Home » Modeling » EMF » Ecore definition and model instances in the same workbench
Ecore definition and model instances in the same workbench [message #986621] |
Wed, 21 November 2012 08:46 |
Hello everybody,
is there a way to open a generic EMF editor to create and edit instances
(as XMI files) of an Ecore model which is developed in the same
workbench? And along the same line, is there a way to have such and XMI
file be validated against that .ecore? I think this is some kind of
chicken-and-egg issue. So I've been wondering if there is already
somewhere some magic kind of workspace/*.ecore <-> global EMF registry
syncer plugin?
The obvious workaround is of course to start a runtime workbench, but
that is a rather harsh setback for the development workflow.
Marius
Re: Ecore definition and model instances in the same workbench [message #986919 is a reply to message #986815] |
Thu, 22 November 2012 11:21 |
Hello Ed,
>> workbench?
> Yes.
> Yes.
Almost.. see below.
>> syncer plugin?
> From the context menu of an EClass you have opened in the *.ecore
> editor, you can invoke Create Dynamic Instance...
Thanks!
I experimented a bit with this using an existing .ecore model. I could
create a model instance and indeed I got validation errors both in the
reflective EMF editor and problem markers when I had not initialized
some mandatory attributes. Next I created a new attribute in a class
(type EInt, lowerBound=1, no default literal, unsettable = false). I did
not get a Problem Marker for this, but the new attribute did appear in
the editor (with a default value of 0). I would have expected to get an
error there.
Next I removed the new attribute from the class again. Again there were
no problem markers. Right-clicking the .xmi file and choosing Validate..
did succeed! Only when I loaded the XMI into the reflective EMF editor,
I did get an error about an unknown attribute. But still no problem marker.
Do I need a special builder perhaps for this?
Marius
Re: Ecore definition and model instances in the same workbench [message #987074 is a reply to message #986919] |
Fri, 23 November 2012 10:11 |
I have tried this again with different models, but no joy.
What is Right-click .xmi -> Validate... supposed to validate anyway?
Marius
Re: Ecore definition and model instances in the same workbench [message #987083 is a reply to message #986919] |
Fri, 23 November 2012 11:28 |
Ed Merks Messages: 33146 Registered: July 2009 |
Marius,
Comments below.
On 22/11/2012 12:21 PM, Marius Gröger wrote:
> Hello Ed,
>>> workbench?
>> Yes.
>> Yes.
> Almost.. see below.
>>> syncer plugin?
> Thanks!
> error there.
Primitives are a bit special. They can't take on a null value so how
best to establish if such a feature violates the constraint that a value
must be present? The validator treats non-unsettable and unsettable
features different in this regard. An unsettable feature must be set
(eIsSet must be true) to satisfy the lower bound of 1 constraint. A
non-unsettable feature must have a non-null value to satisfy the lower
bound of 1 constraint. As such, a primitive-valued non-unsettable
feature can't violate the lower bound of 1 constraint.
Problem markers are not created as a side effect of loading a resource.
The Xtext folks provide a builder that validates Ecore and GenModel
resources so a project with an Xtext nature would do that, but EMF does
not provide such a builder.
> Regards
> Marius
Ed Merks
Re: Ecore definition and model instances in the same workbench [message #987610 is a reply to message #987083] |
Tue, 27 November 2012 10:29 |
>> marker.
I have taken a look a the org.eclipse.wst.validation.validator EP and
began writing a simple validator which is activated on *.xmi IFile
resources. Essentially this validator loads the .xmi file to be checked.
A customized EcoreBuilder then attempts to associate an .ecore file with
the loaded resource and validates it using Diagnostician.
While this kind of works, two questions arise:
1) Overriding the DefaultEcoreBuilder with code searching for an .ecore
appears clumsy to me. When the .xmi file contains an .ecore
schemLocation this should not be necessary. But AFACT the
DefaultEcoreBuilder seems to only handle XSD and xsd schema locations
natively?
2) Obviously any errors detected by the Diagnostician don't have
line/column numbers associated with them. Is there anyway to load an XMI
resource to track this? Otherwise I can't create meaningful problem
markers and this whole thing becomes almost pointless!
TIA
Marius
Re: Ecore definition and model instances in the same workbench [message #987621 is a reply to message #987610] |
Tue, 27 November 2012 10:47 |
Marius,
Comments below.
>>> marker.
> natively?
Yes, it assumes there are XML Schema's being referenced.
No.
EMF creates problem markers that associate the URIs of the objects so if
you double click them the editor selects the right objects without
knowing their location in the source. You can reuse the utilities in
org.eclipse.emf.edit.ui.util.EditUIMarkerHelper, i.e.,
createMarkers(Diagnostic).
> TIA
> Marius
Ed Merks
Re: Ecore definition and model instances in the same workbench [message #987633 is a reply to message #987621] |
Tue, 27 November 2012 11:27 |
Actually I'd been using MarkerHelper already but didn't know there were
even more useful extension to it. The one you mention however seems to
rely on (non-existent) line/column information in the Diagnostics.
I found
org.eclipse.emf.edit.ui.action.ValidateAction.EclipseResourcesUtil which
seems at least to adjust markers with EMF resources but doesn't attach
LOCATION tags to the markers.
Do you have any more clues to get this working?
Marius
Re: Ecore definition and model instances in the same workbench [message #987644 is a reply to message #987637] |
Tue, 27 November 2012 12:18 |
On 27.11.2012 12:54, Ed Merks wrote:
> Marius,
> Comments below.
> For ResourceDiagnostics we often have line information, but not from the
> validator.
>> I found
> Yes, as I said we simply don't have them so that's not going to work...
> Create them like you see in ValidateAction.
I'm very confused now. :-) Initially you indicated that I *don't* need
line information for error markers created by EditUIMarkerHelper.
I found out this doesn't seem to be true.
But the ValidateAction.EclipseResourcesUtil.createMarkers() doesn't work
either, even though ValidateAction.EclipseResourcesUtil.adjustMarker()
is being used.
Now what do you refer to with "like you see in ValidateAction"?!
Marius
Re: Ecore definition and model instances in the same workbench [message #987694 is a reply to message #987644] |
Tue, 27 November 2012 16:10 |
Marius,
Comments below.
>> Marius,
>> Comments below.
>> validator.
>>> I found
I thought the code that's in the validator action was there...
> is being used.
What do you mean by it doesn't work? When these markers are used in the
generate editors they select the object with the problem.
The code you refer to above, i.e., the adjustMarker override...
> Marius
Ed Merks
Re: Ecore definition and model instances in the same workbench [message #987780 is a reply to message #987694] |
Wed, 28 November 2012 07:20 |
>> is being used.
Mystery solved - in my testing workbench I had previously opened the
erratic file with the XML editor. Double clicking the error marker then
always opened the XML editor and neither of the generic or reflective
EMF editors. It works now.
Thanks!
Marius
Current Time: Sat May 11 02:25:22 GMT 2024
Powered by FUDForum. Page generated in 0.14963 seconds
