| Using workflow with GMF 2.2 for Xpand + QVTO [message #139053] |
Tue, 21 July 2009 10:52  |
So apparently in the wonderful world of GMF 2.2, we have switched from
Xtend to QVTO for the query.
If I look at some sample workflows I see something like:
<component class="org.eclipse.xpand2.Generator">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel " />
<expand value="pmw2csv::Main FOR model" />
<outlet path="${out}" />
</component>
I'm guessing that for using QVTO, should the above component class
should be changed?
| Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #139194 is a reply to message #139183] |
Sat, 25 July 2009 11:33  |
> This was part of my original confusion when I started with Xpand
> recently, ie which version of Xpand goes with what GMF. It may be
> me but I can't get the MWE/M2T combo to work on Galileo Modeling
> but it works on all the other downloads if I install MWE/M2T myself.
> Going forward which will be the definitive Xpand, M2T or GMF in future?
> Why have 2 different things with the same name, it's confusing.
> Is one going to be deprecated?
> regards
> Steve
You should ask on eclipse.modeling or (GMF and M2T) newsgroups.
Krzysztof Kowalczyk
| Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621173 is a reply to message #139053] |
Wed, 22 July 2009 08:07  |
> <metaModel id="mm"
> </component>
> should be changed?
AFAIK:
1 - GMF Xpand and M2T Xpand are different and not compatible, the GMF
Xpand is now using QVTO
2 - there is no MWE component for GMF Xpand
3 - creating a workflow component is easy
Krzysztof Kowalczyk
| Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621180 is a reply to message #139102] |
Fri, 24 July 2009 17:21  |
>> <metaModel id="mm"
>> </component>
>> should be changed?
> AFAIK:
> Regards,
> Krzysztof Kowalczyk
regards
Steve
| Re: Using workflow with GMF 2.2 for Xpand + QVTO [message #621181 is a reply to message #139183] |
> regards
> Steve
Krzysztof Kowalczyk
FUDForum. Page generated in 0.05540 seconds
