Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Using workflow with GMF 2.2 for Xpand + QVTO
Using workflow with GMF 2.2 for Xpand + QVTO [message #139053] Tue, 21 July 2009 10:52 Go to next message
So apparently in the wonderful world of GMF 2.2, we have switched from
Xtend to QVTO for the query.
If I look at some sample workflows I see something like:
<component class="org.eclipse.xpand2.Generator">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel " />
<expand value="pmw2csv::Main FOR model" />
<outlet path="${out}" />
</component>
I'm guessing that for using QVTO, should the above component class
should be changed?
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #139102 is a reply to message #139053] Wed, 22 July 2009 08:07 Go to previous messageGo to next message
> <metaModel id="mm"
> </component>
> should be changed?
AFAIK:
1 - GMF Xpand and M2T Xpand are different and not compatible, the GMF
Xpand is now using QVTO
2 - there is no MWE component for GMF Xpand
3 - creating a workflow component is easy
Krzysztof Kowalczyk
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #139183 is a reply to message #139102] Fri, 24 July 2009 17:21 Go to previous messageGo to next message
>> <metaModel id="mm"
>> </component>
>> should be changed?
> AFAIK:
> Regards,
> Krzysztof Kowalczyk
This was part of my original confusion when I started with Xpand
recently, ie which version of Xpand goes with what GMF. It may be
me but I can't get the MWE/M2T combo to work on Galileo Modeling
but it works on all the other downloads if I install MWE/M2T myself.
Going forward which will be the definitive Xpand, M2T or GMF in future?
Why have 2 different things with the same name, it's confusing.
Is one going to be deprecated?
regards
Steve
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #139194 is a reply to message #139183] Sat, 25 July 2009 11:33 Go to previous message
> regards
> Steve
You should ask on eclipse.modeling or (GMF and M2T) newsgroups.
Krzysztof Kowalczyk
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621173 is a reply to message #139053] Wed, 22 July 2009 08:07 Go to previous message
> <metaModel id="mm"
> </component>
> should be changed?
AFAIK:
Krzysztof Kowalczyk
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621180 is a reply to message #139102] Fri, 24 July 2009 17:21 Go to previous message
>> <metaModel id="mm"
>> </component>
>> should be changed?
> AFAIK:
> Regards,
> Krzysztof Kowalczyk
regards
Steve
Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621181 is a reply to message #139183] Sat, 25 July 2009 11:33 Go to previous message
> regards
> Steve
Krzysztof Kowalczyk
Previous Topic:emf compare
Next Topic:[Proposal] EMF Tiger and EMF Refactor
Current Time: Tue May 20 19:23:36 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
