Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.5.2 installation problems
TPTP 4.5.2 installation problems [message #142450] |
Tue, 02 June 2009 16:16 |
Franck Mising name Messages: 92 Registered: July 2009 Location: France |
Member |
Hi all, I am new to TPTP and I am running into issues trying to setup TPTP
on Ganymede.
I downloaded and installed the 4.5.2 plugins (platform and testing tools)
from the 4.5.2 download page, and I successfully converted an existing
unit test into a TPTP unit test.
In the preferences window both "test connection" button/links report
success. However when I right-click my TPTP junit test and choose Run As
-> Test I get a dialog saying "preparing and deploying", then after a few
minutes an error saying "IWAT4039E The Test Execution Harness reported the
following problems: IWAT0005E The host localhost was not found."
I have included my serviceconfig.xml below, and there is no firewall in
the way.
I could not figure out how to enable debug logging for the integrated
agent. Changing INFORMATION to DEBUG in serviceconfig.xml had no effect,
does that configuration file affect the IAC or only standalone controllers?
Also, I am a bit confused by the preference pages:
- is the "Agent Controller -> Agent Controller Local Port" setting
defining the port the IAC will listen on?
- if so why is the default host in "Agent Controller -> Hosts" defined as
localhost[10002] when the default agent controller local port is 10006?
Test connection fails with 10002, I had to add a 127.0.0.1[10006] host for
the test to succeed
- What does the defined list of hosts in Agent Controller -> Hosts mean? I
assume the TPTP client is configured on the "Test" main preference page, I
entered localhost[10006] on that page and the test succeeds.
Your help would be greatly appreciated, I can't figure out how to
troubleshoot those issues...
Franck
<AgentControllerConfiguration>
<AgentControllerEnvironment configuration="default">
<Variable name="JAVA_PATH" position="replace"
value="C:\jre6\bin\java.exe"/>
<Variable name="RASERVER_HOME" position="replace"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.ac.win_ia32_4. 4.100.v200902101418\agent_controller "/>
<Variable name="TPTP_AC_HOME" position="replace"
value="%RASERVER_HOME%"/>
<Variable name="TPTP_AC_CONFIG_HOME" position="replace"
value=" E:\eclipse\.metadata\.plugins\org.eclipse.tptp.platform.iac. administrator\config "/>
<Variable name="PLUGINS_HOME" position="replace"
value="E:\ganymede\plugins"/>
<Variable name="PATH" position="prepend" value="%RASERVER_HOME%\bin"/>
<Variable name="SYS_TEMP_DIR" position="replace" value="%TEMP%"/>
<Variable name="LOCAL_AGENT_TEMP_DIR" position="replace"
value="%SYS_TEMP_DIR%"/>
<Variable name="CLASSPATH_ORG_APACHE_COMMONS_LOGGING" position="append"
value=" E:\ganymede\plugins\org.apache.commons.logging_1.0.4.v200806 05-1930.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS" position="append"
value=" E:\ganymede\plugins\org.eclipse.core.commands_3.4.0.I2008050 9-2000.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME" position="append"
value=" E:\ganymede\plugins\org.eclipse.core.runtime_3.4.0.v20080512 .jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON" position="append"
value=" E:\ganymede\plugins\org.eclipse.equinox.common_3.4.0.v200804 21-2006.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_OSGI" position="append"
