Home » Archived » Visual Editor (VE) » VE, Eclipse 3.3, and Vista
VE, Eclipse 3.3, and Vista [message #140007] Tue, 28 August 2007 17:29 Go to next message
Originally posted by: mucous.gmail.com
Is anyone running Erik Hecht's version of the VE for Eclipse 3.3
on Vista? I'm having a few problems that show up as "socket refused"
in the .log
However, turning on and off the Windows firefall has no effect.
I'm just curious if anyone has this combination working.
Re: VE, Eclipse 3.3, and Vista [message #140029 is a reply to message #140007] Tue, 28 August 2007 23:12 Go to previous messageGo to next message
Originally posted by: wolfgang_baltes.hotmail.com
Hi Denis,
I have this combination working. But everytime I upgrade or change the
eclipse configuration (adding a plugin) I run into the same problem you are.
The fix is to remove the eclipse entries from the firewall and then reboot
the system. I don't fully understand why the reboot is required, but this
makes things work. I should also mention that I use the Symatec Antivirus
solution, and not Microsoft's.
After the reboot and after starting eclipse, I get a firewall prompt asking
whether I want to grant network access to the software. Reply with yes!
I hope this helps,
Wolfgang.
"Denis Yuen" <mucous@gmail.com> wrote in message
news:fb24j2$2j9$1@build.eclipse.org...
> in the .log
> Thanks
Re: VE, Eclipse 3.3, and Vista [message #140213 is a reply to message #140007] Sun, 02 September 2007 16:20 Go to previous message
I use Vista Business Edition with Eclipse 3.3 without having socket
problems. But eclipse.exe is allowed to access the network with my
configuration. Eclipse is allowed to access the network. Perhaps this is the
problem? I noticed the same when going into debug-mode (The VM communicates
via sockets). Hope this helps.
"Denis Yuen" <mucous@gmail.com> schrieb im Newsbeitrag
> in the .log
> Thanks
Re: VE, Eclipse 3.3, and Vista [message #616409 is a reply to message #140007] Tue, 28 August 2007 23:12 Go to previous message
Hi Denis,
I hope this helps,
Wolfgang.
> in the .log
> Thanks
Re: VE, Eclipse 3.3, and Vista [message #616424 is a reply to message #140007] Sun, 02 September 2007 16:20 Go to previous message
> in the .log
> Thanks
Previous Topic:Migrate to VE from plan Swing
Next Topic:Errors in VE
Current Time: Mon Oct 27 18:23:18 EDT 2025
Powered by FUDForum. Page generated in 0.03328 seconds
