XWT is that you don't have to deal with databinding explicitly.
Instead, you have your POJOs/Beans/... and bind their property with a UI widget using this expression: {Binding path=yourBeanProperty}
Do you have some demo code and/or xwt snippets that you tried?
Re: XWT Databinding [message #987015 is a reply to message #987010] Thu, 22 November 2012 16:32 Go to previous messageGo to next message
Thank you for the answer. I hope you understand my bad english
I have a collections of parameter (class with four fileds: name ==> string , initValue ==> Object, value ==> Object and categorie ==> String). the Parameter are provided by my application
usecase: The ability to bind the parameter value (parametername = "p") with Widget Property (p.value <===> Widget Property ) . if something happens to my widget, for example when changing the text or selection or background rate, the p.value will change. if the parameter (p.value) change the widget property change
Re: XWT Databinding [message #987081 is a reply to message #987015] Fri, 23 November 2012 06:15 Go to previous message
So, you have this class model:
class Application {
  List<Parameter> params;
class Parameter {
  String name;
  Object intValue;
  Object value;
  String categorie;
It is not clear what UI design you are targeting.
The simplest way is the master/detail pattern:
- A jface (Table)Viewer to show Parameter.name as label
- a Text widget to show/edit Parameter.value
Have a look at the Test cases of XWT.
Specifically, TableViewer_MasterDetail_Edit.xwt (see [1]) seems to be a good starting point for you.
Links:
[1] http://git.eclipse.org/c/e4/org.eclipse.e4.xwt.git/tree/tests/org.eclipse.e4.xwt.tests/src/org/eclipse/e4/xwt/tests/jface/tableviewer/master/detail/list/TableViewer_MasterDetail_Edit.xwt
Ahmed Hettab wrote on Thu, 22 November 2012 22:32
Previous Topic:Active Selection in Child Context
Next Topic:IExtensionRegistry.addContribution() calls not working in E4?
Current Time: Tue Oct 28 12:47:57 EDT 2025
Powered by FUDForum. Page generated in 0.04032 seconds