value=" e:\ganymede\plugins\org.eclipse.osgi_3.4.3.R34x_v20081215-10 30.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_COMMON" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.common_2.4.0.v2009021711 15.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.ecore_2.4.2.v20090217111 5.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI" position="append"
value=" E:\ganymede\plugins\org.eclipse.emf.ecore.xmi_2.4.1.v2009021 71115.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_JFACE" position="append"
value=" E:\ganymede\plugins\org.eclipse.jface_3.4.2.M20090107-0800.j ar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_SWT" position="append"
value=" E:\ganymede\plugins\org.eclipse.swt.win32.win32.x86_3.4.1.v3 452b.jar;E:\ganymede\plugins\org.eclipse.swt_3.4.2.v3452b.ja r "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS"
position="append"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.models_4.5.2.v 200901290906\tptp-models.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS_HIERARCHY"
position="append"
value=" E:\ganymede\plugins\org.eclipse.tptp.platform.models.hierarc hy_4.5.1.v200902180100\tptp-models-hierarchy.jar "/>
<Variable name="CLASSPATH_ORG_JUNIT" position="append"
value=" E:\ganymede\plugins\org.junit_3.8.2.v20080602-1318\junit.jar "/>
<Variable name="CLASSPATH_COM_IBM_ICU" position="append"
value="E:\ganymede\plugins\com.ibm.icu_3.8.1.v20080530.jar"/ >
<Variable name="CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING"
position="append" value="%CLASSPATH_ORG_APACHE_COMMONS_LOGGING%"/>
<Variable name="CLASSPATH" position="append"
</AgentControllerEnvironment>
<ApplicationAliases>
<Application configuration="default" executable="java.exe"
location="%SYS_TEMP_DIR%" path="%JAVA_PATH%">
value="%CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON%"/>
</Application>
</ApplicationAliases>
<Plugin path="E:\eclipse\.metadata\.plugins"/>
<Agent path="%TPTP_AC_HOME%\agents"/>
<Jvm location="C:\jre6\bin\client\jvm.dll"/>
<Logging directory="%TPTP_AC_CONFIG_HOME%" format="CBE" level="DEBUG"/>
<ProcessController>%TPTP_AC_HOME%\bin\tptpProcessController.exe </ProcessController>
<Connection name="Dev">
<TransportLayer loadlib="socketTL" type="TPTP_SOCKET">
<Configuration>
<Port>10006</Port>
<SecurityEnabled>false</SecurityEnabled>
</Configuration>
<CommandExtractor>tptpCmdExtr</CommandExtractor>
</TransportLayer>
<TransportLayer loadlib="namedPipeTL" type="TPTP_LOG">
<Configuration>
<PipeName>acmasterlog</PipeName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="namedPipeTL" type="TPTP_NAMEDPIPE">
<Configuration>
<PipeName>acmaster</PipeName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="sharedMemTL" type="TPTP_SHAREDMEM">
<Configuration>
<MemName>acbuffer</MemName>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="tptpCCTL" type="TPTP_CCTL">
<Configuration>
<Port>10002</Port>
<SecuredPort>10003</SecuredPort>
<FilePort>10005</FilePort>
<IsDataMultiplexed>false</IsDataMultiplexed>
<ProcessPolling>true</ProcessPolling>
<Version>4.4.1</Version>
<Hosts configuration="default">
<Allow type="LOCAL"/>
</Hosts>
</Configuration>
</TransportLayer>
<TransportLayer loadlib="tptpACTL" type="TPTP_ACTL">
<Configuration/>
</TransportLayer>
</Connection>
<PeerConnectionTransport>TPTP_CCTL</PeerConnectionTransport >
</AgentControllerConfiguration>
Re: TPTP 4.5.2 installation problems [message #142472 is a reply to message #142450] |
Tue, 02 June 2009 18:31 |
Member |
I was able to activate logging, and I still get the same error, the log is
included below.
I started the test around 18:21, and the interesting message from the
agent controller seems to be "msg="RAC message was received, so
ignore."... any hint as to what the problem might be?
Thanks!
