Home » Modeling » EMF » [CDO] Questions regarding the new offline/failover example
[CDO] Questions regarding the new offline/failover example [message #978201] |
Fri, 09 November 2012 22:46 |
Cristian Spiescu Messages: 100 Registered: July 2009 |
First of all thanks Eike for the new offline/failover RCP example.
My question: when the client goes offline and it commits a transaction, then an offline branch is created. On reconnection: can I merge the offline branch with the initial branch, from the main server?
I have noticed a few issues with the example:
* the node directory is missing from the client project, which prevents starting the launch config. I have created it manually and it worked.
* with the initial launch configuration (after modifying it with "Add Required Plugins"): opening a CDO editor for a resource failed, throwing this:
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException: can't find IDadditions
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
Caused by: java.lang.IllegalArgumentException: can't find IDadditions
at org.eclipse.jface.action.ContributionManager.insertAfter(ContributionManager.java:334)
at org.eclipse.jface.action.SubContributionManager.insertAfter(SubContributionManager.java:159)
at org.eclipse.emf.cdo.internal.ui.editor.CDOActionBarContributor.contributeToMenu(CDOActionBarContributor.java:242)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:167)
at org.eclipse.emf.edit.ui.action.EditingDomainActionBarContributor.init(EditingDomainActionBarContributor.java:139)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)
at org.eclipse.ui.internal.EditorReference.createEditorActionBars(EditorReference.java:405)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:320)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 76 more
[ERROR] NullPointerException
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3087)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:2996)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2978)
I'm new to e4, so I don't really understand what's going on. However, I have modified the launch config so that it includes all plugins from the target eclipse install, and the problem was solved.
Cristian.
Re: [CDO] Questions regarding the new offline/failover example [message #978463 is a reply to message #978201] |
Sat, 10 November 2012 03:59 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Am 09.11.2012 23:46, schrieb Cristian Mising name:<br>
<blockquote cite="mid:k7k14u$ije$1@xxxxxxxxe.org" type="cite">Hello,
<br>
<br>
<br>
</blockquote>
You've found it! It's not not 100% finished, yet. I'm still working
on one bug in the core (related to switching the view/transaction
target/branch) that I uncovered with the new example suite. I plan
to write a blog about the example this weekend when I'm done ;-)<br>
<br>
<br>
main server?
<br>
</blockquote>
Yes, but it requires the pending changes I mentioned above. From my
local workspace I can already do this:<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12247" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12248" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12249" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12250" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12251" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
How have you created the example? By checking it out from Git or by
using the example installer wizard?<br>
<br>
<blockquote cite="mid:k7k14u$ije$1@xxxxxxxxe.org" type="cite">*
<br>
<br>
<br>
<br>
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)<br>
at
org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)<br>
<br>
IDadditions
<br>
at
org.eclipse.jface.action.ContributionManager.insertAfter(ContributionManager.java:334)<br>
at
org.eclipse.jface.action.SubContributionManager.insertAfter(SubContributionManager.java:159)<br>
at
org.eclipse.emf.cdo.internal.ui.editor.CDOActionBarContributor.contributeToMenu(CDOActionBarContributor.java:242)<br>
at
org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:167)<br>
at
org.eclipse.emf.edit.ui.action.EditingDomainActionBarContributor.init(EditingDomainActionBarContributor.java:139)<br>
at
org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)<br>
at
org.eclipse.ui.internal.EditorReference.createEditorActionBars(EditorReference.java:405)<br>
at
org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:320)<br>
at
org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)<br>
<br>
<br>
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
<br>
<br>
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)<br>
... 76 more
<br>
<br>
<br>
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3087)<br>
at
<br>
at
<br>
<br>
</blockquote>
Hmm, hard to tell whether this is an e4 compatibility layer issue or
something else. A big part of my example suite effort was to free
our cdo.ui plugin from IDE dependencies, e.g., RCP'ify the
CDOEditor. Maybe you need to update your code. I'm still
committing/pushing every once in a day.<br>
<br>
solved.
