| @Lob Causing incorrect Hibrenate mapping [message #985642] |
Thu, 15 November 2012 10:15  |
With an eCore that looks as follows:
<eClassifiers xsi:type="ecore:EClass" name="Case1">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Case1"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eAnnotations source="bds">
<details key="isCase" value="true"/>
</eAnnotations>
<eAnnotations source="teneo.jpa">
<details key="value" value="@Table(name="ROBTEST_CASE1")
@DiscriminatorValue("com.example.robtest.Case1")"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="stringLob" unique="false" upperBound="-1">
<details key="kind" value="element"/>
<details key="name" value="stringLob"/>
</eAnnotations>
<details key="value" value="@Lob
@Column(name="STRINGLOB", length="1048576")"/>
</eAnnotations>
<eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2003/XMLType#//String"/>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bdsId">
<details key="value" value="@GeneratedValue(strategy="AUTO")
@Id
@Column(name="BDS_ID")"/>
</eAnnotations>
<details key="isId" value="true"/>
</eAnnotations>
<eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//ELongObject"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bdsVersion">
<details key="value" value="@Version
@Column(name="BDS_VERSION")"/>
</eAnnotations>
<details key="isVersion" value="true"/>
</eAnnotations>
</eClassifiers>
So the "stringLob" has the following annotation:
@Lob
If this is used to generate a hibernate mapping it gives:
<hibernate-mapping auto-import="false">
<class entity-name="robtest.Case1" abstract="false" lazy="false" discriminator-value="com.example.robtest.Case1" table="`BDS_1_ROBTEST_CASE1`">
<meta attribute="eclassName">Case1</meta>
<meta attribute="epackage">http://example.com/robtest</meta>
<id name="bdsId" type="java.lang.Long">
<column not-null="false" unique="false" name="`BDS_ID`"/>
<generator class="native"/>
</id>
<discriminator column="`DTYPE`" type="string"/>
<version name="bdsVersion" type="java.lang.Long">
<column not-null="false" unique="false" name="`BDS_VERSION`"/>
</version>
<property name="stringLob" lazy="false" insert="true" update="true" not-null="false" unique="false" type="text">
<column not-null="false" unique="false" name="`STRINGLOB`" length="1048576"/>
</property>
</class>
</hibernate-mapping>
But because the upperBound="-1" is specified, I would have expected it to generate a list for stringLob:
</id>
</version>
<list name="stringLob" table="`BDS_1_ROBTEST_CASE1STRINGLOB`" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`CASE1_STRINGLOB_BDSID`" not-null="true" unique="false"/>
</key>
<list-index column="`CASE1_STRINGLOB_IDX`"/>
<element type="java.lang.String" not-null="false" unique="false" type="text">
</element>
</list>
</property>
</class>
Is anyone able to assist me with this, is it a know problem, or am I doing something wrong?
Rob
| Re: @Lob Causing incorrect Hibrenate mapping [message #985903 is a reply to message #985642] |
Fri, 16 November 2012 10:56   |
Hi Rob,
This is an omission in Teneo, I am solving it and will do a new build sometime today.
gr. Martin
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> @Id
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> Quote:
>> @Lob
> </id>
> </version>
> </property>
> </class>
> </id>
> </version>
> <key update="true">
> </key>
> </element>
> </list>
> </property>
> </class>
> Thanks
> Rob
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
| Re: @Lob Causing incorrect Hibrenate mapping [message #985948 is a reply to message #985903] |
Fri, 16 November 2012 14:59   |
Hi Rob,
I published a new build which should solve this.
gr. Martin
On 11/16/2012 04:56 PM, Martin Taal wrote:
> Hi Rob,
> gr. Martin
>> </eAnnotations>
>> </eAnnotations>
>> </eAnnotations>
>> </eAnnotations>
>> </eAnnotations>
>> @Id
>> </eAnnotations>
>> </eAnnotations>
>> </eAnnotations>
>> </eAnnotations>
>> </eClassifiers>
>> Quote:
>>> @Lob
>> </id>
>> </version>
>> </property>
>> </class>
>> </id>
>> </version>
>> <key update="true">
>> </key>
>> </element>
>> </list>
>> </property>
>> </class>
>> Thanks
>> Rob
The Netherlands
FUDForum. Page generated in 0.04821 seconds
