Re: NPE in AutomationClientAdapter [message #140408 is a reply to message #140399] |
Wed, 18 February 2009 10:17 |
Juergen Aschenbrenner Messages: 25 Registered: July 2009 |
--------------060606000003010604080608
My feeling is that I can prevent this error from happening if I delete
this workspaces meta forlder.
Though I get a different not always satisfying behaviour:
If I run the ant script from within eclipse but in a different JRE it
runs smothly (verification, execution, interogation)
If I run the ant script from within eclipse using the workspace JRE
execution fails throwing the stack trace below
The NPE seems to be caused by a not set *properties* field which should
be done in the init operation of the AutomationClientAdapter.
There is something in the workspace log (see attachment) what I am no be
able to correlate to the output of the console ?!
/Juergen
Apache Ant version 1.7.0 compiled on December 13 2006
Buildfile: C:\Workspaces\Continous\com.jasche.tptp.update\foo.xml
parsing buildfile C:\Workspaces\Continous\com.jasche.tptp.update\foo.xml
with URI = file:/C:/Workspaces/Continous/com.jasche.tptp.update/foo.xml
Project base dir set to: C:\Workspaces\Continous\com.jasche.tptp.update
[antlib:org.apache.tools.ant] Could not load definitions from resource
org/apache/tools/ant/antlib.xml. It could not be found.
Arguments: -v -Dorg.eclipse.ant.core.ANT_PROCESS_ID=1234951410154
Build sequence for target(s) `test-execution' is [test-execution]
Complete build sequence is [test-execution, ]
test-execution:
dropping c:\Users\jasche\.ant\lib\ant-tptp.jar from path as it doesn't exist
parsing buildfile
bundleresource://325/org/eclipse/hyades/automation/client/ad apters/ant/antlib.xml
with URI =
parsing buildfile
bundleresource://325:1/org/eclipse/hyades/automation/client/ adapters/ant/antlib.xml
with URI =
parsing buildfile
jar:file:C:/java/test/eclipse/plugins/org.eclipse.hyades.exe cution_4.4.201.v200808111750/ant-tptp.jar!/org/eclipse/hyade s/automation/client/adapters/ant/antlib.xml
with URI =
[echo] Executing test
suite...'C:\Workspaces\Continous\com.jasche.tptp.anothertest '
parsing buildfile
with URI =
parsing buildfile
with URI =
parsing buildfile
with URI =
BUILD FAILED
C:\Workspaces\Continous\com.jasche.tptp.update\foo.xml:17:
at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:115)
at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:13 4)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
at
org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:247)
at
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Automation.addConfiguredProperty(AutomationCli entAdapter.java:119)
at
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Automation.addProperty(AutomationClientAdapter .java:176)
at
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Automation.addProperty(AutomationClientAdapter .java:131)
at
org.eclipse.hyades.automation.client.adapters.ant.Automation ClientAdapter$Execution.execute(AutomationClientAdapter.java :591)
at
... 24 more
--- Nested Exception ---
at
at
at
at
at
at
at
at
at
at
at
Total time: 444 milliseconds
name=".log"
Content-Disposition: inline;
filename=".log"
!SESSION 2009-02-18 11:01:50.609 -----------------------------------------------
eclipse.buildId=I20080617-2000
java.version=1.6.0_10-rc
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.hyades.execution.server
Command-line arguments: -os win32 -ws win32 -arch x86 -application org.eclipse.hyades.execution.server -data C:\Workspaces\Continous
!ENTRY org.eclipse.core.resources 2 10035 2009-02-18 11:01:52.843
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:04.116
!MESSAGE Can't find bundle for base name feature, locale de_DE
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:05.118
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:06.072
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:06.112
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:06.246
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:06.313
!ENTRY org.eclipse.update.configurator 4 0 2009-02-18 11:02:06.544
!ENTRY org.eclipse.osgi 4 0 2009-02-18 11:02:28.304
!MESSAGE An error occurred while automatically activating bundle org.eclipse.debug.ui (62).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.core.internal.variables.DynamicVariable.getValue (DynamicVariable.java:47)
at org.eclipse.core.internal.variables.StringSubstitutionEngine .resolve(StringSubstitutionEngine.java:267)
at org.eclipse.core.internal.variables.StringSubstitutionEngine .substitute(StringSubstitutionEngine.java:192)
at org.eclipse.core.internal.variables.StringSubstitutionEngine .performStringSubstitution(StringSubstitutionEngine.java:86)
at org.eclipse.core.internal.variables.StringVariableManager.pe rformStringSubstitution(StringVariableManager.java:567)
at org.eclipse.core.internal.variables.StringVariableManager.pe rformStringSubstitution(StringVariableManager.java:350)
at org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIExecOb jAdapter.setupExecutableObject(AutoGUIExecObjAdapter.java:10 5)
at org.eclipse.hyades.execution.harness.util.ExecutionAdapterUt ilities.adaptExecutableObject(ExecutionAdapterUtilities.java :96)
at org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2001)
at org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$1(TestExecutionHarness.java:1810)
at org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:730)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.debug.internal.ui.contextlaunching.LaunchingReso urceManager.startup(LaunchingResourceManager.java:528)
at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingReso urceManager(DebugUIPlugin.java:305)
at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlu gin.java:502)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 32 more
Root exception:
--------------060606000003010604080608--
Re: NPE in AutomationClientAdapter [message #140422 is a reply to message #140408] |
Wed, 18 February 2009 11:49 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Juergen,
I believe you are running into one or more of the following defects
related to running TPTP JUnit Plug-in test via ASF:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=210292 Exceptions when
running ASF tasks.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=220391 Connection property
does not deploy all dependencies and execute JUnit Plug-in Tests correctly.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=210289 ANT test results
property requires trailing slash to specify location
https://bugs.eclipse.org/bugs/show_bug.cgi?id=222760 Clear remote workspace
launch does not work for remote test execution
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147859
IExecutionDeploymentAdapter.cleanUpTestAssets no longer called
Paul
"Juergen Aschenbrenner" <juergen.aschenbrenner@gmail.com> wrote in message
news:gngn74$uv1$1@build.eclipse.org...
> /Juergen
> test-execution:
> exist
> parsing buildfile
> with URI =
> parsing buildfile
> with URI =
> parsing buildfile
> with URI =
> parsing buildfile
> with URI =
> parsing buildfile
> with URI =
> parsing buildfile
> with URI =
> BUILD FAILED
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 24 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION 2009-02-18
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> yet.
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 32 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.04437 seconds
