[Solved]Gemini - is there a way to speed the startup? [message #975274] |
Wed, 07 November 2012 18:58 |
Scott Hull Messages: 32 Registered: July 2012 |
Member |
Does anyone have any issues starting up their application with gemini and it increasing the startup time from a couple of seconds to over a minute? I have my application handle two EMFs which are instantiated only once each. I have turned off logging to help speed this along, but it does not help very much. Does anyone have any suggestions to speed this along? I would like to get it to the 20 seconds ballpark at the very least for a normal machine.
Thanks!
[Updated on: Tue, 20 November 2012 17:07] Report message to a moderator
Re: Gemini - is there a way to speed the startup? [message #985562 is a reply to message #981600] |
Thu, 15 November 2012 13:50 |
Member |
Mike,
Looks like this issue was related to our previous post about OSGI refresh bundles error. I believe we have obtained an efficient execution time of our product's startup procedure. Turning off the debug in the persistence.xml files and getting the right bundles configured and ordered (including removing the older, obsolete bundles you mentioned earlier) helped out tremendously. I will mark this solved in the next few days once I have confirmed this to work across multiple machines.
Thanks again!
[Updated on: Thu, 15 November 2012 13:51] Report message to a moderator
FUDForum. Page generated in 0.02973 seconds
