Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #985635 is a reply to message #985242] |
Thu, 15 November 2012 15:03 |
David Song Messages: 217 Registered: April 2011 |
Thanks Ralf for your so quick reply to me
the tutorial is about how to deploy workbench rap application to jee container, but I say how to depay RWT STANDALONE APP to jee container, just like the example org.eclipse.rap.examples, I tried import org.eclipse.rap.examples and create a war configuration file to export a war file, but when deploy to jboss, an error occrors and the log is as belong:
WARN [org.jboss.as.ee] (MSC service thread 1-1) JBAS011006: Not installing optional component org.eclipse.rap.rwt.engine.RWTServletContextListener due to exception: java.lang.ClassNotFoundException: org.eclipse.rap.rwt.engine.RWTServletContextListener from [Module "deployment.ROOT.war:main" from Service Module Loader]
at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:190) [jboss-modules.jar:1.1.1.GA]
at org.jboss.modules.ConcurrentClassLoader.performLoadClassUnchecked(ConcurrentClassLoader.java:468) [jboss-modules.jar:1.1.1.GA]
at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:456) [jboss-modules.jar:1.1.1.GA]
at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:398) [jboss-modules.jar:1.1.1.GA]
at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:120) [jboss-modules.jar:1.1.1.GA]
at java.lang.Class.forName0(Native Method) [rt.jar:1.7.0_06]
at java.lang.Class.forName(Class.java:264) [rt.jar:1.7.0_06]
at org.jboss.as.server.deployment.reflect.DeploymentClassIndex.classIndex(DeploymentClassIndex.java:54) [jboss-as-server-7.1.1.Final.jar:7.1.1.Final]
at org.jboss.as.ee.component.deployers.EEModuleConfigurationProcessor.deploy(EEModuleConfigurationProcessor.java:79)
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:113) [jboss-as-server-7.1.1.Final.jar:7.1.1.Final]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.2.GA.jar:1.0.2.GA]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) [rt.jar:1.7.0_06]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) [rt.jar:1.7.0_06]
at java.lang.Thread.run(Thread.java:722) [rt.jar:1.7.0_06]
and the content in warproduct file is listed as below:
<?pde version="3.5"?>
<product name="example product" uid="example" useFeatures="false" includeLaunchers="false">
<plugins>
<plugin id="javax.xml"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.http.servletbridge"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.servletbridge"/>
<plugin id="org.eclipse.equinox.servletbridge.extensionbundle" fragment="true"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.rap.examples"/>
<plugin id="org.eclipse.rap.examples.pages"/>
<plugin id="org.eclipse.rap.jface"/>
<plugin id="org.eclipse.rap.jface.nl_zh" fragment="true"/>
<plugin id="org.eclipse.rap.rwt"/>
<plugin id="org.eclipse.rap.rwt.nl_zh" fragment="true"/>
</plugins>
<configurations>
<plugin id="javax.xml" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.commands" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.contenttype" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.jobs" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.registry" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.servlet" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.servletbridge" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.preferences" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.registry" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.servletbridge" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.osgi" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.osgi.services" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.examples" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.examples.pages" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.jface" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.rwt" autoStart="true" startLevel="0" />
</configurations>
<warConfiguration webXml="/org.eclipse.rap.examples/WEB-INF/web.xml" launchIni="/org.eclipse.rap.examples/WEB-INF/launch.ini">
<libraries>
<library path="org.eclipse.equinox.servletbridge_1.2.200.v20120912-125810.jar" fromTarget="true"/>
</libraries>
</warConfiguration>
</product>
BTW I can run the examples application in my eclipse ide but can not export war file to run jee container.
Thank you again.
David
[Updated on: Thu, 15 November 2012 15:37] Report message to a moderator
Re: require document for deploy rwt standalone to jee container like tomcat or jboss? [message #986571 is a reply to message #984264] |
Wed, 21 November 2012 00:55 |
hi Ralf,
First, thanks again for your reply.Secondly, I am also very happy to help other friends. Do not bother, I encountered problems in using RAP, and I believe that other people may encounter the same problem, take a look at this post hits in, you'll know. Everyone to ask their questions, and then solve the problem, and improve the RAP together What's wrong with it?
Thank you again
Hoping Rap is getting better and better, more powerful.
David
FUDForum. Page generated in 0.03045 seconds