Franck
<CommonBaseEvent creationTime="2009-06-02T18:20:03.197000Z"
globalInstanceId="A8B5A625E79F4F24BBDD4A9B7CED4E2F"
msg="createTransportListener (socket)" severity="5" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\socketTL\socketListener.c,
line 915" instanceId="1000" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Socket TL" threadId="1816"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
globalInstanceId="A1DE48CD4F1943E4BB43E703E670BB5E" msg="Successfully
loaded transport layer: socketTL" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\ConnectionManager.c,
line 184" instanceId="2" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Connection Manager" threadId="1816"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.213000Z"
globalInstanceId="AB7BD738DA0D4C8A9B9F401BB6FE33F7" msg="Successfully
loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
line 235" instanceId="2" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A6A63AA4753246228127133BB2CFC30E"
msg="createTransportListener (named pipe)." severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c,
line 946" instanceId="1001" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A4C3E18DC94943BF8A473025F807B446" msg="Successfully
loaded transport layer: namedPipeTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A65F2C95987D4532BED8E92B1EBD5207" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A978FF143B0245DEAF62D67422B797C7"
line 946" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A41F913C43D64C1FBC38E214477A1FE7" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AB1E722734D34FC08466C2DA199B0CCB" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AF0711F8A5BD4BBC8574AB6F6FA070CF"
msg="createTransportListener (shared memory)." severity="5"
version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\SRC\TRANSPORT\sharedMemTL\sharedMemListener.c,
line 112" instanceId="1003" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Shared Memory TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A27EDC60C2F14A90A98E8B4C12701D07" msg="Successfully
loaded transport layer: sharedMemTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A19241E94535413F9A589A03ED31BB84" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A972F6A8EC3F4AC5B60573538ECBA5E0" msg="Process polling
thread created, tid = 108" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\ClientCTL.c,
line 1028" instanceId="1004" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Client Compatibility TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="AFE67482778249DC80E785EAE292B935" msg="Successfully
loaded transport layer: tptpCCTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="AA5150CBDF724F65B348CB1460404B7F" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="AA43663B7A2A415798BB041CFEC7B101" msg="ACTL process
purge thread created, tid = 3932" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPAgentCompTL\Connect2AC.c,
line 1369" instanceId="1005" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Compatibility TL" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A5A5B332986243C0A744C2BD16267CCF" msg="Successfully
loaded transport layer: tptpACTL" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A7D3886E75FD4C9E82FC302698A96269" msg="Successfully
</situation>
</CommonBaseEvent>
globalInstanceId="A1B64F0A86824DF5B68DE26AF9FD962B" msg="Ready to start
servers" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentController.c,
line 213" instanceId="0" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Core" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A380F2443BBC4E73A6A768FA942A56A7"
msg="startTransportListener (socket)" severity="5" version="1.0.1">
line 995" instanceId="1000" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A6F6CC0E24EB4C318A85CAE27752ABF8" msg="Named pipe server
is running and listening at "\\.\pipe\IBMAC\acmasterlog" pipe."
line 920" instanceId="1001" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="516"
</situation>
</CommonBaseEvent>
globalInstanceId="A5A72E4FE4AA47E6808E261424FD1DE0" msg="Ready to accept
next named pipe request." severity="5" version="1.0.1">
line 1105" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AC64DB6D735841B3B9D6B68EFE827959" msg="Named pipe server
is running and listening at "\\.\pipe\IBMAC\acmaster" pipe."
line 920" instanceId="1002" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Named Pipe TL" threadId="3008"
</situation>
</CommonBaseEvent>
globalInstanceId="A919F9332E4F407F989E3F44A781B6B1" msg="Ready to accept
line 1105" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AAC9EE34C4EA428D853D1AC428CE12B5" msg="ConnectionManger
- successfully added connectionID 100 for transportID 1004" severity="5"
version="1.0.1">
line 328" instanceId="2" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A974AA15CC454A6A8C9DA169FBF9FD77" msg="Shared memory
server is running and listening at "acbuffer" name."