<br>
</blockquote>
I know this is nasty but I don't have a better approach. Especially
because the example apps are really one app. They share the same
code and launch config. That's why I tried to minimize the plugins
in the launch. I'll keep this in mind and write an extra bold hint
to the readme that will pop up after the example installer wizard.<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
Attachment: efifieii.png
(Size: 50.12KB, Downloaded 244 times) -
Attachment: caefhcbi.png
(Size: 39.31KB, Downloaded 239 times) -
Attachment: agbfjice.png
(Size: 40.98KB, Downloaded 274 times) -
Attachment: hedjbaia.png
(Size: 40.00KB, Downloaded 242 times) -
Attachment: ebjahhic.png
(Size: 38.52KB, Downloaded 236 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978468 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12252" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12253" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12254" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12255" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12256" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 232 times) -
(Size: 39.31KB, Downloaded 242 times) -
(Size: 40.98KB, Downloaded 221 times) -
(Size: 40.00KB, Downloaded 244 times) -
(Size: 38.52KB, Downloaded 226 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978473 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12257" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12258" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12259" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12260" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12261" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 233 times) -
(Size: 39.31KB, Downloaded 249 times) -
(Size: 40.98KB, Downloaded 239 times) -
(Size: 40.00KB, Downloaded 246 times) -
(Size: 38.52KB, Downloaded 242 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978478 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12262" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12263" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12264" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12265" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12266" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 226 times) -
(Size: 39.31KB, Downloaded 232 times) -
(Size: 40.98KB, Downloaded 235 times) -
(Size: 40.00KB, Downloaded 229 times) -
(Size: 38.52KB, Downloaded 228 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978483 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12267" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12268" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12269" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12270" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12271" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 235 times) -
(Size: 39.31KB, Downloaded 236 times) -
(Size: 40.98KB, Downloaded 216 times) -
(Size: 40.00KB, Downloaded 241 times) -
(Size: 38.52KB, Downloaded 218 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978488 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12272" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12273" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12274" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12275" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12276" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 229 times) -
(Size: 39.31KB, Downloaded 228 times) -
(Size: 40.98KB, Downloaded 224 times) -
(Size: 40.00KB, Downloaded 216 times) -
(Size: 38.52KB, Downloaded 235 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978493 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12277" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12278" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12279" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12280" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12281" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 239 times) -
(Size: 39.31KB, Downloaded 222 times) -
(Size: 40.98KB, Downloaded 237 times) -
(Size: 40.00KB, Downloaded 239 times) -
(Size: 38.52KB, Downloaded 245 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978498 is a reply to message #978201] |
<html>
<head>
</head>
<br>
<br>
<br>
</blockquote>
<br>
<br>
main server?
<br>
</blockquote>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12282" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12283" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12284" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12285" alt=""><br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=12286" alt=""><br>
<br>
<br>
<br>
<br>
and it worked.<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
at
at
<br>
IDadditions
<br>
at
at
at
at
at
at
at
at
at
<br>
<br>
Source)
<br>
<br>
at
... 76 more
<br>
<br>
<br>
at
at
<br>
at
<br>
<br>
</blockquote>
<br>
solved.
<br>
</blockquote>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
(Size: 50.12KB, Downloaded 231 times) -
(Size: 39.31KB, Downloaded 248 times) -
(Size: 40.98KB, Downloaded 222 times) -
(Size: 40.00KB, Downloaded 245 times) -
(Size: 38.52KB, Downloaded 239 times)
Cheers
/Eike
Re: [CDO] Questions regarding the new offline/failover example [message #978704 is a reply to message #978201] |
Sat, 10 November 2012 08:39 |
Thanks Eike.
I have downloaded the new version, and it works great!
I'm looking forward to your blog post.
I have noticed an issue yesterday (in the previous version and this one as well), regarding the existing examples master/clone. Maybe you are already aware of it, but if not, I past the log details.
