Order of @Type and @JoinTable can break hibernate mapping [message #986666] |
Wed, 21 November 2012 05:35  |
Hi Martin, All,
I'd really appreciate some more assistance. I think I have found some strange behaviour based on the order of the @Type and @JoinTable in annotations. If I have an eCore as follows:
<eClassifiers xsi:type="ecore:EClass" name="Case1">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Case1"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eAnnotations source="bds">
<details key="isCase" value="true"/>
</eAnnotations>
<eAnnotations source="teneo.jpa">
<details key="value" value="@Table(name="MYTEST_CASE1")
@DiscriminatorValue("com.example.mytest.Case1")"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="attribute1" unique="false"
upperBound="-1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime">
<details key="kind" value="element"/>
<details key="name" value="attribute1"/>
</eAnnotations>
<details key="value" value="@JoinTable(name="MYTEST_CASE1_ATTRIBUTE1")
@Type(type="com.rob.bds.core.hibernate.XMLGCDateTime")
@Column(name="ATTRIBUTE1")"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bdsId" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELongObject">
<details key="value" value="@GeneratedValue(strategy="AUTO")
@Id
@Column(name="BDS_ID")"/>
</eAnnotations>
<details key="isId" value="true"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bdsVersion" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELongObject">
<details key="value" value="@Version
@Column(name="BDS_VERSION")"/>
</eAnnotations>
<details key="isVersion" value="true"/>
</eAnnotations>
</eClassifiers>
Note the order of the teneo.jpa:
Then the hibrnate mapping generated is as expected:
<hibernate-mapping auto-import="false">
<class entity-name="mytest.Case1" abstract="false" lazy="false" discriminator-value="com.example.mytest.Case1" table="`BDS_1_MYTEST_CASE1`">
<meta attribute="eclassName">Case1</meta>
<meta attribute="epackage">http://example.com/mytest</meta>
<id name="bdsId" type="java.lang.Long">
<column not-null="false" unique="false" name="`BDS_ID`"/>
<generator class="native"/>
</id>
<discriminator column="`DTYPE`" type="string"/>
<version name="bdsVersion" type="java.lang.Long">
<column not-null="false" unique="false" name="`BDS_VERSION`"/>
</version>
<list name="attribute1" table="`BDS_1_MYTEST_CASE1ATTRIBUTE1`" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`CASE1_ATTRIBUTE1_BDSID`" not-null="true" unique="false"/>
</key>
<list-index column="`CASE1_ATTRIBUTE1_IDX`"/>
<element type="com.rob.bds.core.hibernate.XMLGCDateTime" not-null="false" unique="false">
<column not-null="false" unique="false" name="`ATTRIBUTE1`"/>
</element>
</list>
</class>
</hibernate-mapping>
However if the ecore changes to:
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
<details key="value" value="@Type(type="com.rob.bds.core.hibernate.XMLGCDateTime")
</eAnnotations>
@Id
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
Again note the change in order of the teneo.jpa:
Then the hibrnate mapping generated is not as I would expect:
</id>
</version>
<list name="attribute1" table="`MYTEST_CASE1_ATTRIBUTE1`" lazy="true" cascade="all,delete-orphan">
<key update="true">
</key>
<element type="BDS_1_MYTEST_CASE1ATTRIBUTE1" not-null="false" unique="false">
</element>
</list>
</class>
The line:
Quote:<element type="BDS_1_MYTEST_CASE1ATTRIBUTE1" not-null="false" unique="false">
Has put in a very strange type!
Any ideas?
Rob
Re: Order of @Type and @JoinTable can break hibernate mapping [message #986717 is a reply to message #986666] |
Wed, 21 November 2012 07:37   |
Hi Rob,
To me it seems like a real bug.. Can you enter a bugzilla for it?
gr. Martin
On 11/21/2012 11:35 AM, Rob Mising name wrote:
> Hi Martin, All,
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> @Id
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> Quote:
> </id>
> </version>
> <key update="true">
> </key>
> </element>
> </list>
> </class>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> @Id
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> Quote:
> </id>
> </version>
> <key update="true">
> </key>
> </element>
> </list>
> </class>
> The line:
> Quote:
> Any ideas?
> Thanks
> Rob
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03699 seconds
