Home » Archived » Test and Performance Tools Platform (TPTP) » how to run in standard mode
Re: how to run in standard mode [message #138568 is a reply to message #138556] |
Thu, 20 November 2008 11:29 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Yes, that is the right workspace. Does the context workspace get created
when you run the test? If not, does the context workbench appear? If not,
are there any errors in your .log file?
Paul
"Asha " <asha@readiminds.com> wrote in message
news:697466ee4db8588a6e14b6f88c7025e8$1@www.eclipse.org...
> Hi Paul,
> I defined behaviour for test cases.the workspace specified is "
> ${workspace_loc}/../auto-gui-workspace".is this right? Paul Slauenwhite
> wrote:
>> Hi Asha,
>> Do you have a behaviour defined for your test suite? Does the
>> workspace specified in the AGR test suite editor (Overview tab) get
>> created?
>> I would suggest that you have something wrong with your install. Cna
>> you try reinstalling using these installation instructions:
> http://www.eclipse.org/tptp/test/documents/gettingstarted/Au tomated_GUI_Recorder_Getting_Started.html#2.0
>> Paul
>> news:7c73259f22a371f60e3402990ce1533f$1@www.eclipse.org...
>>> Hi, no error is coming.there should be another workbench open when we
>>> run in standard mode, but in my case the current workbench closed and
>>> after that nthg happens. and when i open the workbench then i didn' get
>>> the testsuite.execution file.
>>> Paul Slauenwhite wrote:
>>>> Hi Asha,
>>>> Do you have a behaviour defined for your test suite? If so, does
>>>> the context workbench appear? If not, are there any errors in your
>>>> .log files in both your workspace and the workspace specified in the
>>>> AGR test suite editor (Overview tab)?
>>>> Paul
>>>> news:28899a5bf6b2f6b411895703b9d25683$1@www.eclipse.org...
>>>>> hi..I follow all the steps written in "An Introduction to Using TPTP's
>>>>> Automated GUI Recorder" document for running test cases in standard
>>>>> mode. but still i m not able to run it .after running nothing
>>>>> happens.can anyone tell me in detail (Step wise)for running test cases
>>>>> in standard mode..
Re: how to run in standard mode [message #138580 is a reply to message #138568] |
Thu, 20 November 2008 11:40 |
Asha Messages: 28 Registered: July 2009 |
Hi Paul,
In error log i get error as "Invalid preference page path:
Icon Style" .but i m not able to get test log file, how can i see test log
file.
> Paul
>> Hi Paul,
>> wrote:
>>> Hi Asha,
>>> created?
>>> Paul
>>>>> Hi Asha,
>>>>> Paul
>>>>>> in standard mode..
Re: how to run in standard mode [message #138628 is a reply to message #138580] |
Fri, 21 November 2008 06:37 |
The error "Invalid preference page path: Icon Style" is not related with
automated test cases.Other than that i not getting any error in error log
file..
Asha wrote:
> Hi Paul,
> file.
>> Paul
>>> Hi Paul,
>>> wrote:
>>>> Hi Asha,
>>>> created?
>>>> Paul
>>>>>> Hi Asha,
>>>>>> Paul
>>>>>>> in standard mode..
Re: how to run in standard mode [message #138640 is a reply to message #138628] |
Fri, 21 November 2008 11:27 |
Asha,
I would suggest that you try reinstallating the TPTP all-in-one
(http://www.eclipse.org/tptp/home/downloads/?ver=4.5.1) and the AGR (see
http://www.eclipse.org/tptp/test/documents/gettingstarted/Au tomated_GUI_Recorder_Getting_Started.html#2.0).
Paul
news:20618c8f40ff239685c2cb50ba98a99e$1@www.eclipse.org...
> file..
> Asha wrote:
>> Hi Paul,
>> log file.
>>> created when you run the test? If not, does the context workbench
>>> appear? If not, are there any errors in your .log file?
>>> Paul
>>>> Hi Paul,
>>>> wrote:
>>>>> Hi Asha,
>>>>> created?
>>>>> Cna you try reinstalling using these installation instructions:
>>>>> Paul
>>>>>> get the testsuite.execution file.
>>>>>>> Hi Asha,
>>>>>>> does the context workbench appear? If not, are there any errors in
>>>>>>> your .log files in both your workspace and the workspace specified
>>>>>>> in the AGR test suite editor (Overview tab)?
>>>>>>> Paul
>>>>>>>> TPTP's Automated GUI Recorder" document for running test cases in
>>>>>>>> standard mode. but still i m not able to run it .after running
>>>>>>>> nothing happens.can anyone tell me in detail (Step wise)for running
>>>>>>>> test cases in standard mode..
Re: how to run in standard mode [message #138651 is a reply to message #138640] |
Fri, 21 November 2008 12:38 |
I can't install TPTP 4.5 as i m using 3.3 version of eclipse but i will
reinstall everything for TPTP 4.4
> Asha,
> Paul
>> file..