The clone repository, continuously opens sessions:
Opened Session2 [repo1]
Opened Session3 [repo1]
Opened Session4 [repo1]
Opened Session5 [repo1]
Opened Session6 [repo1]
And the server keeps showing this:
TCPSelector [debug] Reading java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371]
TCPSelector [debug.buffer] Obtained Buffer@16[INITIAL]
TCPSelector [debug.buffer] Read 12 bytes
05 00 10 00 00 00 0b 00 03 63 64 6f
TCPSelector [debug.lifecycle] Activating SignalProtocol[cdo]
TCPSelector [debug.lifecycle.dump] DUMP CDOServerProtocol
Protocol.type = cdo
Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@66daad3a[Running, pool size = 1, active threads = 0, queued tasks = 0, completed tasks = 45]
Protocol.bufferProvider = Channel[-32,768, SERVER]
Protocol.infraStructure = null
Protocol.channel = Channel[-32,768, SERVER]
Protocol.userID = null
SignalProtocol.timeout = 10000
SignalProtocol.streamWrapper = null
SignalProtocol.signals =
SignalProtocol.nextCorrelationID = 1
SignalProtocol.failingOver = false
negotiationTimeout = 15000
repositoryProvider = org.eclipse.emf.cdo.spi.server.PluginRepositoryProvider@2ee5d3df
packageURICompressor = StringCompressor[client=false]
TCPSelector [debug.connector] Opening channel with protocol cdo
TCPSelector [debug.lifecycle] Activating Channel[16, SERVER, cdo]
TCPSelector [debug.lifecycle] Activating ReceiveSerializer
TCPSelector [debug.lifecycle.dump] DUMP ReceiveSerializer
Worker.daemon = true
Worker.activationTimeout = 10000
Worker.deactivationTimeout = 10000
QueueWorker.queue =
QueueWorker.pollMillis = 100
TCPSelector [debug.lifecycle.dump] DUMP Channel
userID = null
channelMultiplexer = TCPServerConnector[127.0.0.1:60,371]
id = 16
receiveExecutor = java.util.concurrent.ThreadPoolExecutor@66daad3a[Running, pool size = 1, active threads = 0, queued tasks = 0, completed tasks = 45]
receiveHandler = SignalProtocol[cdo]
receiveSerializer = ReceiveSerializer
sendQueue =
sentBuffers = 0
receivedBuffers = 0
TCPSelector [debug.buffer] Created Buffer@17[INITIAL]
TCPSelector [debug.buffer] Obtained Buffer@17[INITIAL]
TCPSelector [debug.channel] Handling buffer: Buffer@17[PUTTING] --> Channel[Control, SERVER]
TCPSelector [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371] = true
TCPSelector [debug.buffer] Retaining Buffer@16[RELEASED]
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371] = true
TCPSelector [debug] Setting interest READ|WRITE (was read)
TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371]
TCPSelector [debug.buffer] Writing 5 bytes
03 00 10 00 00
TCPSelector [debug.buffer] Retaining Buffer@17[RELEASED]
TCPSelector [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371] = false
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371] = false
TCPSelector [debug] Setting interest READ (was read|write)
TCPSelector [debug.buffer] Read 27 bytes (EOS)
00 00 00 01 00 01 00 00 00 01 00 00 00 0a 01 00 05 72 65 70 6f 31 00 00 01 7c 7c
TCPSelector [debug.channel] Handling buffer from multiplexer: Buffer@16[GETTING] --> Channel[16, SERVER, cdo]
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Received buffer for correlation 1
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Got signalID: 1
net4j-Thread-1 [debug.signal] ================ Indicating: Signal[protocol=cdo, id=1, name=OpenSessionIndication, correlation=-1]
net4j-Thread-1 [debug.protocol] Read repositoryName: repo1
net4j-Thread-1 [debug.protocol] Read userID: null
net4j-Thread-1 [debug.protocol] Read passiveUpdateEnabled: true
net4j-Thread-1 [debug.protocol] Read passiveUpdateMode: ADDITIONS
net4j-Thread-1 [debug.buffer] Retaining Buffer@16[RELEASED]
net4j-Thread-1 [debug.protocol] Read lockNotificationMode: ALWAYS
net4j-Thread-1 [debug.signal] ================ Responding: Signal[protocol=cdo, id=1, name=OpenSessionIndication, correlation=-1]