line 326" instanceId="1003" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Shared Memory TL" threadId="496"
</situation>
</CommonBaseEvent>
globalInstanceId="AFB8F0CF0B6F42D18C8D0C9EE905A04C" msg="Client
compatibility transport layer received a command that that is recognized
(but unsupported). (iid: org.eclipse.tptp.eventProvider cmd:
listenerAccepted)" severity="5" version="1.0.1">
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPClientCompTL\Connect2AC.c,
line 2280" instanceId="1004" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.228000Z"
globalInstanceId="A38C0DFBD26B4478AB123D7A3F8EEE6D" msg="Native file
server started listening on port 10005" severity="10" version="1.0.1">
line 586" instanceId="1004" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A71CCF91A3654E2B8A53858E49B63336" msg="Socket server is
running at port number of 10006." severity="5" version="1.0.1">
line 827" instanceId="1000" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Socket TL" threadId="1884"
</situation>
</CommonBaseEvent>
globalInstanceId="A819D0D062D944CB89B87B66EC82CCA2" msg="Ready to accept
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\transport\TPTPAgentCompTL\ACTLServer.c,
line 449" instanceId="1005" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Compatibility TL" threadId="980"
</situation>
</CommonBaseEvent>
globalInstanceId="A52830B84CA64EF5881713AC00ED4044" msg="Starting Process
Controller:E:\ganymede\plugins\org.eclipse.tptp.platform.ac. win_ia32_4.4.100.v200902101418\agent_controller\bin\tptpProc essController.exe "
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agentController\AgentManager.c,
line 3095" instanceId="1" location="D5502H3J" locationType="IPV4"
processId="1584" subComponent="Agent Manager" threadId="1816"
</situation>
</CommonBaseEvent>
globalInstanceId="A26D3FB3CBA44403936BBFAF227DBE9E" msg="SUCCESSFULLY
started Process Controller (pid=1240)" severity="5" version="1.0.1">
line 3120" instanceId="1" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AD3C18C96E1047C2B4182426DAC2AE99" msg="Everything is
running" severity="5" version="1.0.1">
line 227" instanceId="0" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-02T18:20:03.275000Z"
globalInstanceId="AE558652294B445D8F78054DB7A92621" msg="Received(49
bytes)." severity="5" version="1.0.1">
line 854" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A86A3546F642473FA19463E6B9ECE9D3" msg="Validated message
of 49 bytes" severity="5" version="1.0.1">
line 770" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AC866C08507C4692A9780D362EA340D1" msg="ConnectionManger
- successfully added connectionID 101 for transportID 1002" severity="5"
version="1.0.1">
processId="1584" subComponent="Connection Manager" threadId="3008"
</situation>
</CommonBaseEvent>
globalInstanceId="A0DE14FE181A419A90E4E801BB1533AE" msg="NamedPipe
getInitRequestDataBlock: returning Connection ID: 101." severity="5"
version="1.0.1">
line 163" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AF8838E97F7E48B4BFED136E3033A355" msg="UUID:
e7a1a976-c6ea-4a66-abcc-074d3df9137c." severity="5" version="1.0.1">
line 441" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A2BCCFDBE0A7433C91E3C7314AA0457D" msg="NamedPipe: Sent
16 bytes on connection ID 101" severity="5" version="1.0.1">
line 222" instanceId="1002" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="AD6CF23B769C40E0A846B6D661B2C2EF" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A61906C72A644720AA29A6C92B5E841F" msg="Received(935
line 854" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A5333189D3BF4FC1B526B69D60AEE2BB" msg="Validated message
of 935 bytes" severity="5" version="1.0.1">
line 770" instanceId="1001" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="ABD56D1BFD1C4838A3F64BC3E1D30C3E" msg="Agent's
(ProcessController) connection id is - 101" severity="5" version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.2\TPTP-4.5.2-200902180100\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp,
line 1002" instanceId="101" location="D5502H3J" locationType="IPV4"
