300 M7 code formatter problem? [message #142703] |
Tue, 17 February 2004 17:53 |
Originally posted by: stromo.spamme.com
The code formatter doesnt seem to work at all (default settings)
It just removes the indent from the first line of whatever block of code i
select.
Anyone else seeing this?
-s
Re: 300 M7 code formatter problem? [message #142720 is a reply to message #142703] |
Tue, 17 February 2004 18:15 |
> select.
> -s
Yes, I found the formatter to work horribly. I experimented for a while
with setting options to get back to the behavior in previous versions, but
I still saw very strange formatting that could not be fixed by changing
options, i.e. the formatter is basically broken.
I decided to go back to the previous version, m6. I hope the formatter
will
be restored to that version.
JBR
Re: 300 M7 code formatter problem? [message #142730 is a reply to message #142720] |
Tue, 17 February 2004 19:27 |
Originally posted by: neil.neil.swingler.name
"jbr" <riley@ll.mit.edu> wrote in message news:c0tloh$8o8$1@eclipse.org...
i
> > select.
> > -s
> will
See bugs:
No migration path to switch to new code formatter [code formatter]:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48962
New code formatter: can't replicate old formatter:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51158
Re: 300 M7 code formatter problem? [message #142740 is a reply to message #142720] |
Tue, 17 February 2004 19:29 |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Tue, 17 Feb 2004 18:15:45 +0000 (UTC), riley@ll.mit.edu (jbr) a
écrit :
>will be restored to that version.
Could you please open a bug report against JDT/Core with test cases
that used to work and are not working anymore?
Open one bug report per problem found, please.
Olivier
FUDForum. Page generated in 0.02904 seconds