net4j-Thread-1 [debug.session] Opening session 17
net4j-Thread-1 [debug.lifecycle] Activating Session[17]
net4j-Thread-1 [debug.lifecycle.dump] DUMP Session
ShareableLifecycle.refCount = null
manager = SessionManager
protocol = SignalProtocol[cdo]
sessionID = 17
userID = null
passiveUpdateEnabled = true
passiveUpdateMode = INVALIDATIONS
lockNotificationMode = IF_REQUIRED_BY_VIEWS
lastUpdateTime = 0
views =
lastTempViewID = 0
subscribed = false
net4j-Thread-1 [debug.protocol] Writing sessionID: 17
net4j-Thread-1 [debug.buffer] Obtained Buffer@17[INITIAL]
net4j-Thread-1 [debug.protocol] Writing userID: null
net4j-Thread-1 [debug.protocol] Writing repositoryUUID: repo1
net4j-Thread-1 [debug.protocol] Writing CDOIDObject of subtype 4 (UUID)
net4j-Thread-1 [debug.protocol] Writing 3 package units
net4j-Thread-1 [debug] Writing CDOPackageUnit[id=http://www.eclipse.org/emf/2002/Ecore, state=LOADED, type=LEGACY, originalType=LEGACY, timeStamp=2012-11-10 09:28:09.691]
net4j-Thread-1 [debug] Writing CDOPackageInfo[packageURI=http://www.eclipse.org/emf/2002/Ecore, parentURI=null]
net4j-Thread-1 [debug] Writing CDOPackageUnit[id=http://www.eclipse.org/emf/CDO/Eresource/4.0.0, state=LOADED, type=NATIVE, originalType=NATIVE, timeStamp=2012-11-10 09:28:09.691]
net4j-Thread-1 [debug] Writing CDOPackageInfo[packageURI=http://www.eclipse.org/emf/CDO/Eresource/4.0.0, parentURI=null]
net4j-Thread-1 [debug] Writing CDOPackageUnit[id=http://www.eclipse.org/emf/CDO/Etypes/4.0.0, state=LOADED, type=NATIVE, originalType=NATIVE, timeStamp=2012-11-10 09:28:09.691]
net4j-Thread-1 [debug] Writing CDOPackageInfo[packageURI=http://www.eclipse.org/emf/CDO/Etypes/4.0.0, parentURI=null]
net4j-Thread-1 [debug.channel] Handling buffer: Buffer@17[PUTTING] --> Channel[16, SERVER, cdo]
net4j-Thread-1 [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:60371] = true
TCPSelector [debug.buffer] Writing 300 bytes (EOS)
00 00 00 00 00 00 00 11 00 01 00 05 72 65 70 6f 31 00 7e 7b 01 00 02 64 62 00 00 00 00 01 7a 00 00 01 3a 16 6e 1b 5b 00 00 01 3a 16 6e 1b 5b 04 00 00 00 10 70 30 29 50 2b 10 11 1d 7d 6f 43 68 0e 32 08 4a 01 01 00 00 00 7d 00 00 00 03 00 01 00 00 01 3a 16 6e 1b 5b 00 00 00 01 7f 00 00 00 00 00 00 00 02 01 00 25 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 32 30 30 32 2f 45 63 6f 72 65 00 01 00 00 00 00 00 00 00 00 01 3a 16 6e 1b 5b 00 00 00 01 7f 00 00 00 00 00 00 01 02 01 00 2e 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 00 01 00 00 00 00 00 00 00 00 01 3a 16 6e 1b 5b 00 00 00 01 7f 00 00 00 00 00 00 02 02 01 00 2b 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 74 79 70 65 73 2f 34 2e 30 2e 30 00 01 00 00 00 00
TCPSelector [debug.buffer] Read 6 bytes (EOS)
00 00 00 02 00 17
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Received buffer for correlation 2
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Got signalID: 23
net4j-Thread-1 [debug.signal] ================ Indicating: Signal[protocol=cdo, id=23, name=RepositoryTimeIndication, correlation=-2]
net4j-Thread-1 [debug.signal] ================ Responding: Signal[protocol=cdo, id=23, name=RepositoryTimeIndication, correlation=-2]
net4j-Thread-1 [debug.protocol] Writing indicated: 2012-11-10 09:29:01.605
net4j-Thread-1 [debug.protocol] Writing responded: 2012-11-10 09:29:01.605
TCPSelector [debug.buffer] Writing 20 bytes (EOS)
00 00 00 01 00 00 01 3a 16 6f 50 25 00 00 01 3a 16 6f 50 25
TCPSelector [debug.buffer] Read 26 bytes (EOS)
00 00 00 03 00 2b 00 00 00 01 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00 00
TCPSelector [debug.channel] Handling buffer from multiplexer: Buffer@17[GETTING] --> Channel[16, SERVER, cdo]
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Received buffer for correlation 3