>> Asha wrote:
>>> Hi Paul,
>>> log file.
>>>> Paul
>>>>> Hi Paul,
>>>>> wrote:
>>>>>> Hi Asha,
>>>>>> created?
>>>>>> Paul
>>>>>>>> Hi Asha,
>>>>>>>> Paul
Re: how to run in standard mode [message #138689 is a reply to message #138651] |
Mon, 24 November 2008 10:00 |
Hello Paul ,
I installed it again now its showing one error as
('IWAT4039E The Test Execution Harness reported the following
problems:Failed to retrieve the context that should be used to run the
test cases in').what is that
>> Asha,
>> Paul
>>> file..
>>> Asha wrote:
>>>> Hi Paul,
>>>> log file.
>>>>> Paul
>>>>>> Hi Paul,
>>>>>> wrote:
>>>>>>> Hi Asha,
>>>>>>> created?
>>>>>>> Paul
>>>>>>>>> Hi Asha,
>>>>>>>>> Paul
Re: how to run in standard mode [message #138710 is a reply to message #138689] |
Mon, 24 November 2008 11:45 |
Hi Asha,
This error is caused by an incorrect/faulty path to the workbench
instance used to run the AGR tests. I believe you have a faulty
configuration.
Note, in TPTP 4.5, the AGR was moved from a Technology Preview component
to an As-Is component. As-Is components are primarily provided for prior
users but imply no support (for example, defects, news group, and mailing
lists). As such, we are unable to debug your problem.
Paul
news:3ef408ce355c1d1584ccb2e0a8a89bb5$1@www.eclipse.org...
> Hello Paul ,
>>> Asha,
>>> Paul
>>>> with automated test cases.Other than that i not getting any error in
>>>> error log file..
>>>> Asha wrote:
>>>>> Hi Paul,
>>>>> path: Icon Style" .but i m not able to get test log file, how can i
>>>>> see test log file.
>>>>>> Paul
>>>>>>> Hi Paul,
>>>>>>> " ${workspace_loc}/../auto-gui-workspace".is this right? Paul
>>>>>>> Slauenwhite wrote:
>>>>>>>> Hi Asha,
>>>>>>>> created?
>>>>>>>> install. Cna you try reinstalling using these installation
>>>>>>>> instructions:
>>>>>>>> Paul
>>>>>>>>> we run in standard mode, but in my case the current workbench
>>>>>>>>> closed and after that nthg happens. and when i open the workbench
>>>>>>>>> then i didn' get the testsuite.execution file.
>>>>>>>>>> Hi Asha,
>>>>>>>>>> in your .log files in both your workspace and the workspace
>>>>>>>>>> specified in the AGR test suite editor (Overview tab)?
>>>>>>>>>> Paul
>>>>>>>>>>> in standard mode. but still i m not able to run it .after
>>>>>>>>>>> running nothing happens.can anyone tell me in detail (Step
>>>>>>>>>>> wise)for running test cases in standard mode..
Re: how to run in standard mode [message #138759 is a reply to message #138710] |
Tue, 25 November 2008 05:18 |
hello Paul,
Now i m able to run in standard mode.yesterday i didn't
restart my system after intalling all things. now its running but it
always failed.
> Hi Asha,
> configuration.
> Paul
>> Hello Paul ,
>>>> Asha,
>>>> Paul
>>>>> error log file..
>>>>> Asha wrote:
>>>>>> Hi Paul,
>>>>>> see test log file.
>>>>>>> Paul
>>>>>>>> Hi Paul,
>>>>>>>> Slauenwhite wrote:
>>>>>>>>> Hi Asha,
>>>>>>>>> created?
>>>>>>>>> instructions:
>>>>>>>>> Paul
>>>>>>>>>>> Hi Asha,
>>>>>>>>>>> Paul
Re: how to run in standard mode [message #138771 is a reply to message #138759] |
Tue, 25 November 2008 11:28 |
Asha, good news. I would suggest that there is something wrong with your
recording to cause the failure.
Paul
news:1ecb977c124d7d17611a89bca34216db$1@www.eclipse.org...
> hello Paul,
> always failed.
>> Hi Asha,
>> configuration.
>> component to an As-Is component. As-Is components are primarily provided
>> for prior users but imply no support (for example, defects, news group,
>> and mailing lists). As such, we are unable to debug your problem.
>> Paul
>>> Hello Paul ,
>>>> will reinstall everything for TPTP 4.4
>>>>> Asha,
>>>>> (see
>>>>> Paul
>>>>>> error log file..
>>>>>> Asha wrote:
>>>>>>> Hi Paul,
>>>>>>> see test log file.
