Home » Archived » Test and Performance Tools Platform (TPTP) » Beginner question: creating diagrams using UML 2.0 Testing profile
Beginner question: creating diagrams using UML 2.0 Testing profile [message #142846] Thu, 25 June 2009 06:02 Go to next message
Hello all,
Background: I'm attempting an experiment to generate test suites in a
text-based testing language (not JUnit or TTCN-3). My primary goal is to
be able to use the UML 2.0 Testing Profile and create sequence diagrams
specifying different test cases. TPTP seems to be the only (?) project
implementing the profile, which is why I'm asking here.
The material I have found so far seems geared towards java code profiling
and testing using JUnit, but I'm foremost interested in just producing
UML2 diagrams using the testing profile. Is TPTP unnecessary to acheive
this, or can it be of help?
My hope is then to use JET to generate test code based on the the UML
diagrams.
Are there any resources I should look at to get a better understanding of
how to achieve this?
Thanks for any help,
/Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #142906 is a reply to message #142846] Mon, 29 June 2009 03:51 Go to previous messageGo to next message
Hi all,
More searching through the Eclipse forums lead me to a thread where the
poster asks the same question as the one I'm interested in.
http://dev.eclipse.org/newslists/news.eclipse.tptp/msg06957. html
From what I can tell, it is therefore possible to do what I propose in the
paragraph below?
<snip>
> diagrams.
Is this a good idea, or should I consider something else to generate test
code?
This question remains, especially tips on where to begin to create a very
simple model with which to experiment.
/Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #142936 is a reply to message #142906] Mon, 29 June 2009 07:14 Go to previous messageGo to next message
Hi Lars,
The TPTP Test Project implements the UML 2 Test Profile model used to
model our test artifacts, such as test suites, test cases, and datapools.
We use JET to generate the generator classes that generate JUnit test
classes from the test suite/case models (see
/org.eclipse.hyades.test.tools.core/src/org/eclipse/hyades/t est/tools/core/internal/java/codegen/GenTestSuite.java).
In your case, you could follow the same design as TPTP and model your
test cases/suites using the Test Profile model and model your execution
sequences (e.g. sequence diagrams) using the behavioral model. From these
models, you could write a JET template to generate any type of executable
test.
Paul
"Lars" <larsgj@hotmail.com> wrote in message
news:afb1b6f02d4f6b55e726b6296aec424b$1@www.eclipse.org...
> Hi all,
> paragraph below?
> <snip>
>> diagrams.
> code?
> Cheers,
> /Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #142945 is a reply to message #142936] Mon, 29 June 2009 09:49 Go to previous messageGo to next message
Hi Paul,
Thanks for your reply, I was hoping for something to that effect.
<snip>
<snip>
> test.
OK, this is what I'll try to achieve when I have created a model that I
can transform.
<snip>
<snip>
This is now my main focus. Since I'm not interested in Java in particular,
but only in the UML 2.0 Testing Profile, I'm not quite sure where to begin
to create a model.
If I try to create a project using File -> New -> Other, and filter on
"test", I have the following options:
Java
-> JUnit
-> JUnit Test Case
-> JUnit Test Case
Test
-> Test Case
-> Test From Recording
-> TPTP JUnit Plug-in Test
-> TPTP JUnit Test
-> TPTP URL Test
None of these seem to fit what I want to do, namely to create a UML 2.0
model that uses the UML 2.0 Test Profile, without any connections to Java
or JUnit. It is possible that what I really want to do is create just a
UML 2.0 model and then somehow specify that it should follow the Test
Profile that the TPTP framework implements.
I would really like to keep my first examples/experiments as simple and
clean as possible.
Any help to push me in the right direction would be appreciated!
/Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #142986 is a reply to message #142945] Wed, 01 July 2009 06:15 Go to previous messageGo to next message
Hi Lars,
TPTP does not provide any modeling tools to create your models. We use
EMF to generate our models
( http://www.eclipse.org/tptp/platform/documents/resources/mod els/index.htm)
from Rational Rose class diagrams:
http://www.eclipse.org/tptp/platform/documents/resources/mod els/TPTP_Model_Generation.html
You should start with a simple EMF tutorial:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.html
http://wiki.eclipse.org/index.php/EMF/FAQ
Paul
news:92f4dc0babcfa2be97d3f4478e9b49a6$1@www.eclipse.org...