Net4jReceiveSerializer-Channel[16, SERVER, cdo] [debug.signal] Got signalID: 43
net4j-Thread-1 [debug.signal] ================ Indicating: Signal[protocol=cdo, id=43, name=ReplicateRepositoryRawIndication, correlation=-3]
net4j-Thread-1 [debug.buffer] Retaining Buffer@17[RELEASED]
net4j-Thread-1 [debug.signal] ================ Responding: Signal[protocol=cdo, id=43, name=ReplicateRepositoryRawIndication, correlation=-3]
net4j-Thread-1 [debug.sql] SELECT id, name, base_id, base_time FROM cdo_branches WHERE id BETWEEN 1 AND 0
net4j-Thread-1 [debug.sql] SELECT commit_time, previous_time, branch_id, user_id, commit_comment FROM cdo_commit_infos WHERE commit_time BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT id, user_id, view_branch, view_time, read_only FROM cdo_lock_areas
net4j-Thread-1 [debug.sql] SELECT area_id, object_id, lock_grade FROM cdo_locks
net4j-Thread-1 [debug.sql] SELECT p_u.id, p_u.original_type, p_u.time_stamp, p_u.package_data FROM cdo_package_units p_u WHERE p_u.id<>'http://www.eclipse.org/emf/2002/Ecore' AND p_u.id<>'http://www.eclipse.org/emf/CDO/Eresource/4.0.0' AND p_u.id<>'http://www.eclipse.org/emf/CDO/Etypes/4.0.0' AND p_u.time_stamp BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT p_i.uri, p_i.parent, p_i.unit FROM cdo_package_infos p_i, cdo_package_units p_u WHERE p_u.id<>'http://www.eclipse.org/emf/2002/Ecore' AND p_u.id<>'http://www.eclipse.org/emf/CDO/Eresource/4.0.0' AND p_u.id<>'http://www.eclipse.org/emf/CDO/Etypes/4.0.0' AND p_u.time_stamp BETWEEN 1 AND 1352536089691 AND p_i.unit=p_u.id
net4j-Thread-1 [debug.sql] SELECT "a_t".cdo_id, "a_t".cdo_version, "a_t".cdo_branch, "a_t".cdo_created, "a_t".cdo_revised, "a_t".cdo_resource, "a_t".cdo_container, "a_t".cdo_feature, "a_t".folder, "a_t".name, "a_t".contents, "a_t".encoding FROM eresource_CDOTextResource "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT "a_t".cdo_id, "a_t".cdo_version, "a_t".cdo_branch, "a_t".cdo_created, "a_t".cdo_revised, "a_t".cdo_resource, "a_t".cdo_container, "a_t".cdo_feature, "a_t".folder, "a_t".name, "a_t".contents FROM eresource_CDOBinaryResource "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT "a_t".cdo_id, "a_t".cdo_version, "a_t".cdo_branch, "a_t".cdo_created, "a_t".cdo_revised, "a_t".cdo_resource, "a_t".cdo_container, "a_t".cdo_feature, "a_t".folder, "a_t".name, "a_t".contents FROM eresource_CDOResource "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM eresource_CDOResource_contents_list "l_t", eresource_CDOResource "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT "a_t".cdo_id, "a_t".cdo_version, "a_t".cdo_branch, "a_t".cdo_created, "a_t".cdo_revised, "a_t".cdo_resource, "a_t".cdo_container, "a_t".cdo_feature, "a_t".source, "a_t".modelElement, "a_t".annotations, "a_t".details, "a_t".contents, "a_t".references0 FROM etypes_Annotation "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM etypes_Annotation_annotations_list "l_t", etypes_Annotation "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM etypes_Annotation_details_list "l_t", etypes_Annotation "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM etypes_Annotation_contents_list "l_t", etypes_Annotation "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM etypes_Annotation_references_list "l_t", etypes_Annotation "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT "a_t".cdo_id, "a_t".cdo_version, "a_t".cdo_branch, "a_t".cdo_created, "a_t".cdo_revised, "a_t".cdo_resource, "a_t".cdo_container, "a_t".cdo_feature, "a_t".folder, "a_t".name, "a_t".nodes FROM eresource_CDOResourceFolder "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691
net4j-Thread-1 [debug.sql] SELECT "l_t".cdo_source, "l_t".cdo_branch, "l_t".cdo_version, "l_t".cdo_idx, "l_t".cdo_value FROM eresource_CDOResourceFolder_nodes_list "l_t", eresource_CDOResourceFolder "a_t" WHERE "a_t".cdo_created BETWEEN 1 AND 1352536089691 AND "a_t".cdo_id="l_t".cdo_source AND "a_t".cdo_version="l_t".cdo_version AND "a_t".cdo_branch="l_t".cdo_branch
