Re: Missing requiremennt: org.eclipse.platform [message #970983 is a reply to message #970245] |
Sun, 04 November 2012 13:35 |
Ed Merks Messages: 33142 Registered: July 2009 |
Tony,
Which version of Eclipse are you installing into? Which version of EMF
and Eclipse does UIMA require? I don't generally expect anyone to
install the examples feature, those examples are used to build the SDK
to help you create examples in the workspace. I'm not sure why you have
them installed.
On 04/11/2012 1:04 PM, Tony Su wrote:
> Running Juno on x64 openSUSE 12.2
> (If you just want to see the error, skip to the end)
> Attempting to install UIMA, wow what a test of frustration... Have
> been gradually ironing out missing dependencies until I've run into
> this one.
> Apparently this URL supposedly is insufficient (Maybe, maybe not. See
> how things progress, I arrive at the same error)
> http://download.eclipse.org/modeling/emf/updates/releases
> so
> Attempting to install from this recommended URL
> which resulted in a minor error (sorry, I can't remember exactly what
> it was)
> I then ran "Help... Check for Updates" which installed/updated
> numerous packages
> But then when after an automatic Eclipse restart,
> I'm seeing the same error reported when I tried the first URL
> Error Reported
> Missing requirement: EMF Examples 2.5.0.v200906151043
> (org.eclipse.emf.examples.feature.group 2.5.0.v200906151043) requires
> 'org.eclipse.platform.feature.group
> [3.3.0.v20061208-Fj22sCYGm0XDWm3,4.0.0)' but it could not be found
> Am unable to find any way to resolve this. Surely this should be
> available as part of a standard package?
> TIA,
> Tony
Ed Merks
Re: Missing requiremennt: org.eclipse.platform [message #973875 is a reply to message #973855] |
Tue, 06 November 2012 17:40 |
Tony,
Yes, if their documentation misdirected you, best you suggest they
update it.
On 06/11/2012 6:20 PM, Tony Su wrote:
> Thx Ed!
> That seems to have worked (Installed without errors).
> If this becomes the recommended approach, then I wonder if either the
> UIMA folks should update their documentation or maybe a re-direct for
> the URI I used?
> Or, of course I guess people following in my footsteps can just run
> into the problem and find this thread...
> Tony
Ed Merks
FUDForum. Page generated in 0.04157 seconds
