Home » Modeling » EMF » [CDO] SSL Server [ERROR] BufferUnderflowException(BufferUnderflowException at server while connecting)
[CDO] SSL Server [ERROR] BufferUnderflowException [message #973581] Tue, 06 November 2012 08:00 Go to next message
Hi there,
I am testing a CDO 4.1 server using a SSL connection. Everything went well with a simple TCP connection based on the example server. Currently the client connection test fails on server side due to an occuring java.nio.BufferUnderflowException.
Some details:
- CDO 4.1.1.v20120911-1146 (Juno SR1 release)
- Win x86_64 machine, Win7, Java7_09
To mention first, the NIO exception lets me think of an native problem within the 64bit enviroment, but I am not sure about that. I'm not very familiar with the Net4j interna. As far as I see, the SSL handshake works, but a read attempt fails afterwards.
What I've done so far:
- a CDO server based on the example master server (org.eclipse.emf.cdo.examples.installer.master) with a acceptor type "ssl"
<acceptor type="ssl" listenAddr="0.0.0.0" port="2036"/>
- created a keystore and truststore according to bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=333947 and modified the vmargs for launch
-Xms40m
-Xmx1024m
-Ddebug=true
-Dnet4j.config="${project_loc:/org.eclipse.emf.cdo.examples.installer.master}/config"
-Dorg.eclipse.emf.cdo.server.browser.port=7777
-Dosgi.console.enable.builtin=true
-Djavax.net.ssl.trustStore=file:///${resource_loc:org.eclipse.emf.cdo.examples.installer.master/ssl}/truststore.jks
-Djavax.net.ssl.trustStorePassword=truststore
-Djavax.net.ssl.keyStore=file:///${resource_loc:org.eclipse.emf.cdo.examples.installer.master/ssl}/keystore.test.jks
-Djavax.net.ssl.keyStorePassword=truststore
-Dorg.eclipse.net4j.tcp.ssl.passphrase=truststore
-Dorg.eclipse.net4j.tcp.ssl.trust=file:///${resource_loc:org.eclipse.emf.cdo.examples.installer.master/ssl}/truststore.jks
-Dorg.eclipse.net4j.tcp.ssl.key=file:///${resource_loc:org.eclipse.emf.cdo.examples.installer.master/ssl}/keystore.test.jks
-Dsun.security.ssl.allowUnsafeRenegotiation=true
-Dorg.eclipse.net4j.util.om.trace.disable=false
- enabled tracing
- created a test client connection with
    // Enable logging and tracing
    OMPlatform.INSTANCE.setDebugging(true);
    OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
    OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
    // Prepare container
    IManagedContainer container = ContainerUtil.createContainer();
    Net4jUtil.prepareContainer(container); // Register Net4j factories
    SSLUtil.prepareContainer(container);
    CDONet4jUtil.prepareContainer(container); // Register CDO factories
    container.activate();
    // Create connector
    IConnector connector = SSLUtil.getConnector(container, CDOTests.URL);
    // Create configuration
    CDONet4jSessionConfiguration configuration = CDONet4jUtil.createNet4jSessionConfiguration();
    configuration.setConnector(connector);
    configuration.setRepositoryName(CDOTests.REPO);
    // Open session
    CDOSession session = configuration.openNet4jSession();
    session.options().setGeneratedPackageEmulationEnabled(true);
    CDOTransaction cdoTransaction = session.openTransaction();
    assert null!=cdoTransaction.getResourceNode("testResource"); //$NON-NLS-1$
    session.close();
    connector.close();
A BufferUnderflowException occurs at:
TCPSelector [debug] Executing server operation REGISTER java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682]
TCPSelector [debug] Registering java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682]
TCPSelector [debug.connector] Setting state CONNECTED (was connecting) for SSLServerConnector[127.0.0.1:49.682]
TCPSelector [debug.acceptor] Added connector SSLServerConnector[127.0.0.1:49.682]
TCPSelector [debug] Reading java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682]
net4j-Thread-1 [debug] Scheduled task: sun.security.ssl.Handshaker$DelegatedTask@35725349
net4j-Thread-1 [debug] Scheduled task: sun.security.ssl.Handshaker$DelegatedTask@72f51247
TCPSelector [debug.lifecycle] Activating SignalProtocol[cdo]
TCPSelector [debug.lifecycle.dump] DUMP  CDOServerProtocol@36
  Protocol.type = cdo
  Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@2aa68b6a[Running, pool size = 2, active threads = 0, queued tasks = 0, completed tasks = 3]
  Protocol.bufferProvider = Channel[-32.768, SERVER]
  Protocol.infraStructure = null
  Protocol.channel = Channel[-32.768, SERVER]
  Protocol.userID = null
  SignalProtocol.timeout = 10000
  SignalProtocol.streamWrapper = null
  SignalProtocol.signals =
  SignalProtocol.nextCorrelationID = 1