net4j-Thread-1 [debug.sql] SELECT cdo_id, cdo_class, cdo_created FROM cdo_objects WHERE cdo_created BETWEEN 1 AND 1352536089691
TCPSelector [debug.buffer] Writing 714 bytes (EOS)
00 00 00 02 00 00 00 00 00 00 01 3a 16 6e 1b 5b 00 00 00 00 00 00 00 01 01 00 00 01 3a 16 6e 1b 5b 01 00 00 01 3a 16 6e 1b 5b 01 00 00 00 00 01 00 0a 43 44 4f 5f 53 59 53 54 45 4d 00 01 00 0c 3c 69 6e 69 74 69 61 6c 69 7a 65 3e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 7f 00 00 00 00 00 00 03 02 01 00 3e 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 23 43 44 4f 54 65 78 74 52 65 73 6f 75 72 63 65 00 01 00 00 00 00 7f 00 00 00 00 00 00 04 02 01 00 40 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 23 43 44 4f 42 69 6e 61 72 79 52 65 73 6f 75 72 63 65 00 01 00 00 00 00 7f 00 00 00 00 00 00 05 02 01 00 3a 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 23 43 44 4f 52 65 73 6f 75 72 63 65 00 01 00 00 00 01 01 00 18 40 5f 6a 38 5f 57 55 43 73 51 45 65 4b 43 62 37 79 58 44 6a 4c 33 53 67 00 00 00 00 01 00 00 00 00 00 00 01 3a 16 6e 1b 5b 00 00 00 00 00 00 00 00 01 00 18 40 5f 6a 38 5f 57 55 43 73 51 45 65 4b 43 62 37 79 58 44 6a 4c 33 53 67 00 01 00 01 30 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 7f 00 00 00 00 00 00 06 02 01 00 36 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 74 79 70 65 73 2f 34 2e 30 2e 30 23 41 6e 6e 6f 74 61 74 69 6f 6e 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 00 00 00 00 00 00 07 02 01 00 40 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 23 43 44 4f 52 65 73 6f 75 72 63 65 46 6f 6c 64 65 72 00 01 00 00 00 00 00 00 00 00 00 00 00 01 01 00 18 40 5f 6a 38 5f 57 55 43 73 51 45 65 4b 43 62 37 79 58 44 6a 4c 33 53 67 00 01 00 3c 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 45 72 65 73 6f 75 72 63 65 2f 34 2e 30 2e 30 23 2f 2f 43 44 4f 52 65 73 6f 75 72 63 65 00 01 00 00 01 3a 16 6e 1b 5b
Cristian.
Re: [CDO] Questions regarding the new offline/failover example [message #979929 is a reply to message #978704] |
Sun, 11 November 2012 07:29 |
Am 10.11.2012 09:39, schrieb Cristian Mising name:
> Thanks Eike.
I can not reproduce this here. Do you suspect an actual problem?
Cheers
/Eike
> 05 00 10 00 00 00 0b 00 03 63 64 6f TCPSelector [debug.lifecycle] Activating SignalProtocol[cdo]
> Protocol.type = cdo
> SignalProtocol.signals = SignalProtocol.nextCorrelationID = 1
> QueueWorker.queue = QueueWorker.pollMillis = 100
> userID = null
> id = 16
> sendQueue = sentBuffers = 0
> receivedBuffers = 0
> 03 00 10 00 00 TCPSelector [debug.buffer] Retaining Buffer@17[RELEASED]
> 00 00 00 01 00 01 00 00 00 01 00 00 00 0a 01 00 05 72 65 70 6f 31 00 00 01 7c 7c TCPSelector [debug.channel] Handling
> correlation=-1]
> correlation=-1]
> sessionID = 17
> userID = null
> lastUpdateTime = 0
> views = lastTempViewID = 0
> subscribed = false
> 2f 65 6d 66 2f 43 44 4f 2f 45 74 79 70 65 73 2f 34 2e 30 2e 30 00 01 00 00 00 00 TCPSelector [debug.buffer] Retaining
> Buffer@17[RELEASED]
> 00 00 00 02 00 17 TCPSelector [debug.channel] Handling buffer from multiplexer: Buffer@16[GETTING] --> Channel[16,
> SERVER, cdo]
> correlation=-2]
> correlation=-2]
> 00 00 00 01 00 00 01 3a 16 6f 50 25 00 00 01 3a 16 6f 50 25 TCPSelector [debug.buffer] Retaining Buffer@17[RELEASED]
> 00 00 00 03 00 2b 00 00 00 01 00 00 00 0a 00 00 00 00 00 00 00 00 00 00 00 00 TCPSelector [debug.channel] Handling
> 1352536089691
> 63 65 00 01 00 00 01 3a 16 6e 1b 5b TCPSelector [debug.buffer] Retaining Buffer@17[RELEASED]
> Best regards,
> Cristian.
Cheers
/Eike
Current Time: Sat Apr 27 02:53:08 GMT 2024
Powered by FUDForum. Page generated in 0.04383 seconds