>>>>>>>> Paul
>>>>>>>>> Hi Paul,
>>>>>>>>> is " ${workspace_loc}/../auto-gui-workspace".is this right? Paul
>>>>>>>>> Slauenwhite wrote:
>>>>>>>>>> Hi Asha,
>>>>>>>>>> the workspace specified in the AGR test suite editor (Overview
>>>>>>>>>> tab) get created?
>>>>>>>>>> instructions:
>>>>>>>>>> Paul
>>>>>>>>>>> when we run in standard mode, but in my case the current
>>>>>>>>>>> workbench closed and after that nthg happens. and when i open
>>>>>>>>>>> the workbench then i didn' get the testsuite.execution file.
>>>>>>>>>>>> Hi Asha,
>>>>>>>>>>>> so, does the context workbench appear? If not, are there any
>>>>>>>>>>>> errors in your .log files in both your workspace and the
>>>>>>>>>>>> tab)?
>>>>>>>>>>>> Paul
>>>>>>>>>>>>> Using TPTP's Automated GUI Recorder" document for running test
>>>>>>>>>>>>> cases in standard mode. but still i m not able to run it
>>>>>>>>>>>>> .after running nothing happens.can anyone tell me in detail
>>>>>>>>>>>>> (Step wise)for running test cases in standard mode..
Re: how to run in standard mode [message #138784 is a reply to message #138771] |
Wed, 26 November 2008 03:56 |
the test cases which i have created running fine in quick mode but in
standard mode it showing error as
There was an error while running the macro associated with the test case:
Test. org.eclipse.core.runtime.CoreException: Error while executing a
macro command: MacroCommand [item-expand, line 3]
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell.createPlaybackException(MacroCommandShell.java:1261)
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell.access$11(MacroCommandShell.java:1258)
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(MacroCommandShell.java:1214)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
at org.eclipse.core.launcher.Main.main(Main.java:30)
> Paul
>> hello Paul,
>> always failed.
>>> Hi Asha,
>>> configuration.
>>> Paul
>>>> Hello Paul ,
>>>>>> Asha,
>>>>>> (see
>>>>>> Paul
>>>>>>> error log file..
>>>>>>> Asha wrote:
>>>>>>>> Hi Paul,
>>>>>>>> see test log file.
>>>>>>>>> Paul
>>>>>>>>>> Hi Paul,
>>>>>>>>>> Slauenwhite wrote:
>>>>>>>>>>> Hi Asha,
>>>>>>>>>>> tab) get created?
>>>>>>>>>>> instructions:
>>>>>>>>>>> Paul
>>>>>>>>>>>>> Hi Asha,
>>>>>>>>>>>>> tab)?
>>>>>>>>>>>>> Paul
Re: how to run in standard mode [message #138797 is a reply to message #138784] |
Wed, 26 November 2008 12:00 |
Asha,
Check line 3 for what widget/view/dialog/etc. it is using. Often, the
local workbench (quick mode) has preferences (eliminating certain dialogs
asking to set the preferences) or resources in the workspace that are not in
the context workbench/workspace, thereby causing failures when running in
standard mode. Always start recording in a new workspace, simulating the
running the running environment.
Paul
news:7ff9bed2e02bced3464a38bd82d11e8f$1@www.eclipse.org...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Paul
>>> hello Paul,
>>> always failed.
>>>> Hi Asha,
>>>> configuration.
>>>> provided for prior users but imply no support (for example, defects,
>>>> news group, and mailing lists). As such, we are unable to debug your
>>>> problem.
>>>> Paul
>>>>> Hello Paul ,
>>>>>>> Asha,
>>>>>>> (see
>>>>>>> Paul
>>>>>>>> in error log file..
>>>>>>>> Asha wrote:
>>>>>>>>> Hi Paul,
>>>>>>>>> i see test log file.
>>>>>>>>>> workbench appear? If not, are there any errors in your .log
>>>>>>>>>> file?
>>>>>>>>>> Paul
>>>>>>>>>>> Hi Paul,
>>>>>>>>>>> specified is " ${workspace_loc}/../auto-gui-workspace".is this
>>>>>>>>>>> right? Paul Slauenwhite wrote:
>>>>>>>>>>>> Hi Asha,
>>>>>>>>>>>> tab) get created?
>>>>>>>>>>>> instructions:
>>>>>>>>>>>> Paul
>>>>>>>>>>>>>> Hi Asha,
>>>>>>>>>>>>>> tab)?
>>>>>>>>>>>>>> Paul
>>>>>>>>>>>>>>> test cases in standard mode. but still i m not able to run
>>>>>>>>>>>>>>> it .after running nothing happens.can anyone tell me in
>>>>>>>>>>>>>>> detail (Step wise)for running test cases in standard mode..
Current Time: Fri Apr 26 19:17:44 GMT 2024
Powered by FUDForum. Page generated in 0.04117 seconds