processId="1240" subComponent="ProcessController" threadId="2108"/>
<situationType reasoningScope="INTERNAL" reportCategory="LOG"
xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
globalInstanceId="A1E2DA39C5894F50922B5A11D943FE72" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A5536EB1235943F5B7E7581A67EC13EA" msg="Received(934
</situation>
</CommonBaseEvent>
globalInstanceId="AB22C7A0E3FF461E81EBA217E06C4517" msg="Validated message
of 934 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A9769A4D7CB34BD1935B025FB2ADD2C6" msg="Agent(101): Bytes
in msg left to be processed: 0 bytes." severity="5" version="1.0.1">
line 887" instanceId="101" location="D5502H3J" locationType="IPV4"
</situation>
</CommonBaseEvent>
globalInstanceId="A1F3BD4F804B46309B9A7F4BD13B16D7" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="A2C523E3C546448580E8398E7CDAC33C" msg="Received(945
</situation>
</CommonBaseEvent>
globalInstanceId="A349D887092445F18163F95C9C65764A" msg="Validated message
of 945 bytes" severity="5" version="1.0.1">
</situation>
</CommonBaseEvent>
globalInstanceId="A65DB44401D6469A8E5A65CEFC9F387C" msg="BaseAgent
registerFunc: Agent (ProcessController) connected to AC " severity="5"
version="1.0.1">
line 428" instanceId="101" location="D5502H3J" locationType="IPV4"
processId="1240" subComponent="ProcessController" threadId="3092"/>
</situation>
</CommonBaseEvent>
globalInstanceId="AB2E9D62E7B04046BAAB15D5E4A2BE11" msg="Ready to accept
</situation>
</CommonBaseEvent>
globalInstanceId="ABF0FCC6175A4F13941CE1B6A6DED63B" msg="Received(916
</situation>
</CommonBaseEvent>
globalInstanceId="A0EE52113AED48E6A9A9CBA46B7AB1FF" msg="Received(137
&l
Re: TPTP 4.5.2 installation problems [message #142521 is a reply to message #142511] |
Fri, 05 June 2009 16:56 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Franck,
Great news. Please add your Bugzilla ID to the CC list for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278655 if you are interested
in tracking the fix.
As for the slow test execution, what percentage of the test execution
(see the Progress view) takes the longest time? Is security enabled on the
Agent Controller? What JVM vendor/version are you using for the workbench
and Agent Controller?
Paul
"Franck " <franck102@yahoo.com> wrote in message
news:2cf8cf2e04c6f61ef6f2de46da908d46$1@www.eclipse.org...
> Paul Slauenwhite wrote:
>> Hi Franck,
>> What JVM vendor/version are you using for the workbench and Agent
>> Controller? I believe you are running into
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=278655 or something
>> similar. Can you confirm if there are any stray java.exe processes
>> running. If so, kill them, restart TPTP/Agent Controller, and run your
>> test again.
> Hi Paul,
> Thanks for the help, there was indeed a stray java process left behind,
> and even a stray eclipse process as well. Once I kill them the connection
> happens and the test completes.
> The only remaining issue is that the test takes 5mn to complete when the
> method itself should take a few seconds to run, but that is secondary.
> Franck
Re: TPTP 4.5.2 installation problems [message #142632 is a reply to message #142597] |
Wed, 10 June 2009 10:55 |
Hi Franck,
No, we have not seen this behavior. What vendor/version of JVM? We
test the script adapter every iteration using the following test (calls the
same class as automation-client-adapter.bat/cmd/sh):
http://dev.eclipse.org/viewcvs/index.cgi/test-results/test/o rg.eclipse.hyades.test.core.services.tests/src/org/eclipse/h yades/test/core/services/tests/shell/?root=TPTP_Project
I noticed that you are not passing in the service (see
org.eclipse.hyades.test.core.services.tests.shell.ShellAutom ationClientAdapterTest.testExecuteSampleJUnitTestOutOfProces s()):
org.eclipse.hyades.test.tools.core.execute
If the problem persists, please open a defect.
Paul
news:88dde31c28841df7f86d89304ebe5492$1@www.eclipse.org...
> Thanks Paul,
> That is what I feared, we have fairly large plug-in dependencies because
> we are integrating a legacy product into Eclipse, I guess we'll have to
> live with the [erformance for now.