  SignalProtocol.failingOver = false
  negotiationTimeout = 15000
  repositoryProvider = org.eclipse.emf.cdo.spi.server.PluginRepositoryProvider@2b02a8fb
  packageURICompressor = StringCompressor[client=false]
TCPSelector [debug.connector] Opening channel with protocol cdo
TCPSelector [debug.lifecycle] Activating Channel[1, SERVER, cdo]
TCPSelector [debug.lifecycle] Activating ReceiveSerializer@37
TCPSelector [debug.lifecycle.dump] DUMP  ReceiveSerializer@37
  Worker.daemon = false
  Worker.activationTimeout = 10000
  Worker.deactivationTimeout = 10000
  QueueWorker.queue =
  QueueWorker.pollMillis = 100
TCPSelector [debug.lifecycle.dump] DUMP  Channel@38
  userID = null
  channelMultiplexer = SSLServerConnector[127.0.0.1:49.682]
  id = 1
  receiveExecutor = java.util.concurrent.ThreadPoolExecutor@2aa68b6a[Running, pool size = 2, active threads = 0, queued tasks = 0, completed tasks = 3]
  receiveHandler = SignalProtocol[cdo]
  receiveSerializer = ReceiveSerializer@37
  sendQueue =
  sentBuffers = 0
  receivedBuffers = 0
TCPSelector [debug.channel] Handling buffer: Buffer@39[PUTTING] --> Channel[Control, SERVER]
TCPSelector [debug] Ordering server operation INTEREST READ java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = false
TCPSelector [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = true
TCPSelector [debug] Executing server operation INTEREST READ java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = false
TCPSelector [debug] Setting interest  (was read)
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = true
TCPSelector [debug] Setting interest WRITE
TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682]
TCPSelector [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = false
TCPSelector [debug] Ordering server operation INTEREST READ java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = true
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = false
TCPSelector [debug] Setting interest  (was write)
TCPSelector [debug] Executing server operation INTEREST READ java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49682] = true
TCPSelector [debug] Setting interest READ
net4j-Thread-1 [debug.lifecycle] Deactivating SSLServerConnector[127.0.0.1:49.682]
net4j-Thread-1 [debug.lifecycle] Deactivating Channel[Control, SERVER]
net4j-Thread-1 [debug.lifecycle] Deactivating ReceiveSerializer@33
net4j-Thread-1 [debug.connector] Setting state DISCONNECTED (was connected) for SSLServerConnector[null:0]
net4j-Thread-1 [debug.lifecycle] Deactivating Channel[1, SERVER, cdo]
net4j-Thread-1 [debug.lifecycle] Deactivating ReceiveSerializer@37
net4j-Thread-1 [debug.lifecycle] Deactivating SignalProtocol[cdo]
	at java.nio.Buffer.nextGetIndex(Buffer.java:498)
	at java.nio.DirectByteBuffer.getShort(DirectByteBuffer.java:580)
	at org.eclipse.net4j.internal.tcp.ssl.SSLBuffer.startGetting(SSLBuffer.java:84)
	at org.eclipse.net4j.internal.tcp.TCPConnector.handleRead(TCPConnector.java:220)
	at org.eclipse.net4j.internal.tcp.ssl.SSLConnector.handleRead(SSLConnector.java:70)
	at org.eclipse.net4j.internal.tcp.TCPSelector.handleSelection(TCPSelector.java:255)
	at org.eclipse.net4j.internal.tcp.TCPSelector.run(TCPSelector.java:170)
	at java.lang.Thread.run(Thread.java:722)
[ERROR] BufferOverflowException
java.nio.BufferOverflowException
	at java.nio.DirectByteBuffer.put(DirectByteBuffer.java:357)
	at org.eclipse.net4j.internal.tcp.ssl.SSLBuffer.startGetting(SSLBuffer.java:79)
	at org.eclipse.net4j.internal.tcp.ssl.SSLConnector.handleRead(SSLConnector.java:76)
net4j-Thread-1 [debug.acceptor] Removed connector SSLServerConnector[null:0]
Any ideas anyone?
Bernold
Re: [CDO] SSL Server [ERROR] BufferUnderflowException [message #973643 is a reply to message #973581] Tue, 06 November 2012 08:55 Go to previous messageGo to next message
Hi Bernold,
The SSL connector has been developed by NoMagic and I'm not able to give advice for it. I've cc'ed Saulius from NoMagic
in the hope that he can provide more infos.
Cheers
/Eike
http://www.esc-net.de
Am 06.11.2012 14:43, schrieb Bernold Kraft:
> Hi there,
> Some details:
> fails afterwards.
> "ssl"
> -Xms40m
> -Xmx1024m
> -Ddebug=true
> -Dsun.security.ssl.allowUnsafeRenegotiation=true -Dorg.eclipse.net4j.util.om.trace.disable=false
> - enabled tracing
> // Create connector
> // Open session
> session.close();
> connector.close();
> Protocol.type = cdo
> SignalProtocol.signals = SignalProtocol.nextCorrelationID = 1
> QueueWorker.queue = QueueWorker.pollMillis = 100
> userID = null
> id = 1
> sendQueue = sentBuffers = 0
> receivedBuffers = 0
> Any ideas anyone?
