Home » Newcomers » Newcomers » How to pair program with Eclipse?
How to pair program with Eclipse? [message #138479] Fri, 17 February 2006 13:56 Go to next message
Originally posted by: siegfried.heintze.com
I just discovered a nifty feature in emacs: "new frame on display". This
menu entry prompts me for another X server and (assuming someone has typed
xhost+ on that remote machine) it brings up a windows on the remote machine
so we can both edit the same file at the same time.
Does eclipse have this feature?
thanks,
siegfried
Re: How to pair program with Eclipse? [message #138504 is a reply to message #138479] Fri, 17 February 2006 16:06 Go to previous messageGo to next message
Doubtful - it sounds like an extremely platform specific feature, not
easily ported to Windows or OS X. Pair programming may be supported at
a higher application level through a 3rd party plug-in, but a quick
search on eclipse-plugins.info didn't come up with much in the way of
promising results.
Hope this helps,
- Jeff
Re: How to pair program with Eclipse? [message #138517 is a reply to message #138504] Fri, 17 February 2006 18:07 Go to previous message
That is odd. emacs has been ported everywhere. I see the menu entry even on
windows. I hope to try it. I already tried it on linux and it worked. Oh
well. Hurray for the old standby.
Siegfried
"Jeff Myers" <jeff.myers@eclipse.org> wrote in message
news:dt5dpr$6qi$1@utils.eclipse.org...
> promising results.
> Hope this helps,
> - Jeff
Previous Topic:Plugin: Deployment problem
Next Topic:java method separator
Current Time: Fri Nov 07 04:42:04 EST 2025
Powered by FUDForum. Page generated in 0.11524 seconds