> I ran into an unrelated issue today while trying to execute a unit test
> from a shell script as described in the documentation. Using this command
> line:
> java -Xms40m -Xmx512m -cp
> E:/ganymede/plugins/org.eclipse.hyades.execution_4.4.202.v20 0901200947/tptp-automation-client.jar
> org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
> -eclipse "E:/ganymede" -workspace e:/workspace -project project1 -suite
> project1/qa/src/test1.testsuite
> I get the OutOfMemoryError exception with the stack trace included below
> (the NoClassDefFound exceptions I think are all due to the
> OutOfMemoryException at the bottom of the stack trace).
> The interesting thing is that if I then try to open the workspace using
> the ganymede IDE, I get the same exception in the error log. The exception
> goes away if I shutdown the IDE and restart it, but any attempt to run a
> test from the command line makes it reappear.
> Short of putting the client under debugger I have no idea where to start
> looking, has anyone seen this before? This is with TPTP 4.5.2 from the
> Ganymede update site and Sun's JVM 6 on Windows, and that particular unit
> test runs fine using Run As in the IDE.
> Franck
> org.eclipse.core.runtime.CoreException: Plug-in
> org.eclipse.hyades.test.tools.core was unable to load class org.eclipse.
> hyades.test.tools.core.services.TestExecutionService.
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.j
> ava:162)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:2
> 43)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementH
> andle.java:51)
> at
> org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:87)
> at
> org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> Caused by:
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
> An error occu
> rred while automatically activating bundle org.eclipse.hyades.test.core
> (136).
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
> at
> ava:160)
> ... 22 more
> Caused by: org.osgi.framework.BundleException: Exception in
> org.eclipse.hyades.test.core.TestCorePlugin.start() of bundl
> e org.eclipse.hyades.test.core.
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> ... 34 more
> Caused by: java.lang.NoClassDefFoundError:
> org/eclipse/emf/ecore/resource/Resource$Factory$Registry
> at
> org.eclipse.hyades.test.core.TestCorePlugin.start(TestCorePl ugin.java:247)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
> ... 39 more
> Caused by:
> An error occu
> rred while automatically activating bundle org.eclipse.emf.ecore (71).
> at
> at
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
> at
> at
> at
> at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> ... 43 more
> org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.star
> t() of bundle org.eclipse.emf.ecore.
> at
> at
> at
> at
> at
> at
> ... 53 more
> org/eclipse/core/resources/ResourcesPlugin
> at
> org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.star t(EcorePlugin.java:520)
> at
> at
> ... 58 more
> Caused by:
> An error occu
> rred while automatically activating bundle org.eclipse.core.resources
> (51).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 62 more
> org.eclipse.core.resources.ResourcesPlugin.start() of bundle
> at
> at
> at
> at
> at
> at
> ... 72 more
> Caused by: java.lang.OutOfMemoryError: Java heap space
> at
> org.eclipse.core.internal.resources.Workspace.newElement(Wor kspace.java:1598)
> at
> org.eclipse.core.internal.resources.SaveManager.readElement( SaveManager.java:493)
> at
> org.eclipse.core.internal.watson.ElementTreeReader$1.readDat a(ElementTreeReader.java:62)
> at
> org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:80)
> at
> org.eclipse.core.internal.dtree.DataTreeReader.readNode(Data TreeReader.java:94)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.internal.dtree.DataTreeReader.readTree(Data TreeReader.java:135)
> at
> org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dTree(ElementTreeReaderImpl_1.java:102)
> at
> org.eclipse.core.internal.watson.ElementTreeReader.readTree( ElementTreeReader.java:123)
> at
> org.eclipse.core.internal.watson.ElementTreeReaderImpl_1.rea dDeltaChain(ElementTreeReaderImpl_1.java:84)
> at
> org.eclipse.core.internal.watson.ElementTreeReader.readDelta Chain(ElementTreeReader.java:96)
> at
> org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTrees(WorkspaceTreeReader_1.java:226)
> at
> org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:165)
> at
> org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:921)
> at
> org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:647)
> at
> org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1326)
> at
> org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1953)
> at
> org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1716)
> at
> org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:376)
> at
> at
> at
> at
Current Time: Sat May 04 23:25:12 GMT 2024
Powered by FUDForum. Page generated in 0.03734 seconds