> Bernold
Re: [CDO] SSL Server [ERROR] BufferUnderflowException [message #975800 is a reply to message #973581] Wed, 07 November 2012 23:49 Go to previous messageGo to next message
Hi Bernold,
Here's what the original developer replied to me:
For the server need to store only key store file and set key store cert
and pass phrase via the VM arguments below.
For each client need to store only trust key file and set trust key cert
and passphrase via the VM arguments below.
"-Dorg.eclipse.net4j.tcp.ssl.key" for setting key store cert file for
server (key store).
"-Dorg.eclipse.net4j.tcp.ssl.trust" for setting trust cert file for
client (trust key).
"-Dorg.eclipse.net4j.tcp.ssl.passphrase" for both client and server
Cheers
/Eike
Re: [CDO] SSL Server [ERROR] BufferUnderflowException [message #976266 is a reply to message #975800] Thu, 08 November 2012 07:49 Go to previous messageGo to next message
Hi Eike,
I changed the VM arguments, but the result is the same. I don't think, that these details have any influence.
I recognized another Exception, which occures after the BufferUnderflowException:
TCPSelector [debug] Executing server operation REGISTER java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49861]
TCPSelector [debug] Registering java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49861]
TCPSelector [debug.connector] Setting state CONNECTED (was connecting) for SSLServerConnector[127.0.0.1:49.861]
TCPSelector [debug.acceptor] Added connector SSLServerConnector[127.0.0.1:49.861]
net4j-Thread-3 [debug] SSL handshake incomplete.
javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
	at sun.security.ssl.EngineInputRecord.bytesInCompletePacket(EngineInputRecord.java:171)
	at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:845)
	at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:758)
	at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624)
	at org.eclipse.net4j.internal.tcp.ssl.SSLEngineManager.performHandshake(SSLEngineManager.java:420)
	at org.eclipse.net4j.internal.tcp.ssl.SSLEngineManager.checkInitialHandshake(SSLEngineManager.java:139)
	at org.eclipse.net4j.internal.tcp.ssl.SSLConnector$1.run(SSLConnector.java:219)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
net4j-Thread-3 [debug] ssl cannot handshake.
TCPSelector [debug] Reading java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:49861]
It did appear sometimes during the last tests. Maybe only a subsequent exception caused by BufferUnderflowException.
I try to figure out, wether this is a kind of platform problem with win64.
Bernold
Re: [CDO] SSL Server [ERROR] BufferUnderflowException [message #1482089 is a reply to message #976266] Fri, 21 November 2014 08:28 Go to previous messageGo to next message
this post is quiet old but, I'm facing exactly the same problem (SSL acceptor) after few days of experiments :
at org.eclipse.net4j.internal.tcp.TCPConnector.handleRead(TCPConnector.java:219)
I have a look at those pages with no chance :
- bug 299871
- Bug 262875
- Bug 295989
- and www.eclipse.org/forums/index.php/t/731156/
Does anyone find a solution/configuration ?
Re: [CDO] SSL Server [ERROR] BufferUnderflowException [message #1488244 is a reply to message #1482089] Wed, 26 November 2014 07:39 Go to previous message
I faced the same problem a couple of months ago. Here's the general procedure I wrote down to remember what to do Wink :
On the server side :
In 'cdo-server.xml', change the acceptor type to 'ssl'.
Follow the « Security Features in Java SE » trail of the Java Tutorial to create the necessary keystore and truststore :
http://docs.oracle.com/javase/tutorial/security/toolsign/step3.html
In case, only the JRE is installed (which comes without keytool), one can use the Keytool plugin for Eclipse :
http://keytool.sourceforge.net/
Create a 'server.jks' keystore that will contain the server private key and where the public client one will be added (e.g. imported as a 'client.cer' file).
Important: Make sure the same password is used for the private key and the store as SSL Net4J connector only expects and uses one single passphrase (see JVM arguments below).
Copy the 'server.jks' in the exported product directory (I run my CDO server as a standalone exported product) and add the following JVM arguments to the 'RepositoryServer.ini':
-vmargs
-Dorg.eclipse.net4j.tcp.ssl.passphrase=mySingleServerPassword
-Dorg.eclipse.net4j.tcp.ssl.key=file:///[/absolute/path/to/]server.jks
-Dorg.eclipse.net4j.tcp.ssl.trust=file:///[/absolute/path/to/]server.jks
On the client side :
Use an SSL URI corresponding the server acceptor like : ssl://localhost:2036
Follow the same steps as on the server side to created the "opposite" 'client.jks' keystore in your exported product directory (my client is a RCP application) and add the following JVM arguments to its .ini file :
-vmargs
-Dorg.eclipse.net4j.tcp.ssl.passphrase=mySingleClientPassword
-Dorg.eclipse.net4j.tcp.ssl.trust=file:///[/absolute/path/to/]client.jks
-Dorg.eclipse.net4j.tcp.ssl.key=file:///[/absolute/path/to/]client.jks
Hope it helps.
Laurent
Previous Topic:[XCORE]
Next Topic:[Xcore]
Current Time: Mon Oct 13 22:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.04328 seconds
