Re: [Texo] Generation Code [message #986321 is a reply to message #986298] |
Mon, 19 November 2012 23:14 |
Hi Gabriele,
A bug, I solved it and published a new build. Let me know if it still occurs.
gr. MArtin
On 11/19/2012 07:53 PM, gabriele boldrin wrote:
> I found texo ORM generator doesn't process JPA annotation correctly.
> Errors:
> "import javax.persistence.Index" is wrong, it should be "org.eclipse.persistence.annotations.Index"
> "import javax.persistence.Indexs" is wrong, it should be "org.eclipse.persistence.annotations.Indexes"
> Result code generation by my test:
> import javax.persistence.Basic;
> import javax.persistence.Entity;
> import javax.persistence.Index;
> import javax.persistence.Indexs;
> * A representation of the model object '<em><b>A</b></em>'. <!-- begin-user-doc
> * --> <!-- end-user-doc -->
> * @generated
> @Entity(name = "test_A")
> @Indexs({ @Index(columnNames = { "field1", "field2" }, unique = false) })
> public class A {
> * <!-- begin-user-doc --> <!-- end-user-doc -->
> * @generated
> @Basic()
> private String id = null;
> * @generated
> @Basic()
> @Index()
> private String name = null;
> I have attached my test : test.ecore and test-orm.annotationsmodel
> Is this a bug?
> Enviroment :
> Eclipse Java EE IDE Juno Build id: 20120920-0800
> EMF 2.8.1
> JPA eclipselink 2.4
> EMFT Texo SDK (Incubation) 0.1.0.v201211031957 org.eclipse.emf.texo.sdk.feature.group Eclipse Modeling Project
> EMFT Texo (Incubation) 0.1.0.v201211031957 org.eclipse.emf.texo.feature.group Eclipse Modeling Project
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Generation Code [message #986399 is a reply to message #986391] |
Tue, 20 November 2012 10:27 |
Hi Gabriele,
Okay thanks, will check and solve it. The reason that these errors occur is that the Texo annotations model is generated
from the orm xsd (xml schema), there are slight differences between the naming/formatting/structure of the xsd compared
to the java/JPA annotations. In addition the xsd is a combination of standard JPA and eclipselink specific annotations.
gr. Martin
On 11/20/2012 11:14 AM, gabriele boldrin wrote:
> I have found other errors.
> Annotation Multitenant
> The imports are wrong, but this time the generation of annotations is incorrect
> See you http://wiki.eclipse.org/EclipseLink/Examples/JPA/Multitenant
> Example:
> package test;
> import javax.persistence.Multitenant;
> import javax.persistence.TenantDiscriminator;
> @Multitenant(tenantDiscriminators = { @TenantDiscriminator(columnName = "tenant") })
> @Indexes({ @Index(columnNames = { "field1", "field2" }, unique = false) })
> public class A {
> The code should be this:
> @org.eclipse.persistence.annotations.Multitenant @org.eclipse.persistence.annotations.TenantDiscriminatorColumn(name =
> "tenant") @Indexes({ @Index(columnNames = { "field1", "field2" }, unique = false) })
> public class A {
The Netherlands
FUDForum. Page generated in 0.02709 seconds
