Home » Archived » BIRT » DocumentProcessor.getPageNumber():'Invalid page number' BUG#126660
DocumentProcessor.getPageNumber():'Invalid page number' BUG#126660 [message #140465] Tue, 07 March 2006 06:09 Go to next message
I'd like to get a complete explaination on the way to fix this problem.
I'm also having the same exception in
DocumentProcessor.getPageNumber:'Invalid page number'. (the exception only
occurs when viewing the parameters frameset. the __run url works fine)
My report was build with 2.0.1 designer and the exception occured when
viewing in 2.01 or 2.1M5 viewer.
What do I need to do to view a report older than 2.0.0 with parameters
frameset?
Where is the 'report document page number'?
What do you mean by 'delete the old report document file and try
again'.(see BUG#126660 comments)
Tx. (I need to use a production release, not the 2.1M5)
Re: DocumentProcessor.getPageNumber():'Invalid page number' BUG#126660 [message #140869 is a reply to message #140465] Tue, 07 March 2006 11:22 Go to previous messageGo to next message
Can we learn more over the generation of the parameters frame?
Is it a way to modify this.
Is there another way to enter parameters (with an input field and a submit
button on the report)?
Gilles
HELP! Re: DocumentProcessor.getPageNumber():'Invalid page number' BUG#126660 [message #141531 is a reply to message #140869] Wed, 08 March 2006 09:29 Go to previous messageGo to next message
Could someone let me know if a solution exists?
Tx,
Gilles
Re: DocumentProcessor.getPageNumber():'Invalid page number' BUG#126660 [message #363315 is a reply to message #140465] Wed, 18 June 2008 09:08 Go to previous message
I am currently having a problem with BIRT's web viewer in version 2.2.2 that
seems to match the description of the bug reported below
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=126660)
The report works just fine with the run servlet but fails with frameset
servlet saying "invalid page number -1 of 1"
Is there a known solution to this problem?
Jose
"Gilles" <gilles.vandaele@axa.be> wrote in message
news:a30619b543a59f3a6fe7eba1832ab836$1@www.eclipse.org...
> frameset?
Previous Topic:Property background-color does not work as inline style when creating a PDF
Next Topic:Chart - Null data points in a Line Chart
Current Time: Sun Nov 09 17:19:47 EST 2025
Powered by FUDForum. Page generated in 0.03674 seconds