> Hi Paul,
> <snip>
> <snip>
>> these models, you could write a JET template to generate any type of
>> executable test.
> can transform.
> <snip>
>>>> to
> <snip>
>>>> of
>>> very
> to create a model.
> Java -> JUnit
> -> JUnit Test Case
> -> JUnit Test Case
> Test
> -> Test Case
> -> TPTP JUnit Test
> -> TPTP URL Test
> clean as possible.
> /Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #143029 is a reply to message #142945] Wed, 01 July 2009 12:35 Go to previous messageGo to next message
Hi Lars,
just a short briefing from myside: the U2TP (UML2 Testing Profile) is a
so called "profile", but the implementation from tptp is the standalone
mof model. If you want a UML model to be annotated with the stereotypes
of the u2tp, you still need an uml implementation of the profile. I
think, currently, there is no open source implementation available, but
to implement it by yourself should not be very difficulty. Afterwards
you still need a transformation from UML+u2tp into TPTP metamodel, since
they implementing the same spec, but having separate concept spaces.
But don't think, that the u2tp provides good capabilities for the
generation of test cases. Let's consider the test case stereotype. It
extends Behavior and as such, it is possible to mark any behavior of the
uml superstructure as TestCase. But, if you stereotype an
UML::StateMachine, what is the semantic of the TestCase? One path
through the machine, all pathes through the machine? You know, the
greates problem of the u2tp, imho, is, that even if you have annotated
your system model completely with u2tp stereotypes, you won't have any
executable test case. There is still a lot of transformation work to do!
HTH
Timothy
Lars schrieb:
> Hi Paul,
> <snip>
> <snip>
>> your test cases/suites using the Test Profile model and model your
>> execution sequences (e.g. sequence diagrams) using the behavioral
>> model. From these models, you could write a JET template to generate
>> any type of executable test.
> can transform.
> <snip>
>>>> is to
> <snip>
>>>> understanding of
>>> very
> particular, but only in the UML 2.0 Testing Profile, I'm not quite sure
> where to begin to create a model.
> Java -> JUnit
> -> JUnit Test Case
> -> JUnit Test Case
> Test
> -> Test Case
> -> TPTP JUnit Test
> -> TPTP URL Test
> Java or JUnit. It is possible that what I really want to do is create
> just a UML 2.0 model and then somehow specify that it should follow the
> Test Profile that the TPTP framework implements.
> clean as possible.
> /Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #143115 is a reply to message #142846] Mon, 13 July 2009 10:15 Go to previous messageGo to next message
Hello Lars,
at our university (the university of Göttingen), we currently have a
master's thesis in development (actually, the implementation will be
finished in one or two weeks) where we generate test cases from the UML
testing profile (actually an OCL constrained variant of it in order to
make it semantically more clear and strict) using EMF/Ecore (to define
an intermediate metamodel that is more simple than all the UML stuff),
Xtend to transform UML->intermediate model, Xpand to generate the test
cases, and MWE to execute the workflows (basically the oAW stuff).
We develop and export our UML models with Magicdraw where we have
adapted the UML testing profile slightly in order to make the export
work properly and support more diagrams. I am not sure if TPTP brings
anything different to the table in order to make this work, but we are
pretty happy with this setup and what we have achieved without TPTP ;-)
Don't hesitate to contact me if you would like to know any more details
about this work.
Ben
Lars schrieb:
> Hello all,
> profiling and testing using JUnit, but I'm foremost interested in just
> producing UML2 diagrams using the testing profile. Is TPTP unnecessary
> to acheive this, or can it be of help?
> diagrams.
> of how to achieve this?
> /Lars
Re: Beginner question: creating diagrams using UML 2.0 Testing profile [message #496751 is a reply to message #143115] Wed, 11 November 2009 05:00 Go to previous message
Hello Ben:
I am seraching for a tool which can create U2TP test cases using UML design models. Is this what you are doing in the project. Can I get a little more details about the intermediate model you discussed. Have you completed the tool already?
Best Regards
Annie
Previous Topic:Very slow performance while profiling
Next Topic:Looking for 4.6.1 project file set i.e. TPTPProjectSet461.psf
Current Time: Wed Sep 17 11:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.10858 seconds
