Re: Multi Java Annotations in the model [message #986406 is a reply to message #986398] |
Tue, 20 November 2012 10:42 |
Hi Gabriele,
The content of the eannotation is a large text field, so you can put them all in one eannotation, that will work.
But it is probably no work to add support for this, can you enter a bugzilla for this?
gr. Martin
On 11/20/2012 11:30 AM, gabriele boldrin wrote:
> I've specified in the model a java annotation.
> If I insert more than one java annotation for node, TEXO considers only the first java annotation and the others are ignored.
> Example:
> Generation Code:
> * Returns the value of '<em><b>field2</b></em>' feature.
> * <!-- begin-user-doc --> <!-- end-user-doc -->
> * @return the value of '<em><b>field2</b></em>' feature
> * @generated
> @Overview(Overview.DATE)
> public String getField2() {
> return field2;
> code generation that I expect:
> * @generated
> @Overview(Overview.TEXT)
> return field2;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Multi Java Annotations in the model [message #991128 is a reply to message #991125] |
Mon, 17 December 2012 12:38 |
Erdal Karaca Messages: 854 Registered: July 2009 |
Andreas Brieg wrote on Mon, 17 December 2012 13:26As a side node: the Java code you want to be generated won't be valid. You can't annotate something with the same annotation type more than once. You would need something like
@Overviews(@Overview(Overview.Date), @Overview(Overview.Text))
or
@Overview({Overview.Date, Overview.Text})
It is the second one as you can only have one optional value/attribute in a java annotation...
[Updated on: Mon, 17 December 2012 12:39] Report message to a moderator
Re: Multi Java Annotations in the model [message #991131 is a reply to message #991128] |
Mon, 17 December 2012 12:45 |
Hi Andreas,
Not sure which annotation/annotation type do you mean, is it related to Texo or to something else?
gr. Martin
>> or
The Netherlands
Re: Multi Java Annotations in the model [message #991138 is a reply to message #991131] |
Mon, 17 December 2012 13:15 |
Ha Andreas,
Forget my question, I see now that you refer to (the invalid example in) the original question.
gr. Martin
On 12/17/2012 01:45 PM, Martin Taal wrote:
> Hi Andreas,
> gr. Martin
>>> or
The Netherlands
FUDForum. Page generated in 0.03420 seconds
