Re: Problem installing tptp [message #142433 is a reply to message #142326] |
Mon, 01 June 2009 20:53 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Dan,
JVM 1.6 is not supported by TPTP 4.1.0. Please check out JRE support stmt of
each TPTP download for the right JVM version to use. The latest TPTP releave
4.5.2 supports JVM 1.6.
Eugene
"dan " <okeeffdb@yahoo.co.uk> wrote in message
news:70e5ef5e0abcddf01d05f7a78d8bb4c1$1@www.eclipse.org...
> Hey all,
> I'm trying to install tptp to work with eclipse. I installed tptp via the
> eclipse update manager, and installed the agent controller and native
> logger
> manually as per the instructions given here:
> http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide42.html
> The problem arises when I try to run a profile of a java application in
> eclipse. It basically fails to start properly, and prints the error
> message
> below to the command line every 30 seconds or so.
> I'm using eclipse version 3.2.2, java 1.6.0_01, agent controller in
> tptpdc.linux_ia32-TPTP-4.1.0.zip, logger in cbe.linux_ia32-TPTP-4.1.0.zip.
> One question I have relates to the install of the logger. The instructions
> don't mention whether a pointer to the .so file it contains should be set
> in my environment. I have an entry in my PATH at the moment, but I'm not
> sure that is what is required.
> Any help much appreciated.
> Dan
> The error message given was:
> Exception in thread
> "org.eclipse.hyades.execution.core.task.ReusableThread@12f5f88"
> at
> org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.versionIsAtLeast(AgentControllerDescriptor.java:67)
> at
> org.eclipse.hyades.execution.local.util.AgentControllerDescr iptor.isVersionAtLeast(AgentControllerDescriptor.java:194)
> at
> org.eclipse.hyades.execution.local.file.FileManagerFactory$3 .run(FileManagerFactory.java:414)
> at
> org.eclipse.hyades.execution.core.task.ReusableThread.run(Re usableThread.java:131)
> at java.lang.Thread.run(Thread.java:619)
FUDForum. Page generated in 0.03573 seconds
